Question about Whirlpool RBS275PD Electric Single Oven
After preheat temperature is not able to increase.
After preheat oven temperature cannot be increased. Attempting to increase or decrease temperature only results in a decrease.
  • rchrist Nov 12, 2009
    Where is the sensor located?
  • rchrist Nov 13, 2009
    I removed the sensor. Measured 500 ohms. Am now waiting for part to arrive.
    Thanks!
  • 6,784 Answers
HI, this is a sensor issue. You will need to check the oven sensor wires that link the actual sensor to the main control board. Make sure that the contacts are connected properly, and not loose, or corroded. If all the wiring checks out, test the sensor for the correct resistance readings.(you will need a multimeter for this test)
The most common oven sensor should be approximately, 1100 ohms when at room temperature. The others may be close to as follows:
100°F - 1143 ohms
200°F - 1350 ohms
300°F - 1553 ohms
350°F - 1654 ohms
400°F - 1753 ohms
500°F - 1949 ohms
If the sensor test is adequate, and the wiring is Ok at the control, this will lead to a failed control board. replace the control in this case.
Posted on Nov 12, 2009
  • Michael Masters
    Michael Masters Nov 13, 2009
    Ok, the sensor is housed inside of the oven. It is mounted inside, on the back wall region. In the upper right or left hand side. You will notice a probe, when looking inside your oven. It is about 4 to 5 inches long. this is where the sensor is housed. You will need to unscrew the two screws that hold the housing, to access. Most newer models will need to be removed from the cabinet, in order to test the connections from the back side of the unit. Older models will allow you to access the sensor from inside the oven.
Can not raise temperature above 350
500 degrees farenheit is 260 degrees celcius (metric)
any chance the display is set for metric ?
Jun 28, 2012 | Whirlpool RBS305PDS Electric Single Oven
Oven preheats but will not maintain heat
Hi you have a bad thermostat for the oven , I would guess that everything else is working ok on this unit correct ? if you send information i will look up the part for you this is easy to replace , as always turn the power off before service or unplug
Nov 25, 2011 | Maytag Ovens
I can not control the oven temperature. When I turn on the oven the temperature keeps increase the food will burned.
You need to replace the thermostat for the oven. This consists of the switch on the panel and a long capillary tube and a small bulb. Remember to switch off the oven wall switch or the mains if you are attempting the job yourself.
Jan 23, 2011 | Ovens
Not the right temp in the oven 100 degrees off
I have a kenmore gas range with digital display that will let me increase the temperature up to 35 degrees f*. It says to press BAKE for 6 sec., then use the number pad to increase or decrease then press START.
Hope this helps
Don
Jan 05, 2010 | GE Ovens
My oven has increased only 65 degrees in almost an hour....what does it mean when it heats up, but SLOWLEY??
The broiler element on the top of the oven comes on during the preheat cycle to speed things up and then only the lower element keeps the temperature steady. One of those elements is bad, probably the broiler. Try using the broiler and see if it works. If not, you need to disconnect the elements from the oven and check them with an ohm meter. If gthe elements check out ok, then it must be the temperature sensor/thermostat.
Jun 25, 2009 | Frigidaire FEB27S5A Electric Single Oven
Oven cooks at 400 plus degrees when set at 350 degrees
If your problem is temperature do this;
Press "options" Then press "6". Then press "3" to increase or "6" to decrease temp.
Then press "start" to end the calibration.
If you recently used self-cleaning you could have a thermal overload fuse problem.
Feb 23, 2009 | Whirlpool SB160PEE Gas Single Oven
Oven temperature only gets to within 20-25 degrees of temp. set
next to last page in your manual
Adjusting Oven Temperature
Oven temperature has been factory calibrated and tested. If
oven consistently over or under cooks food, adjust thermostat.
Oven temperature can be increased or decreased 35°F. To
avoid over adjusting oven, move temperature 5°F each time.
1. Push BAKE pad.
2. Press + pad until an oven temperature greater than 500°F
shows in display.
3. Immediately push and hold, approximately 5 seconds,
BAKE button until “00” appears.
4. Press + or - arrow pad to adjust oven temperature.
• To increase oven temperature (for a hotter oven), Press
pad until a positive number appears in display.
• To decrease oven temperature (for a cooler oven),
Press pad until a negative number appears in display.
5. Press OVEN CANCEL pad to save adjustment.
• Setting is saved if power fails or is disconnected.
heres a link to the entire manual if needed
http://shop.amana.com/assets/pdfs/literature/32103601.PDF
Nov 27, 2008 | Amana AOCS3040SS Electric Single Oven
Whirlpool RBS275PD Electric Single Oven Logo
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
