Question about Ovens
GE Profile 2002 Wall oven JCKP18BA2BB Code faults
My 2002 GE electric profile wall oven shows a F 0 code on the touch pad. I have turned power off for days, taken off ribbon - cleaned ends, re-set and initially I got a F 7 but now after a week of sitting and powering up it beeps non-stop after a few mins and shows a F 0 code. The clock button is difficult to operate as are some of the other touch pads. The oven will bake/convection for a few minutes then the oven shuts off by itself. Wait 2-4 mins and F 0 displays again. My repairman states it is an ERC or complete touch panel. Each costing $330 and $320. I'm trying to determine what part it needs, if both scrap a 6 yr old oven and start again....Help !!! thx.
  • Anonymous Jun 08, 2008
    we are having a touch pad problem too. It beeps randomly and shuts on and off at will. What do we do
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 68 Answers
Try my solution for the F7 problem at the following link:
http://www.applianceblog.com/manuals/Dreaded_F7_Problem.pdf
I have shared this with over 1500 folks and most report success.
Please let me know. Also, what is your model number, how old is your oven and where are you located? I am making a study of this problem. You can email me at: hutchipop@yahoo.com
Posted on Jan 08, 2008
What is a fo code on ge doulble wall oven
It is more than likely the touch pad is bad. It could be the electronic control or worst case both. Touch pads are notorious for giong bad. i would look there irst.
Oct 07, 2014 | GE Profile JTP56 Electric Double Oven
Error code FO
F0 Stuck touch pad Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both.
Oct 17, 2010 | GE Profile JTP18 Electric Single Oven
Error code - F0
Sep 14, 2010 | GE Profile JTP56 Electric Double Oven
On a GE Profile Performance oven the code F7 show up on the key pad and the oven Beeps. Hitting the end or stop button stops the beepimg for about 5 minutes. Turning the power off achieves the same...
Hello there
The code can be caused by a faulty keypad or a Stuck keypad which may mean relay is turned on. Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel. :
furtrhermore
Jul 21, 2010 | GE Profile JTP56 Electric Double Oven
Touch pad for the oven does not work
eith touch pad or control board un plug the touch pad if it returns the board is bad if it dont the touch pad is
May 27, 2010 | GE Profile JTP56 Electric Double Oven
The upper and lower oven will not turn on there is power to it and clock and oven lights work there is an FO red light that comes on and beeps and flashes
Built In Oven Fault Codes
F0 or F1 - Failed transistor in control - If code cannot be cancelled, replace the Electronic Range Control (ERC) or touch pad
Sep 21, 2009 | GE Profile JTP56 Electric Double Oven
Ge profile wall oven - f7 but I fix with eraser trick - now the clock can't be reset and the 4 does not always work on the keypad
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Aug 28, 2009 | GE Profile Advantium 30" Built-In Single...
Just received a used GE profile electric convection oven. Plugged it in and I'm getting a F1 error code
HI. this "F-1" code Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be canceled, replace the oven control (also called clock or ERC), touch pad, or both.
Aug 08, 2009 | Ovens
Ge Profile built-in 27 inch wall oven -- When I
f9 means your control panel needs to be replaced..chances are part is not covered and if it is the only way you can obtain it is through having service
Jun 18, 2009 | GE Profile JT912 Electric Single Oven
Ovens Logo
329 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
