Question about Toshiba Satellite A15-S127 Notebook
Memory i just added memory to my toshiba a15,(trying to upgrade the RAM) when i go into my computer additional RAM does not show. What am i doing wrong?
    Novelist:
  • 101 Answers
Hi Blevnthyself,
First make sure the ram is fully seated. I know the Toshiba requires a lot of pressure to get the ram to seat, properly. Also, try using just the new ram, to boot. If it fails to boot, the ram is either bad, the ram stick is not compatible, or you have reached your ram limit!
Good Luck!
Posted on Jan 08, 2008
  • 233 Answers
How much ram? what windows version? windows Vista 32bit will not support more than 3GB
boot up and go into CMOS see if the memory shows up there, sometimes you have to go into CMOS and SAVE
hope this helps
thanks for the rating
Acer Aspire M3400 Desktop PC. Memory Upgrade Issue
please check the memory timing settings. if your mixing up ram they may not have the same memory timings and require you to go either higher or to the supported settings that either memory can use. for example if corsair runs at 8-8-8-14 and kingston runs at 10-10-10-16 then you will need to bump the settings to 10-10-10-16 since the computer is trying to set the timings for kingston to 8-8-8-14 which it does not support.
Feb 18, 2012 | Acer Aspire M3400 PC Desktop
1-3-3-1 beep at boot on toshiba satellite
If the Toshiba satellite uses the Phoenix BIOS, then the 1-3-3-1 beep code indicates a memory problem. The specific problem the BIOS saw on the self-test is 28 Autosize DRAM.
It could be a problem with the CMOS battery. You can try replacing this coin battery. You can also try resetting the CMOS. For some computers, you can do this by removing the battery for 20-30 minutes. Other computers will have a CMOS jumper that you can use to reset the machine. I'd need the model number to check the CMOS reset.
More likely one or more of your RAM is incompatible or damaged or the motherboard RAM slots are damaged. If you have two memory sticks, then if they aren't the same speed or type, this error can occur. Remove the RAM and test one stick at a time. If you recently added memory or otherwise upgraded your RAM, test the old memory and the new separately.
Sometimes, you can accidently get the wrong memory. Some computers can only support RAM with memory modules on one side of the memory stick. Newer memory often has memory modules on both sides. (This applies only if you recently upgraded the memory. You should use a memory configuration tool to check the supported memory for your machine. Each memory manufacturer has one for their memory.)
If this error occurs with the original memory or each memory stick separately, you will need to test the memory in another computer or get new memory to test in your Toshiba. That will determine if the memory was bad or if the motherboard is damaged.
If you add a comment with your computer's model number and the details of your memory for the system, I may be able to provide more specific suggestions.
I hope this helps.
Aug 07, 2011 | Computers & Internet
My Toshiba Satellite A15-S129 is very slow How can i make this first. Plz help me at suja.islam@yahoo.com
Saying a computer is slow really is not giving out enough info. The A15's came with 256MB of memory, and runs XP Home - which was barely adequate. So that'd be the first area I'd address: most computers run slow 'cause they ain't got enough memory, and memory is cheap, so it's a crime not to give it an upgrade. If you indeed have 256MB of installed memory, then you should add a 512MB module (it uses laptop DDR PC2100 or PC2700 memory) and that ought to do it.
Mar 02, 2011 | Toshiba Satellite A15-S129 Notebook
Hello, Can I install a 512MB DDR DIMM, N mem stick taken out of my Dell Desktop into a Toshiba Satellite A15, S129 laptop? Thanks, RD
You can try, without fear of having your laptop "blow-up".
Turn your laptop off.
Remove the battery.
Physically, does the RAM fit into the RAM slot? If not, the answer is 'no' -- most "desktop" RAM is much bigger than most "notebook" RAM.
If it fits, connect the AC power, and turn the computer on.
If it beeps wildly, or does not beep at all, the RAM is incompatible.
Disconnect the AC power.
Remove the RAM.
Re-insert the "old" RAM.
Re-insert the battery.
Reconnect the AC power.
Do a Google-search for "RAM upgrade Satellite A15" to find sellers that sell compatible RAM.
Oct 10, 2009 | Toshiba Satellite A15-S129 Notebook
Hello, I have a Satellite A15 @129 w/756 MB RAM. I'd like to upgrade but don't know the maximum RAM stick each slot will take and don't remember if there are 2 slots or 4. Thanks, RD
The maximum RAM for this laptop can up to 1 GB DDR1 266MHz RAM and 2 memory slot available, so since u have already 756 MB RAM in your laptop, that mean 1 of your RAM stick is 512MB and another 1 is 256MB, so if u need to upgrade, u have to replace the 256MB with 512MB to make it 1GB maximum.
YBC (/\)
Oct 07, 2009 | Toshiba Satellite A15-S129 Notebook
Toshiba Satellite Pro A40 Can't find RAM memory
The memory is located under the keyboard
Remove batt and cables
open screen
pop out the rectangular panel surrounding the on off buttons
remove the 3 screws and lift up the keyboard to access the memory
Dont ask me why they made it this complicated
Manual can be got here
http://209.167.114.38/support/download/files_downloads/SA40/SA40EXUM.PDF
Sep 05, 2009 | Toshiba SATELLITE A10 A15 A20 A25 A35 A40...
Ram upgrade
Its support "DDR SDRAM"
Max Supported Ram is "1GB"/"1024 MB".
Ram Speed: 266 Mhz..
Good luck...
regards,
Dec 04, 2008 | Toshiba Satellite A65-S1068 Notebook
Toshiba Satellite A15-S127: Memory does not show up
Is the BIOS up to date? if not you can download latest BIOS update from support.toshiba.com
Mar 12, 2008 | Toshiba Satellite A15-S127 Notebook
Toshiba Satellite A15-S127 Notebook Logo
102 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
