Question about AEG Washing Machines
AEG LAVAMAT 10500 VI leaking at front. Is this the door seal/bellows? Water drips from bottom front of drum, I have removed inspection cover at front bottom of machine, and can see drip which appears to be coming down the front of the drum, then dripping from bottom of drum.Machine has been unused for 3 months, but did not leak prior to this. thanks PhilK
  • 159 Answers
SOURCE: Water Leakage Under Front Load Washer
most likley cause of your problem is the grey bellows has a tear in it. Inspect the bellows to check for tears. Or you can remove the lower panel and run the washer and look for the leak that way. Im sure it is a tear in the belows. Not a diffacult part to replace if you are mechanicly inclined. Good luck.
Posted on Jul 12, 2007
  • 11 Answers
SOURCE: Water leaking from bottom of door during wash cycle
I had a similar problem.  It turned out to be the overflow "sock".  It's a long plastic bag that hangs from the side of the tub.  You have to get the top open, and it will be on the left side.  Where it attaches to the tub, the plastic attachment has a rubber washer that gets flattened out after time allowing the attachment to get loose and leak.  Since I couldn't find the washer to replace it, I cut a piece of gasket material like you get from an auto parts place and placed it behind the foam washer.  This made the connection tight, and the leak stopped, thank God.
Posted on Oct 23, 2007
rizla
  • 1463 Answers
SOURCE: AEG Lavamat 1000
hi
dont know if this is the one you need AEG 1000 Washing Machine
you may need to scrool down to download the manual .
riz.
Posted on Mar 03, 2008
EngineerGR
  • 119 Answers
SOURCE: need the manual for Aeg oko lavamat 74630
Dear Biyo,
Please download the manual from here. (simply press left click)
http://www.manualshark.org/manualshark/files/5/pdf_10516.pdf
I have sent you an email as well.
Regards,
EngineerGR
Posted on Apr 09, 2008
  • 110 Answers
SOURCE: Amana Distinction leaks
this is a very common probelm with AM washer you have a bad upper sping bearing and at this point you need to cut your loses and send this one to the washer graveyard because this repair in labor intense
Posted on Jun 01, 2008
How To reset EFO code
Hi. EF0 is suggesting an internal leak which operates a float switch inside the cabinet at the base. It could be a leak (split door seal, hose, etc) or over-foaming causing a momentary leak. Dry the base and inspect. A blocked condenser on the dryer can cause the drum to overfill on wash. I have also witnessed the code come up when the drain pump is jammed..odd as this should be E20. If it drains ok ignore that!.
May 25, 2014 | AEG Lavamat 16810 Front Load Washer/Dryer
My 72640 AEG washing machine continually leaks even though the filter cap is tightly in place. What could be the problem please? Kate Comins
you have a hole in the rubber boot seal and need to change it,also i've seen a buildup of detergent and hair stuck on the bottom side of the front door,when the door is closed the water was traveling down the pieces of hair and leaking through the bottom of the door,but if it's leaking under where the pump is and it's not the pump or hoses it's the boot seal.open the door and pull open the boot seal and run your fingers all around until you find the hole
Jan 23, 2011 | AEG Lavamat 72640 Front Load Washer
How do i re set an EFO code on an AEG LAVAMAT
you just need to mop up the water inside the cabinet to allow the float switch in the base to reset.check there is nothing stopping the float returning to the floor. a small leak from the door seal can cause enough of a leak to trip it . clean the door glass and seal to stop this. or change the door seal.
Jul 17, 2010 | AEG Lavamat 74640 Front Load Washer
My washer leeks from the bottom, slow drips,when in progress. Can I fix this myself
If you have a leaking FRONT LOADER, you will need to remove the lower toe panel under the door and inspect the washer interior cabinet to sufficiently determine where the source of the leak may be coming from. The following link explains how to access and inspect your washer for leaks:
http://www.fixya.com/support/r3576656-washer_leak__front_loader
In the majority of the cases with front loaders, the door bellow begins to leak. A routine inspection of the seal perimeter will tell you if there are any rips or tears. If the bellow is damaged, it must be replaced. The following link explains how:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
Make sure you throughly check all drain hoses, hose connections, the pump seal and the dispenser hose(s) that penetrate the door bellow.
These problems can easily be repaired without the assistance of a repairman. If you have any questions, please post back and let me know. I hope this helps you.
Apr 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
About mid cycle, a significant amount of water leaks out of the bottom. No error message comes up and the machine continues functioning. Machine is AEG oko lavamat 72640
Could the machine be overfilling due to a faulty pressure switch (controls the amount of water in the drum). Splits in the door seal or broken pipes?
Jan 25, 2010 | AEG Lavamat 72640 Front Load Washer
I have taken out the big bellow (at the main drum) to clean it, but can' get it back. Any advice?
You need to remove the front cover, and first install the rear part of the bellow, after that install the front cover, and then get the front ring of the bellow into the door, you might need some tools to accomodate the clamps
Jan 06, 2010 | AEG Lavamat 72640 Front Load Washer
Whirlpool duet washer leaking water
If the washer is leaking around the door area, more than likely the bellow (rubber seal) is ripped or torn. If you pull back the rubber folds in the bellow and inspect, you may find a rip or tear causing your leak.
Another cause can be the rear bellow clamp (clamp that is affixed to the front of the wash tub) can come loose causing a leak between the bellow and tub. All you may have to do is tighten the clamp if this is the case.
The dispenser tube on the left hand side of the door, if not seated through the rubber correctly, can also leak during the fill or rinse cycles. The tube should be inserted through the rubber in the bellow to the flange on the tube. If not, water can fill behind the rubber and drip into the bottom washer casing.
The following link explains how to access and/or replace the the door bellow on a Whirpool Duet:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
Searspartsdirect.com, appliancepartspros.com, pcappliancerepair.com and repairclinic.com carry the bellow. All these sites offer competitive pricing, so shop all of them for the best deal.
If you have any questions, or require addtional assistance, please let me know. I hope this helps you. NOTE: The bellow can also become mishapened over time after frequent use. This can also cause leaks around the door. Look to make sure the bellow is sealing around the door glass. If not, it should also be repalced.
Jul 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Leak
It sounds like you have a leak somewhere around the door bellow. This is the rubber boot that seals the wash tub to the door frame. Pull the folds back and inspect around the entire perimeter of the rubber. You could have a small rip or tear somewhere. There are a series of small holes in the bottom of the bellow that are supposed to be there. This is the allow any standing water to drain back into the wash tub. If you cannot find any obvious signs of leaks, remove the lower panel under the door. This is accomplished by removing the screws under the bottom edge of the panel. With the screws removed, the panel will drop down, then off. Start the washer on a normal wash and watch for any leaks. If the door bellow leaks, the front counterweight (usually a concrete block) will begin to get wet and drip. This could also be an indication of the bellow clamp around the wash tub being loose. If the leak starts to pool under the washer and run out the front, this is usually an indication of a drain pump leak or drain line leak. Please inspect the washer with the panel removed and the washer on a load and post back and let me know. Go to my profile and use the "Ask Me" feature for a quicker response. I hope this helps you.
PS One other item. On the left hand side of the door bellow is the a dispenser tube that penetrates through the bellow and allows water to enter the wash tub. Sometimes the dispenser tube is not seated all the way into the rubber (should be seated past the flange) and it will dispense water behind the rubber instead of into the wash tub. Just something else to consider...
Jun 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Nov 20, 2006 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
61 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
