Question about Magic Chef Microwave Ovens
Countertop microwave shows "8888" and won't reset or function. Unplugged, plugged, etc. commands fail...
  • rpierce123 Nov 13, 2009
    Thanks...
    It's what I suspected...and now I'm heading to Walmart for a different model....
    Damn....
    Top Expert:
  • Magic Chef Master
  • 79,186 Answers
Since you didn't provide make or model number here is the most common problem, the circuit board behind the touch controls is defective, the touch control pad and the circuit board is all sold as one piece, it is expensive, on average around $160 US.
Posted on Nov 12, 2009
One day the microwave just showed PF on the screen, unplugged and plugged in tried to use it, worked for 30 seconds, stopped and showed PF again. Any ideas? It is only a few years old and used in our...
PF is Power Failure. Check and see if the Oven has a reset switch or power button. Try and hook up an extension cord, plug one end into a usable output (wall plate) and the other into the 110VA line plug attached to the Oven. Turn on....if it works then the problem is a circuit breaker or wall interface. If it fails with the extension, then it is an electrical problem with the microwave device itself. If there are no Reset features on the oven, an internal fuse may blow, or other shorts are occurring. The cost to fix is more than a new unit. Lowes has them as low as $150.00.
Dec 18, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave keeps running with door open
I'd say the door interlock switch has failed, and supplies a connection when it should not. Microwave ovens can be dangerous to anyone poking around inside, even when unplugged, so get a quote from a service tech. You might find that parts+labour is almost as much as a new one.
Microwave radiation being released through an open door is also a hazard, as it is known to cause eye cataracts, so don't get near if the oven does this.
Nov 19, 2013 | Panasonic Inverter Countertop Microwave
How do you stop, reset or change the remaining time on the Timer on the GE JES1142 microwave? Pressing Clear/Off does nothing. Do you just have to wait for the timer to run out? Manuel is wrong even on how...
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
Oct 27, 2013 | GE JES1142SPSS 1.1 cu. ft. Countertop...
Sharp microwave 8888 is flashing and I cannot remove
see this steps and fix it. God bless you
Reset the clock. Press "Clock" and the correct time, using the number pads. Press "AM/PM" if applicable, and press "Start" or "Clock" to confirm.
  • 2 Press "Timer On/Off" to reset the timer if nothing on the touch pad will operate. Use the number pads to select a new timed amount, if desired, and press "Timer On/Off" to start. Press again to cancel.
  • 3 Press and hold "Clear/Off" for three seconds if the timer will not function or is blinking when you touch the pads. This will release the "Child Lock" feature. Make a new touch pad selection.
  • 4 Disconnect power to the microwave if following Steps 1 through 3 does not resolve the blinking timer. Wait a few minutes, and then restore power to reset the microwave.
  • However if the problem persist the display board
    main control board is faulty
    Oct 02, 2012 | Sharp Microwave Ovens
    Microwave display flashing & beeping.
    You have a failed membrane keypad.
    On this model, GE doesn't make any parts available except the tray and the roller.
    If it's in warranty, they will exchange or repair it.
    It it's out of warranty, you're out of luck.
    I'd advise you to contact GE Customer Service in case they may be able to help you.
    Jul 25, 2010 | GE JES1036PWF 1100 Watts Microwave Oven
    Nothing on my touch pad works
    My microwave way manafacture May 2008. Nothing on the touch pad works.???. It just abrubtly stopped
    after a few seconds.
    We brought it in July or August
    Debbie
    Mar 27, 2009 | Maytag MMV1153A Microwave Oven
    Display only shows 8888 - display buttons do not work.
    try a reset. unplug for 10 mins, plug it back, see if it will work.
    if not , open the housing, see a ribbon cable from the touch pad to the main pc board. remove the ribbon cable for 1 min. re install it back and test the unit.
    be sure to return all cover and screws of the unit before plugging it back. microwaves are hazardous to your health.
    tnx 4 using fixya,
    drcool
    Oct 05, 2008 | Sharp Microwave Ovens
    Microwave Sharp carousel Model R3A36 keypad not working. We had a brown out due to a recent storm and the microwave keypad didn't work anymore after that. We unplugged and replugged and the light inside is...
    Your keypad has failed.
    It would need a new control panel frame, which comes with the keypad.
    You simply remove the circuit board and plug it into the new frame.
    It is part # FPNLCB070WRK0 and the best place to order Sharp parts is Tritronics.
    Sep 03, 2008 | Sharp Microwave Ovens
    Panasonic NN-T994SF 1250 watt countertop microwave stopping
    From my research, this sounds like a fairly new model. Consult your user's manual to see if this is a user, or common issue. If nothing is descibed then I would seek possible warranty service, or dealer replacement
    Jun 03, 2008 | Panasonic NN-T994SF Microwave Oven
    Microwave Ovens Logo
    96 people viewed this question
    Top Magic Chef Microwave Ovens Experts
    William Miller
    William Miller
    Oloyede Monsuru
    Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
