Connection problem
How do you connect AVR 870 to TV since it does not have Scarf socket.
3 Suggested Answers
GodBlessU
  • 3513 Answers
SOURCE: denon avr-790 sirius antenna antenna connection
The connection is similar to what is mentioned in the user manual bellow. Slightly different model but the connections are universally similar:
http://www.rotel.com/content/manuals_archived/rb850.pdf
Thank You
Posted on Oct 31, 2010
  • 11800 Answers
SOURCE: I have a Denon AVR
The optical audio connection (the TOSLINK) only works when paired with the Component connectors. Now you are using the the Composite one so you must use the audio connectors associated with it, the red and white next to it; then select the VCR1 input when you want to use them.
The audio quality will suffer a little but it will most surely pass unnoticed in most of the cases.
Posted on Aug 15, 2011
Connecting
did you check this out yet? (from the owners manual)
IMPORTANT NOTE: If the AVR's video output resolution
is set higher than the capabilities of the actual connection,
you will not see a picture. If the best available video connection
from the AVR to the TV is composite video, press this button
and change the resolution to 480i.
Oct 06, 2012 | Harman Kardon AVR 3600
I have a Denon AVR 888, I want to use the reciever for my audio coming from my TV, I have plugged in a HDMI into the in port and connected it to my TV, I do not get any audio from the reciever
HI,
If you want to get the audio of tv program through the AVR then your tv should have a HDMI out port. Because you have connected the cable directly to tv. You didnt mentioned anything about your tv (make and model number). So its not possible to give you a final answer.
Check on thing isthere ia nsy RCA audio output in your tv. All tvs will have RCA audio out put. Wich you can connct to the TV /CBL in put of your AVR using a RCA cable. Then select the TV/CBL Using the SOURCE SELECTOR on the frond of the AVR.
Another Way is if there is optical out put on your tv then you can connect the optical out to the AVR's OPTICAL IN 1 or 2 Using an optical cable. Then you have to got to the input assignment menu of
the AVR and then you have to assign the optical 1 or optical 2 to wich you have made the connection. Here i have added the link to the user manual of the AVR. Check the page number 22. Which shows the menu tree. To assign the optical input for TV/CBL you have to go to the Input set-up there you will find the ASSIGN on the under CD,AUX etc menu.
This setup required if you use OPTICAL input of the AVR. Check the page number 14 for the connection diagram.
IF you are going to use RCA cable the simply connect one end of the rca to TV's AUDIO OUT and other end to the TV/CBL input of the AVR. And then select TV/CBL.
Here i have added the picture of RCA cable that you nee for making such connection between TV and AVR.
USER MANUAL
Ajin
Apr 26, 2012 | Audio Players & Recorders
How to connect and set up my DENON AVR-3300 to my LG tv. Waht connections on amp and tv do I use?
  • if you want to listen your TV on your Stereo system thru your receiver, AVR-3300 ** you need to connect "Audio Output " RCA jacks or "Optic cable output" of your TV
** to "AUX input " or "TV" OR "Any input" of your receiver ( except Phone ) or "Optic Cable input"
** than just switch to respective mode on
AVR-3300 RECEIVER corresponding your RCA or Optic connection...
There you go..Your TV sound is on the
AVR-3300
Receiver..By this means whatever you watch on the TV (tuner, satellite , Xbox ) ,it's sound will come thru your stereo..
  • Hope this helps!
Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :)
Mar 28, 2011 | Denon AVR-3300 Receiver
I have a new Panosonic Viera TC-P54VT25. Everything seems to work well except for the sound on the Viera Cast. Viera Cast is connected through a hard wire ethernet connection directly into the TV. ...
I have had my Panasonic Plasma tv for 5 months there was a loud pop and the tv went off and now there is a red light blinking 10 times and the tv will not turn on.
Jun 15, 2010 | Panasonic Viera TH-50PZ80U Plasma TV
PC Sound Card Connection to Denon AVR-2805 or Samsung 40B610
  • Should I be connecting my pc sound card directly to the receiver or to the tv then to my receiver to get the best sound output? To your reciver
  • When I get the HD Digital Tuner, does that make any difference for the pc connection?
  • Try to connect everything that is sound onto your reciver then
  • connect all your video to your your TV for now
  • When you get your digital tuner connect all your inputs for video to(in order >reciever>HD Tuner>TV
  • Basicly everything goes to your tuner first.
Jan 16, 2010 | Denon AVR-2805 Receiver
Hi denon to cable box to samsung lcd
Unless you are having res. issues you can use component / optical / coaxial cables to connect all your devices to your denon and from your denon to your tv using component cables also
Feb 25, 2009 | Denon AVR-5803 Receiver
My new Harman/Kardon AVR 154 has no sound and the blinking light cannot be fixed because I cannot get the OSD blue menu to come up on the TV screen from the remote.
Do you have your receiver output connected to the input on your TV? For example, if the receiver is in connection number 1, is your TV set to connection 1?
Dec 29, 2008 | Harman Kardon AVR 235 Receiver
I have a Denon AVR-3808ci. I am having problems hooking up my nintendo 64 to this unit. I am trying to use the 3 line cable which has left/right audio (respectively red/white) and audio (yellow). I have it...
If your amp is not upcoverting the picture you will have to come from the yellow monitor out on the amp to in on the tv,if you have no input on tv use a scart to phono convertor pluged into the scart socket.
hope this helps.
CABLE GUY.
Jun 30, 2008 | Denon AVR 3808Ci Receiver
Set up
You don't need to fake it with a VCR - on the back left side near the bottom there is a Monitor section with an RCA connection and an S-Video connection. Connect one of these to an input connection on your tv and switch your tv to show that input. Select the AMP setting of your remote and press Setup.
Mar 01, 2008 | Denon AVR-3802 Receiver
Denon Avr 2803
Could be bad connection. Try to tight connection cables on receiver and TV.
Oct 15, 2007 | Denon AVR-2803 Receiver
13 people viewed this question
 Grubhead
Grubhead
