Question about Canon imageRUNNER C3200 Color Printer
I connected the network cable to the Canon C3200 to the ATT network Modem but i dont see it from my PC. Can you help
  • 1,219 Answers
You need to enable the network protocols or similar under user mode
Posted on Jan 14, 2010
Hook up an ASUS N13U Router to a Speedstream 4100 Modem - ATT DSL
Both the modem and the router should have an ethernet cable connection. The modem probably has only one, the router may have more than one. Look for the one on the router labeled WAN or INTERNET or MODEM connection. Connect the two with a standard 8 pin RJ-45 connector cable.
Then, ordinarily, just reboot each. Turn off the router, reboot the modem, the turn on the router. It should connect automatically.
Sep 21, 2013 | ASUS RT-N13U Wireless Router - 300 Mbps 1...
I have an at&t 2wire 2701hg-b but i dont have at&t internet i have charter and i am not able to figure out how to get my internet to work with this router please help
att 2 wire is a Adsl Modem (Requires a telephone line jack to get the signals) but charter communication is a cable internet service (not DSL) , Requires a TV cable service for internet .
These two jacks differs and there working differs ..
Means : Att works with the username and password type of authentication but charter requires the MAC address of modem for authentication .
Therefore for a cable internet 2wire 2701hg-b modem cant be used . But yes in case charters has username and password authentication and works with the telephone jack in house then its possible to use the same modem.
Aug 19, 2011 | 2wire (2701HG-B) Wireless Router
Wanting to connect pc to a Canon ImageRunner C3100. Anyone have any ideas on doing this?
hi first u have to vearfy that yours irc3100 have a network card if yes then you have to
1.download latest driver for irc3100 from canon ofical website.
2. you shud have a network cross cable to connect directly from your pc if you dont want conect directly you want to conect throug yours local network in that condation you can use normal network cable,
3. you have set IP address on yours irc3100.
4. just connect networ cable and install driver on pc.
thats it enjoy
thanks
May 13, 2010 | Canon imageRUNNER C3200 Copier
Setting up a small network using DSL and a DLink router
1.) The setup needs changing
2.) first off the dss-24 is a network switch not a router
3.) all of your pc equipment should be pluged into that device.
4.) chose one port as an uplink to your att modem
I think your problem is that the new modem is only giving out one ip address. So what ever first pc is turned on that is the one that grabs the address.
5.) you will most likly need a router to take the one ip address assigned via att then dole out additional ones. Remember the dss-24 is not a router. It simply connects everyone together. Each device still needs an ip address given from somewhere. Your old cable modem probibly did that but your new att dsl most likly does not.hence the new router will do that.....
to set it up do the following
2.) Find out the ip setup needed for your dsl service
A.) gateway ip
B.) primary & secondary dns server ip`s
C.) subnet mask
3.) get into the setup of your new router and then plugg in
all of these values using a fixed if address in the router
4.) connect routers wan port to one of the modems port. u may have to use a cross cable or straight look at the link lites to find out if they are talking to each other
5.) make sure that the routers lan side is setup for DHCP
6.) connect one lan port off the router to an uplink
of the dss-24. Then reboot everything
7.) viola it should all work internet on evey machine and file sharring.
Apr 27, 2010 | D-Link DES 1005D (DES-1005D) 5x10/100 Mbps...
Lost connectivity to network printer when switched to ATT u-Verse
Is the printer connected via wireless? When I recently connected up a new wireless printer to my UVerse network, the printer manual said that establishing the first connection works better via an Ethernet cable directly to the Uverse router. After the printer is set up once, then I could remove the ethernet cable and connect to the printer via wireless from all my computers.
For all wireless PCs that were previously connected via wireless to dsl, you need to create a new network connection for each one, then enter the key that is listed on the side of your Uverse router when prompted. Sometimes it takes a few minutes to establish the connection.
I am amazed that ATT was so unhelpful on these issues. I was one of their first Uverse customers in Texas, and several times over the last years, techs would visit my house to solve a problem or hook something up, explaining to me as he went. That their helpful attitude is deteriorating is a real shame.
Mar 11, 2009 | Computers & Internet
Laptop to access printer wireless
First, can your labtop see your other computer on the network. If it cannot see the other computer you will not be able to print from your laptop. I had a lot of troublel with this until I purchased a program called Network Magic from www.purenetworks.com. It was easy to install and made setting up my network and shared printers easy. It cost $30.00 and is worth every penny.
Jan 15, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
Canon Imagerunner color 3200 copier
you need to load the copier drivers into your server you can down load these drivers from canon website /or your network outlet is not setup
Dec 05, 2008 | Canon imageRUNNER C3200 Copier
Thnks
Hello!
don't worry, we will figure it out.. i'm pretty sure that you surely did the right thing. its probably the modem itself that is not cooperating here. if you dont see any dsl light on the modem that is because the modem is not yet setup.
nwy, since you already try setting it up using the installation cd, let's try to do check it manually instead
check your cable connection:
step 1: Power supply connected
Step 2: Phone cable to the DSL port of the modem to the DSL outlet
Step 3: Ethernet cable from the ethernet port of the modem to your pc
device configuration:
Step 1:open browser and type 192.168.1.254
Step 2: create your own password
Step 3: username admin and the password you created
Step 4: type your ISP user ID and password
Step 5: it should give your the confirmation that you are now connected
May 08, 2008 | Computers & Internet
2wire Wireless router not working w/Comcast cable modem
Its almost impossible to connect a 2wire DSL router with a Cable modem. They dont go hand in hand.
Although you can connect the outgoing ethernet wire from the modem in the last ethernet plug on the back of the router and then have the ethernet connections coming from the router. But not wireless. and if you find a way, contact me at jneal2k9@hotmail.com
Feb 03, 2008 | 2wire (1000-400108-001) Router
Canon imageRUNNER C3200 Color Printer Logo
94 people viewed this question
old marine
old marine
