Question about Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer
Brother MRC-440CN Printer won't print
Printer continues to give "Unable to Change 51" even after being unplugged and plugged back in. Jobs don't print.
    President:
  • 787 Answers
There is an error in purge unit on your printer.You can't fix it by yourself.If printer in warranty call Brother to replace it.If not look for service in your area.
Posted on Nov 13, 2009
My printer is not printing
Without knowing any more, all I can do is take you through a tedious set of steps:
  1. Is it plugged in? Unplug the power cord at both ends, then plug it back in.
  2. Is it connected to your computer? Unplug the cord at both ends, then plug it back in.
  3. Is it turned on? Press the power button. Do any lights change (go on or off, change color, flash, etc.)?
  4. Send a print job to the printer. Does the printer show any signs of realizing it's been asked to print something (an indicator light or something moving inside)?
  5. Open the print queue. Delete all the jobs that are in there. Shut down the printer. Restart the computer. Turn the printer back on. Try printing.
  6. Are you getting error messages?
  7. What happened before it stopped working? Did you install new software? Move anything?
May 01, 2015 | HP DeskJet F380 All-In-One InkJet Printer
Brother MFC-465CN printer Error code 51 unable to print
Usually this is caused by a foreign object or debris under the printhead path, or under where the printhead "parks."
Unplug the machine. Open the cover. Check the printhead path for little bits of paper, push pins, paperclips, staples etc. Note the location of the printhead.
If the printhead is at the far left, gently slide it towards the center (do not force it). Look carefully under where the printhead was stopped for debris. Use a flashlight if necessary.
Close the cover. Plug in the unit. Try again.
Jan 20, 2010 | Brother MFC-465CN InkJet Printer
How do I clear "Unable to Print 51" Error Code on a Brother MFC-665CW All in one Printer
51 error says that the purge assembly is stuck and not cycling properly. If you can power up and get the printhead to the center and unplug again, look with a flashlight in the far right corner where the printhead parks for any paper scraps or things that don't belong and remove them it might work again. Otherwise a shop repair to possibly replace the cleaning assembly.
Oct 02, 2009 | Brother MFC-665CW All-In-One InkJet...
LaserJet 1200 Stops pulling paper
If the printer works fine for you, but doesn't work properly for someone else I would assume user error. Just make sure that there is plenty of paper in the tray and that it is centered. Also look around for any small peices of paper that might've gotten stuck near the tray, preventing new sheets from getting pulled.
May 06, 2009 | HP LaserJet 1200 Printer
My problem is the same as that of miketheskibm. I
clear the printer rod and cartridges area.
and let me know.
Feb 19, 2009 | Lexmark JetPrinter Z22 Color InkJet
"Unable to Print 50" BROTHER MFC-440CN
my brother mfc-440cn printer says, "unable to print 51" on the screeen after if off (which it woudn't let me do. I had to unplug it. It just won't work.
Aug 26, 2008 | Brother MultiFunction Center MFC-440CN...
Error 51
might be over heated let it cool down also unplug it few min then back in ok and usb prot unplug it from pc also for min
Feb 04, 2008 | Brother MultiFunction Center MFC-440CN...
Print unable 51
Problem with purge station or encoder strip and/or disc defective.
Needs replacement.
Jan 15, 2008 | Brother DCP 130C All-In-One InkJet Printer
Change papersize from LTR to LGL
Turn the printer off for about 10 - 15min ( or even longer ) by removing the power cord.
I had left it unplugged overnight as it was late and had given up on fixing this annoying fault. Once plugged back in it was working fine.
Nov 14, 2007 | Canon imageCLASS MF5770 All-In-One Laser...
Printer stopped working claiming the jobs have been 'stopped' and giving no explanation.
Hi Plug out the usb cable from the cpu. Try deleting the printers from the printers window(START, Printers and Faxes), uninstall the software. Power off the printer and unplug power adapter. After the printer has been deleted from the printer window, plug it back in and reconnect back to computer. Then try a new installation of the printer and software. The pending documents that have been stopped should now not be in the spooled documents.
May 02, 2007 | Epson Stylus DX4200 All-In-One InkJet...
Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer Logo
349 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
