Question about Kenmore Washing Machines
My Kenmore washer motor runs but it will not spin.
  • oldguy5 May 11, 2010
    Can you provide the exact Make, Model and Kenmore model number? Kenmore model numbers use the format ###.######## with the first three digits of 110 for Whirlpool manufactured machines. If this is a basic top load, direct drive washer, the first places to look are the Motor Coupler and / or lid switch. See the Sears parts site for your model. http://www.searspartsdirect.com/partsdir... Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
  • 464 Answers
You need to replace the direct drive coupling which is on the shaft of the motor. not hard to do and not expensive.
Posted on Nov 13, 2009
My Kenmore Washer does not spin during the spin cycle. Is it fixable?
It depends. If the motor is running, it is usually just the motor coupler. If the motor does not run, then suspect the lid switch.
Feb 24, 2010 | Kenmore Washing Machines
Kenmore Series 80 washer NO High Speed Spin
It could be a timer, motor or wiring problem. You would need to check for 110 volts at the timer or motor when in the higher spin mode. If you are getting 110v you have a bad motor. No or low volts you have a bad timer. The motor is either a 2 or 3 speed motor and you would have to determine which winding to check for the 110v. The schematic is usually glued to the inside rear cabinet. Please rate this post.
Dec 14, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washer motor runs. washer drains. washer still
The spin-tube assembly needs to be replaced.
This is one of those jobs to call-in the repair professional for.
Sep 07, 2009 | Kenmore Washing Machines
Kenmore top loader washer - No spin - motor rattles - wtr pmp ok
Bad/broken coupler/ http://www.davesrepair.com/DIYhelp/DIY285753.htm
Sep 01, 2009 | Kenmore Washing Machines
Kenmore washer 80 series misses spin during wash.
You may need to replace the motor coupling between the pump and motor...
Apr 07, 2009 | Kenmore Washing Machines
Kenmore washer not spinning ans washing
Does it sound like the motor is running at all ?( if motor is running u need a coupler) (with machine off turn cycle switch around 3x roughly, then try machine) With the machine off do you hear a clicking noise if you open and close the lid?
Mar 25, 2009 | Kenmore 24032\24036 Top Load Washer
Motor clicking sound from kenmore washer
You most likely have a bad drive coupling between the motor and gearcase.
Set the machine on a spin cycle and turn it on.
If the motor is running and the washer is not spinning, bad drive coupling.
Feb 25, 2009 | Kenmore Washing Machines
Kenmore washer won't spin
ok " sounds like motor belts need replaceing, that smell is the loose belt rubbing against the motor pully.
Jan 01, 2008 | Kenmore 12502 Top Load Washer
Washing Machines Logo
23 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
