Question about Creative Labs ZEN Vision:M Digital Media Player
FM Radio Feature Completely Disappeared!
The FM Radio on my CZV:M is completely gone. It's not listed on the main menu (it's not listed on the configure menu list), and I can't get to it from anywhere else. It's like it was never there. I've tried everything--reloading/updating the firmware, reformatting it, disk cleanup... everything on the Recovery Menu, i've tried. This by far not an uncommon problem; a quick search on the Creative Forums shows that many other owners have the same problem, but no one has been able to fix it. What else can I try?
  • 4,402 Answers
Re: FM Radio Feature Completely Disappeared!
Yes this is a common problem with no soultion. could try taking it apart and reseting all the connectors inside see if that works?
Posted on Jan 14, 2008
0 characters
3 Points
I have an ipod classic 160gb and i go under settings/main menu and i have radio checked isnt it supposed too??
Do you mean that you don't have access to the radio because you need the optional radio piece which connects to the bottom of the device if you wish to use the radio. You can either purchase the radio device or go without radio.
Mar 01, 2011 | Apple iPod classic MP3 Player
How come i cant find the radio for my Phillips go gear vibe?
From the main menu, select the icon that looks like a little radio
To search for the next stronger signal, press and hold the up or down arrow
To fine tune the frequency, briefly press the up or down arrow
From the main menu, select to enter
radio mode.
• The earphones cable acts as FM
Manually tune a radio station
While in mode, you can manually tune to a
radio station:
1 To search for the next stronger signal,
press and hold / .
2 To fine tune the frequency, briefly press
Auto-tune preset radio
The auto-tune feature of GoGear Vibe helps
you find radio stations and save them under the
preset numbers.
1 While in mode, select [Auto tune] >
»» The radio automatically tunes radio
stations and saves the frequencies to
»» There are 20 presets available.
»» To stop auto tuning, press .
»» To exit radio, press and hold for 2
Jan 09, 2011 | Philips GoGear ViBE Digital Media Player
The Nano icon with the eject icon is now missing from my computer site so when I want to disconnect the Ipod after recharging, there is no way to do it unless I turn off the computer completely. Very...
With the ipod connected, you will need to go to "device manager" . There will be a list of all devices on your computer there. Your Ipod will be listed there. Right click on it and click uninstall , confirm that choice if it asks you to. Unplug the ipod then restart the computer. When you next plug in your ipod the computer should see it. To find the device manager on your computer click help on the start menu and Type device manager on the search option. This applies to windows systems only.
Jan 08, 2011 | Apple iPod nano
I can't access the main menu. When I power up it is stuck on the FM radio mode.
Having gone over a month without a reply to my query, I assume the suggested reset solved the problem.
Sep 08, 2010 | SanDisk Sansa E280 MP3 Player
Creative Zen Micro suddenly won't display FM Radio on the main menu. Help please.
The main menu is customizable. You may need to simply add the Radio menu selection back into the main menu.
In the Main Menu select
System --> Display Settings --> Configure Menu
and pick the menus you want to display.
Jul 21, 2009 | Creative Labs Zen Micro MP3 Player
Fm-Radio problem
that model does not support radio.
Jun 21, 2009 | MP3 & Digital Media Players
FM Radio was erased from the MP 3
OK this seems to easy a fix for you, but try it.
* In the main menu where it lists your options (and where FM Radio would be) press the 'Menu' button on your Microphoto (bottom right button) and there is an option to 'Configure Menu' and in there should be the option to show FM Radio again. Hope that helps you.
I have a similar, but different problem, so ill list below, maybe it will help someone out.
i also replaced the (broken) 8gb microdrive with 8gb compact flash in my Zen Microphoto, which worked flawlessly! BTW i bought the A-Data 'SPEEDY CF 8GB' from
My FM Radio still shows up, but only gets MONO sound on the Right channel, its very frustrating. i took it all apart again and made sure no connections were loose or broken, but everything seems perfect. i believe it to be a firmware issue, i think ill try to roll back the drivers. im using firmware 1.31.01.
its just annoying to have to roll back to Media Player 10 everytime just to install the firmware and have windows properly communicate with the zen... :[
Nov 20, 2008 | Creative Labs Zen MicroPhoto MP3 Player
FM Radio
iPods do not come with FM tuners. FM tuners can be bought and added on as an extra feature, but this is a third party device, not an iPod device.
Generally, when you connect the third party FM tuner to the iPod, the iPod will recognize it and you can use the 3rd party FM tuner to change stations.
If you do not have the FM tuner to connect to the iPod, the individual that sold you the iPod did not include the FM tuner to connect to the the iPod. In that case, the Menu will still list the FM tuner, but there is no device to connect to the iPod.
Sep 09, 2008 | Apple iPod MA446LL/A MP3 Player
No radio in menu. only music. voice .settings .
The service may not be available in your area. Make sure the headphones are connected to the player when searching for radio stations: Here's pg 15 of the user manual:
FM Radio (if applicable)
The Sansa
player includes an integrated FM radio for listening to live broadcast FM
stations. Please note that the FM Radio function may not be available in your region.
Listening to FM Radio
To listen to live broadcast FM station, follow these steps:
1. Select FM Radio from the Main Menu.
2. A radio frequency menu will appear.
3. Press |<< or >>| to adjust and search for the desired frequency, or select
preset by pressing Select.
4. For fast search, press and hold the |<< or >>| buttons.
Feb 20, 2008 | SanDisk Sansa Clip MP3 Player
Creative Labs ZEN Vision:M Digital Media Player Logo
76 people viewed this question
Top Creative Labs MP3 & Digital Media Players Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
Are you a Creative Labs MP3 and Digital Media Player Expert? Answer questions, earn points and help others
