REPAIR? OR ELECTRICITY
My system charges the MP3 but the light indicator never came on and of course the volume and speaker system never functioned. What am I doing wrong? What could be the problem? I live in Kuwait, but I bought my system in the United States - could electricity be the problem?
  • 127 Answers
No, this is probably a system malfunction and if it was under warranty i would send it to the manufactorer, OR try to have a local repair shop look at it.
Posted on Nov 13, 2009
Santai TD-V26 user manual
The device has an on/off toggle switch and four control pushbutton switches (left ro right) are:
1. Menu (FM Radio or MP3 Player) select
2. Play/Hold
3. Back/Previous
4. Forward/Next
Inputs and output are:
1. 1/8" External Source Input Jack
2. Micro SD Slot
3. Mini USB 5v External Power Input
4. 1/8" Headset/Output Jack
5. USB Memory Card/USB Cable Input/ (Right Side)
The Menu switch has two functions, MP3 Player and FM Radio as indicated by the display. If the Play/Hold switch is pushed in and held for a few seconds the radio will automatically sweep and put the available local stations in memory. The back and forward switches are used to select the desired station. The display indicates station channel number and broadcast frequency (MHz).
In the MP3 Player function Menu function the Play/Hold Switch starts and stops the player. Back and Forward switches select the previous or next track. Simple as that. The player automatically plays the next file if left alone unless the Play/Hold switch is pressed. The display indicates file number and play time. No other functions, like folder selection, were found. If a 5v dc supply is connected to the Mini USB connector the battery will remain charged and it can be used as a small table radio/player. No tests were made to see how long it would operate on its internal battery.
The sound is good and better than expected for a device its size. Enough sound output to hear it in any part of an small house (With some distortion of course). The volume is controlled by holding the forward or back switches in for a couple of seconds and it will switch to volume level control. The display is LED rather than LCD and easier to view. It is on continuously when the player is working with the charger attached.
Aug 23, 2012 | Santai TD-V26 Portable Mini Digital...
Hitachi mx-w50
This is not a camera, it is an integrated 'hi-fi' system - try posting this query in a forum dealing with music centres
Jun 16, 2017 | Cameras
When connecting den on avr f100 and poa f100 system I get virtualy no sound coming thru speaker have to go to full volume to get any sound what so ever. Is there a set up mode that I have to go to .?
External sources have a piece of this, too. Having an out in/out reversal will sometimes give just a hint of a signal.
Of course there's a setup. You don't just hook things up and crank the volume to make it work. I can't find the manuals but YOU should. Read and understand the meaning and function of every switch and indicator.
NEVER USE MAXIMUM volume for anything, especially troubleshooting. One moment after you find the incorrect switch setting you'll blow your speakers.
May 14, 2011 | Denon Audio Players & Recorders
Nano won't play music just through my headphones-
1 Please check the headphones on any other device to make sure that there is nothing wrong with them and they are functioning normally. 2 Switch on the Nano and press MENU 3 Go to settings and go to clicker. It will show 'speakers' 4 Press the center and it will change to headphones. 5 Set it there. 6 Similarly you can adjust the volume.
Jan 22, 2010 | Audio Players & Recorders
No sound from creative t3030 2.1 speakers
you checked adapter light the green light is show
Jul 23, 2009 | Creative Labs Inspire T3030 Computer...
Subwoofer amplifier
Here's how I'd do it... connect the subwoofer pre-out to one of the unused analog inputs (CD or CD-R perhaps?). Turn on Zone 2 by pressing the MULTI-ZONE ON/OFF button. The MULTI-ZONE indicator will light.
Press CONTROL. (Zone 2 should display) Use the INPUT SELECTOR dial to select the source for the zone you have selected. In my example, CD or CD-R.
Of course, you'll need the sub hooked up to the Surround back speaker terminals.
Here's a link to the manual online:
Pioneer VSX-1018 Manual
Things to keep in mind:
The Surround Back setting must be set to ZONE 2. See page 41 of the manual.
The volume level going to the sub will probably need some tweaking. Check out page 7 to see how to manually adjust volume levels, or get it close by adjusting the Master Volume while in Zone 2 control.
I'm not sure if the auto setup function (with the included microphone) will work properly with this setup. And, of course, this is not a "suggested" setup by Pioneer, so please use caution when hooking everything up.
Apr 21, 2009 | Audio Players & Recorders
Sansa fuze radio will not work red speaker showing
I had the same problem and I found a solution. Turn your mp3 player off and place it face down on a hard surface. place down on the back of the mp3 where the function buttons are and press down firmly. I believe this unlocks the radio. Turn the mp3 player back on and go to the radio. The volume should work now.
Jan 05, 2009 | Audio Players & Recorders
Bluetooth headset
USING THE HEADSET
US USING THE HEADSET
1. Headset
2. Control Button
3. Light Indicator
4. Microphone
5. Earloop
6. Speaker
7. Charging Jack
A. Charging
Charge for at least 20 minutes before
first use. Complete charging in 2 hours.
Headset will not function when charging.
B. On/Off, Volume↑↓
Press the Control Button for 2 seconds
to power on. Press the Control Button
for 3 seconds to power off.
C. Pairing
Begin with Headset turned off.
Press button for 6 seconds. Release
button when Light Indicator flashes
blue/red. Headset is ready to pair with
Bluetooth device.
D. Pairing
Use your device’s menu to begin
pairing mode and select “320
Plantronics” on the display. When
asked for passkey, enter “0000.”
Jul 13, 2008 | Plantronics Explorer 320 Wireless Headset
74 people viewed this question
 Grubhead
Grubhead
