Question about KitchenAid Dishwashers
My Kleenmaid DW34 stops after 10 mins
My 18 month old Kleenmaid DW34 starts a program but stops after about 10 minutes, indicating d06 as the problem (a motor overload). Kleenmaid has gone into liquidation, so the warranty is no longer valid. Is there anything I can do to fix the problem?
SOURCE: Phillips 30" Mod 30pw633r37a
I unplugged it for 24 hours. When I plugged it back in it was ok. It has done it a couple of times since, but only for a few seconds.
Posted on May 14, 2007
  • 351 Answers
SOURCE: High Pitched Noise
try washing on hottest cycle it may be the seal in the spray pump somethimes the rinse aid can put a glaze on the seal if that doesnt work you can replace just the front part of the motor( in australia) dont know where you are.
Posted on Mar 09, 2008
  • 1632 Answers
SOURCE: honda eu 6500 gen overload indicator light will not shut off
Check the Ground Fault Indicator circuit breaker for triping, and look for the high limit on generator. Reset the main breaker by triping it full right and then back. Vitally
Posted on May 22, 2009
  • 4 Answers
SOURCE: humax digital recorder picture freeze every 10 minutes
Humax are having problems and are starting to send out software upgrades (night-time updates) - seems to be related to the new formats on the MUXs for the digital switch-over. Our 9150T hasn't been fixed yet but due any day (I hope)
Posted on Jan 05, 2010
mkh5094
  • 145 Answers
SOURCE: LG Washer trips dedicated breaker
That to me seems like an electrical problem. Every now and again you can get a bad GFCI receptacle that will constantly keep tripping. I would also see that the GFCI is properly sized for the circuit. It needs to be a 20 AMP circuit (just dedicated to the washer) and a 20AMP GFCI receptacle. The way to tell is the 1 of the three prongs of the 20AMP GFCI will be in the shape of a "T" while a 15 AMP will have 2 straight prongs and the ground prong. Hope this ws helpful, don't go spilling any money into your washer without getting that fixed first, because it doesn't seem like a washer problem.
Posted on Apr 30, 2010
The tiller starts and runs well for about 10 to 15 minutes but then will bog down and stop running . It will restart and run for about 30 seconds and then stop again. Any ideas about what is causing this,...
It sounds like a carburetor fuel issue. Which you could try attempting to adjust the carburetor (or have someone else do such) to see if that cures the problem.
May 16, 2014 | Honda 25cc 4-cycle Mini Tiller
I need to program a new fob. am reusing the old key! can you help?
  1. Turn the ignition to ON, then wait 10 minutes for the next step in the programming sequence.
  2. After the 10 minutes has elapsed, the car horn will chirp once. Turn the ignition switch to the OFF position within 5 minutes after the horn has sounded, then to the ON position within 5 seconds after switching it OFF.
  3. Leave the key to the ON position for 10 minutes . After the 10 minutes has elapsed, the car horn will chirp twice. Turn the ignition switch to the OFF position within 5 minutes after the horn has sounded, then to the ON position within 5 seconds after switching it OFF.
  4. Leave the key to the ON position for 10 minutes . After the 10 minutes has elapsed, the car horn will chirp 3 times.
  5. Verify that the security indicator in the instrument cluster has stopped flashing and attempt to start the vehicle.
  6. Turn the ignition to OFF and remove the key from the ignition switch.
  7. Move approximately 3 meters (10 ft) away from the vehicle and test the transmitter functions to validate that the transmitter has been programmed successfully.
Mar 30, 2011 | 2006 Pontiac GTO
How do we set the clock on Sharp logicook R-7N76?
Press stop/clear pad to remove 88:88 from the display.
Press auto start once for 12 hour clock and twice for 24 hour clock.
Enter hours first using 10 minute and 1 minute pad (i.e. for 12:00 - press 10 min button once and 1 minute button twice)
Press auto start.
Enter minutes as before using 10 min pad and 1 minute pad (i.e. for 35 mins press 10 min button 3 times and 1 min button 5 times)
Press auto start.
Jan 22, 2010 | Sharp Office Equipment & Supplies
Indesit dishwasher DI 450 stops after 10 mins
my disher washer dls 535 starts programme then lights 2 and 3 start flashing and does not work
Nov 19, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit WIDL 102
almost certainly a new module and eprom. these modules have given a lot of problems.
not really worth doing
Jun 25, 2008 | Indesit W 123 Front Load Washer
My stiletto records for about 18 minutes then stops
Daylight savings time change a few months ago messed up the timer recording schedule - you must now fix it. Daylight savings time changes will always mess up this recorder. You must reset your recording schedule.
For more info on fixing, go to:
http://shop.sirius.com/edealinv/servlet/ExecMacro?nurl=control/StoreItem.vm&ctl_nbr=2640&siId=1745656&catParentID=7874&scId=7874&oldParentID=&cid=SL100PK1
2 other remote possibilities:
If no signal is present at the time the recording is scheduled to start, the recording will be skipped.
Make sure you have followed all instructions on pp. 55-58
-Tha Mp3 Doctor
Jun 03, 2008 | Sirius STILETTO 100 MP3 Player
Stiletto only records for about 18 munutes
-Tha Mp3 Doctor
Dishwashers Logo
53 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
