Question about Cell Phones
How to unlock the keypad?
How can I unlock the keypad to this phone?
How do you unlock the key pad on a Nokia phone
Hello
To unlock your keypad press the top left key on your keypad and the star (*) key on your keypad, this unlocks the keypad...
Apr 11, 2011 | Nokia 6085 Cellular Phone
Can not unlock keypad phone is frozen and dosen't respond to unlock keypad Also I can not turn the phone off.
  1. 1ST OF ALL FLASH THE PHONE
  2. IF THE PROBLEM STILL OCCURS
  3. YOU WILL HAVE TO CHANGE THE KEYPAD I.C
Jan 25, 2011 | Nokia 6301 Cellular Phone
How to unlock nokia 2700c
Keypad lock
To prevent accidental key presses, select Menu, and press * within 3.5 seconds to lock
the keypad.
To unlock the keypad, select Unlock, and press * within 1.5 seconds. If
the security keyguard is on, enter the security code when requested.
To set the keypad to lock automatically after a preset time when the
phone is in the standby mode, select Menu > Settings > Phone >
Automatic keyguard > On.
To answer a call when the keypad is locked, press the call key. When you end or reject
the call, the keypad locks automatically.
When the device or keypad is locked, calls may be possible to the official emergency
number programmed into your device.
Jun 05, 2010 | Cell Phones
I have a nokia 6500s-1 slide phone and my 3 yr old daughter pressed something while she had it, and now i'm locked out of the phone, tried all I can to no avail. Can't give you an IMEI number as the phone...
It seems that the keypad is locked. Does your poweron? If yes then press the poweron switch and you will find an option LOCK KEYPAD or UNLOCK KEYPAD. If it is the earlier then your keypad is free. If the later then select Unlock option and free up your keypad. If former then your there is no way that you can unlock your phone except re-installing the firmware. The IMEI number is below the battery. But, it will not help despite everyone asking for a SW generated password. get the firmware re-installed. It takes about half an hour.
Aug 12, 2009 | Cell Phones
Forgot my keypad unlock code
i have a sprint pocket pc-6700 i forgot my keypad password how can i unlock
Apr 11, 2009 | RIM BlackBerry Pearl 8100
How do I lock the keypad?
You can manually lock the keypad to avoid pressing keys by accident. You can still answer an incoming call and the keypad will lock again when the call is finished. The keypad remains locked until you unlock it manually.
Depending on your phone model, you can activate the automatic keylock. When the automatic keylock is activated, the keypad locks shortly after you stop pressing keys.
Please note: with some phones you can still use external keys when the keypad is locked. If you wish to lock the external keys you must lock them separately.
K530i To manually lock the keypad:
  1. From standby, press the * key.
  2. Select 'Lock keys'.
To activate automatic keylock:
  1. From standby, select 'Menu' > Settings.
  2. In the General (tab), select Security.
  3. Select Automatic keylock > On.
To unlock the keypad:
  2. Select 'Unlock'.
Mar 31, 2009 | Sony Ericsson K530i Cellular Phone
How to lock and unlock keypad Motorola VE240
To Lock your phone
Hold down the # symbol on your phone until it says: "Phone Keypad is now Locked"
To Unlock your phone
The screen should now read in the bottom right hand corner "Unlock". press the corresponding key. It then asks "Unlock Keypad?" "Yes" or "No". Select Yes and press Menu button (also the play/pause button).
Hope this helps you all!
Jan 02, 2009 | Cell Phones
Locked cell phone keypad
first, take out the battery and press the RED end call key for 15 seconds, then put the battery back in and turn on the phone.
if that doesn't work then try this from the website.
How do I lock/unlock the phone's keypad? To lock and unlock your phone's keypad, press and hold the left navigation key.
Or, select Menu -> Settings -> Keyguard. Then highlight either of the options and press the OK button. You can set your phone to lock the keypad immediately, or automatically if no key is pressed after 30 seconds, 1 minute, or 5 minutes.
To unlock the keypad: Press 1-2-3 in that order."
good luck!
Apr 15, 2008 | Kyocera K10 Royale Cellular Phone
Keypad on ke970 shine
there is some problem with the keypad for this u need to contact LG care center.
Oct 18, 2007 | LG Shine KE970 Cellular Phone
Ke970
  • do keypad settings:
  • go to main menu<settings<security settings<select keypad settings< here u wil get the option for locking or unlocking keypad
 otherwise there might be  some problem with the keypad for this u need to contact LG care center.
Oct 17, 2007 | LG Shine KE970 Cellular Phone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
