Question about LG WM-2277HW Front Load Washer
Error code dE results when I start a load - LG WM-2277HW Front Load Washer
  • LG Master
  • 3,361 Answers
There is a fault in the door lock/door switch.
Could be a bad wire.
Usually a bad door switch mechanism.
Posted on Nov 12, 2009
Lg wm1832cw de error occurs when starting the washing. after multiple tries, it might start
It is a door lock error caused by bad door lock switch or if your door is very hard to swing closed because the hinge is corroded, then the hinge could be causing the door lock to error.
Jan 04, 2014 | LG WM-2277HW Front Load Washer
LG Intellowasher 7kg WD-14125RD shows DE error
DE is for a door lock error and you will need to replace the lock. Here is the part to order.
Dec 07, 2012 | LG WD-12126RD Front Load Washer / Dryer
De error code
DE is a drain error
Check to be sure the drain filter is clear.
Nov 30, 2012 | LG WM-2277HW Front Load Washer
Please Help! My LG WD-3274RHD has the error code "dE" after replacing assembly door switch?
dE for LG does the spring of latch hook actuate? no> fix door latch Yes> is there clicking sound once or twice when the start/pause button is pressed to start the cycle? No> check door switch and main PWB Assemblyhope that helps..
OE is Drain Error.
Sep 02, 2012 | LG WD-3274RHD Front Load Washer / Dryer
LG WM-2277HW Front Load error code dE
de error code means the door is open. If code does not clear when door shut then could be door interlock or main pcb fault
Oct 24, 2009 | LG WM-2277HW Front Load Washer
We get a de code
A "DE" is a drain error, but a "dE" is a door error. If it was in storage, I'd look for damaged wire(s) to the door lock switch caused by a mouse. It is less likely that the door latch itself needs replacing.
Apr 12, 2009 | LG WM-1832C Front Load Washer
Wont start has error DE
Error displayed table_1.gif Solution
n_de.gif table_2.gif i_1.gif Close the door.
n_4e.gif table_2.gif i_1.gif Make sure the source water faucet is turned on.
i_1.gif Check the water pressure.
n_5e.gif table_2.gif i_1.gif Clean the debris filter.
i_1.gif Make sure the drainage hose is installed correctly.
n_ue.gif table_2.gif i_1.gif Laundry load is unbalanced; loosen any tangled laundry. If only one item of clothing needs
washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an "UE"
error message will be shown in the display window.
n_3e.gif table_2.gif i_1.gif Call after-sa
Dec 07, 2008 | Washing Machines
Door latch
DE error code is because there is a drain problem and it will not lock the door.
Jun 24, 2008 | LG WM-1832C Front Load Washer
DE error code
That is a door switch error problem.  The door latch is not sensing the door closed.  You may need to replace the door latch assembly.
Oct 23, 2007 | LG WM-2032H Front Load Washer
Error code de
DE is a error code for your door switch. The door is not locking properly. You need to get a new door latch mechanism.
Sgt 48
Mar 29, 2007 | LG WD-1280FHD Front Load Washer
LG WM-2277HW Front Load Washer Logo
270 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
