Question about Microwave Ovens
We have just moved house, and every time I switch the Maytag fridge on, it blows the main fuse. I left it for a day before I switched it on. It's a big side by side with water chiller, well ventilated at the back but not a lot of space on either side. Should I call in a technician? Many thanks.
  • chelkell Nov 12, 2009
    Thanks for your feed back. We've now had the fridge off for 24 hours, and once again, we can switch it on (the light in the fridge goes on and the compressor starts up) but within seconds the fuse blows again. Do you think it could be because the space around the fridge is too small or wouldn't that have any bearing on the problem?
  • chelkell Nov 13, 2009
    Thank you, you've been a big help!
    President:
  • 2,187 Answers
Normally when moving around you need to have the unit unplugged and standing for 8 hours. But I do not think that would cause the fuse to blow. I would advise that you call a technician especially if you do not have any experience in electrical equipments. As for the cause, should you wish to troubleshoot the device yourself, is to check for loose wires or loose connections. Most likely that the issue is on the wiring at the back of the around the compressor. Check the wires to and from the compressor and into the box. Inside the box are relays. Check for the same items and burnt parts.
Posted on Nov 12, 2009
  • Nicolo Carlo Parazo Nov 12, 2009
    I do not think that the space is an issue unless the compressor has weakened and is taking to much current to run because it needs better circulation than usual. I would bet that it has something to do with the electrical parts.
Panasonic inverter microwave ct579 killing the 10a fuse. Uk.
Check its transformer so that you will know its fuse size
Sep 12, 2014 | Panasonic Microwave Ovens
Whirlpool microwave fuse has blown multiple times
It depends on which fuse and when it blows. Wish you had mentioned that.
But usually it's a defective door switch or door switch mount.
If the fuse blows at random times while it's cooking, it may just be a loose fuse holder. Those have to be replaced due to metal fatigue, not just squeezed tight with pliers.
If it blows as soon as you hit "Start" to begin cooking, you have a shorting high voltage capacitor.
If it blows when you open or close the door, you have a loose or defective door switch or latch.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Nov 21, 2012 | Microwave Ovens
Dead, replaced fuse and it blew again.
The fuse is connected directly in series with the monitor switch. If it senses one of the door switches bad it will blow the fuse, this is there as an added safety to make sure the oven will not work without the door closed.
There are usually three and sometimes four door switches just inside and to the left of the control panel that are activated when the door interlocks with them. One of the switches is most likely bad. Typically it is the primary interlock which is on top. It can be checked with an ohmmeter, usually you can see it broken as the plunger will not go down or come up like the others.
May 10, 2010 | Maytag MMV1153A Microwave Oven
Servicer with a PLMV169DCD Fuse blowing Problem
For future reference, we regularly repair such control boards and displays for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
Here's the main service manual. Other versions are here and here.
It may be grease inside one of the switches or arcing conductors (usually due to opening the door while it's cooking) making it sticky.
This was made by Sharp, so the side panel should come off each interlock switch for inspection.
But looking at the schematic, the monitor switch cannot come into play under normal circumstances unless the door is shut and the secondary interlock (relay RY2 on the control board) is closed and (oddly, if the published schematic is to be believed) if the oven lamp relay RY1 is closed .
Everything seems to point to a bizarre problem like maybe an intermittent short of a wire to the chassis, perhaps where a wire passes through a hole or guide in the sheet metal.
Also, you might consider unplugging the hood vent motor and trying it.
Did you try it with the oven powered from another outlet?
Also be sure the neutral and hot are not reversed at the outlet and that the line voltage is correct.
Sometimes a loose neutral can be a factor. Test outlets in several area of the house to see if some are high and some are low. This can be dangerous, and the power company must be called.
If there is anything else on the same breaker, that can be a factor.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Nov 28, 2009 | Frigidaire PLMV169DC Microwave Oven
No power braker ok
There is an internal fuse on most microwaves, it will "Blow" if the door interlock switches are not happy, sometimes the fuse just blows, like some circuit breakers do.. get a few extra, replace it and see what happens..if it doesn't blow again, you're most likely ok, if not, there are more causes for the internal fuse to blow, beyond the interlocks, it's not going to be cheap.
Oct 25, 2009 | Maytag Microwave Ovens
We have a MH7135XEQ1 microwave and the fuse blew on it. We replaced it and it still keeps blowing. What is going on?
You may have a problem with the door switches. There are usually three switches and if the Monitor switch fails or the door isn't closing properly it will blow the main incoming power fuse.
Aug 26, 2009 | Microwave Ovens
JMC7000ADW Blows circuit breaker
I've had this problem twice with our microwave. The hint to where the problem lies is that the breaker blows when you open the door at times. Inside the microwave are three microswitches; primary and secondary interlock micro switches and an Interlock Monitor switch. The switches are supposed to shut down the microwave if it is running and the door is opened. But, I've found the upper primary switch can stick internal at times and when the door is opened the stuck switch will, because of the way it is wired as a safety switch, cause either the fuse or possibly the main circuit breaker for the oven to pop. The reason the stuck switch blows the breaker or fuse is when the door is opened the interlock switch will cause the neutral wire from the AC power to be applied to the Upper Primary Interlock switch which normally should be open when the door is opened, but if the switch is intermittent or the contacts weld themselves shut the neutral line is connected direct to the "hot" side of the power line through the fuse and thermostat. The first time my microwave failed the switch had melted the contacts together inside the switch and the second time the switch became intermittent and would blow the breaker to the over ever so often. I suspected the switch the second time this happened and utilizing an ohm meter I checked the switch several times by opening and closing the door and once in a while it would remain closed instead of opening when the door was opened. Of course while trouble shooting the power cord to the microwave must be disconnected and use all safety precautions when working around the high voltage areas inside the microwave. I wrote Jenn-Air about the bad switch and the way it is wired into the circuit, but never received any acknowledgement. I suspect these microswitches are under rated for the amount of current that passes through the switch, thus they overheat and eventually arc the contacts together. I hope this helps explain the intermittent problem and could explain many of the intermittent blown fuse problems I see in these internet help sessions
May 09, 2008 | Jenn-Air JMC7000 Microwave Oven
Wont turn on
If it blows the fuse as soon as you hit the START button, it's almost certainly a shorted high-voltage capacitor.
If it blows a few seconds after you hit the START button, it's probably the high-voltage transformer. You'll possibly also smell a faint electrical burning smell from the rear vent after you shut if off.
If it blows the fuse as soon as it's plugged in, you probably have a shorted door switch, a shorted varistor, or an internally exposed wire shorting to the chassis, etc.
Nov 11, 2007 | Frigidaire GLMB209D Microwave Oven
Blowing fuse problems
The door latch switches, and monitor switch assembly needs adjusting. With the door open the two latch switches should be normally open,and the monitor switch closed. Opposite way when door is closed. MAKE sure oven is unplugged before testing
Jun 28, 2007 | Daewoo KOR-860A Microwave Oven
Deawoo model wm1310pm blowing fuses
It's important that the door switches are clean, solidly mounted and operating smoothly. Sometimes as a switch ages, goes bad, or gets clogged with grease, it can be "laggy", and can allow a short that can blow the fuse and/or breaker. They can certainly be intermittent. Since it's blowing the breaker too, that usually indicates door switch trouble, so the door switch mount may be loose or broken. Beyond that, there is a chance that your magnetron or high voltage transformer is going bad, but I strongly suspect a door switch, mount, bent door, etc. first. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Jun 01, 2007 | Daewoo KOR-630A Microwave Oven
Microwave Ovens Logo
15 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
