Question about Cell Phones
I cannot connect to the internet at all. there is no network connection set and i dontknow how to set one up. HELP
I can not get signed in on my xbox
Test the Internet Connection on Your Xbox 360
If you are having trouble connecting to the Internet or the Netflix service follow the instructions below:Test the Internet Connection on your Xbox 360
  1. From the Xbox 360 main menu, select Settings, then System, and Network Settings.
  2. Select Wired Network or Wireless Network depending on how you connect to the Internet.
  3. Select Test Xbox LIVE Connection and agree to Continue.
If the test reports that you can connect to Xbox Live, you have a healthy Internet connection. If the test reports that you cannot connect, seeMicrosoft's Xbox support site for more help.
Need more help?
Oct 06, 2013 | Netflix
Tip
Set up and Use Internet Connection Sharing
To enable Internet Connection Sharing on a network connection
You must be logged on to your computer with an owner account in order to complete this procedure.
Open Network Connections. (Click Start, click Control Panel, and then double–click Network Connections.)
Click the dial–up, local area network, PPPoE, or VPN connection you want to share, and then, under Network Tasks, click Change settings of this connection.
On the Advanced tab, select the Allow other network users to connect through this computer's Internet connection check box.
If you want this connection to dial automatically when another computer on your home or small office network attempts to access external resources, select the Establish a dial–up connection whenever a computer on my network attempts to access the Internet check box.
If you want other network users to enable or disable the shared Internet connection, select the Allow other network users to control or disable the shared Internet connection check box.
Under Internet Connection Sharing, in Home networking connection, select any adapter that connects the computer sharing its Internet connection to the other computers on your network. The Home networking connection is only present when two or more network adapters are installed on the computer.
To configure Internet options on your client computers for Internet Connection Sharing
Open Internet Explorer. Click Start, point to All Programs, and then click Internet Explorer.)
On the Tools menu, click Internet Options.
On the Connections tab, click Never dial a connection, and then click LAN Settings.
In Automatic configuration, clear the Automatically detect settings and Use automatic configuration script check boxes.
In Proxy Server, clear the Use a proxy server check box.
Bhautesh.
on Feb 24, 2010 | Computers & Internet
Need help sharing the internet on my laptop from another laptop
On windows 7
Go to Control Panel > Network and Internet > Network and Sharing Center
Under Change your networking settings, click Set up a new connection or network
Select Set up a wireless ad hoc (computer-to-computer) network
Enter your Network name, and enter a Security key if wanted
Check the box for Save this network and click Turn on Internet connection sharing on next page
From your other laptop search for networks and you will find the one you just created, connect to it and use the security key you gave..
May 13, 2011 | Computers & Internet
How to conect with wireless internet
The Network and Sharing Center in Microsoft* Windows Vista* can be used to set up a secure wireless connection to the Internet.
Note: If an Internet connection is not automatically made by the operating system, you may need to contact your access point (AP), broadband wireless router manufacturer, or Internet Service Provider (ISP).
Set Up a Secure Wireless Connection to the Internet
These steps assume that your network adapter; AP or router; and cable, DSL or another type of modem have already been physically connected and configured. They allow you to create a new connection and configure it accordingly.
Follow these steps to set up a secure wireless connection to the Internet.
Note: If a wireless profile does not exist, you will need to create a secure wireless profile before you can set up a wireless connection to the Internet.
1. Access the Network and Sharing Center.
2. Select Set up a connection or network.
3. Click Connect to the Internet.
4. Click Next.
5. Select Wireless. At this point, if the network(s) that are listed say that the network settings do not match the network requirements, as shown in Figure 1, create a secure wireless profile and then follow the steps again.
6. Select a network and click Connect. If you are not connected to the Internet, you may need to contact your AP/router manufacturer or ISP.
To access the Network and Sharing Center, use one of the following methods:
  • Start » Control Panel » Network and Internet » Network and Sharing Center
  • Start » Network » Network and Sharing Center
  • Right-click the network system tray icon (the icon that displays two computer monitors) » Network and Sharing Center
Jan 21, 2011 | Computers & Internet
AFETR SIGNING-IN, A MSG. HAS BEEN DISPLAYED (YAHOO MESSENGER HAS ENCOUNTERED A NETWORK PROBLEM . PLS. CHECK THE NETWORK AND THEN TRY AGAIN). HOWEVER, NETWORK CONNECTON IS STILL ON. BUT, NOT GET CONNECTED...
Please check your internet connection setting if your network is enable and working properly. To solve this just click on your internet network or connection icon and click on repair, to repair it , if not you can get internet connection which means you can connect the internet.
Aug 09, 2010 | Yahoo Messenger
My dell aximx51v wont connet to the internet when a select a wireless network, add password, it says its connected, when i type www.google.com for instance i get this message; cannot connect cannot connect...
Go to 'Start > Settings > Connections tab > Wi-Fi > Network Adapters tab', and make sure that 'My network card connects to' is set to 'The Internet'.
Hope it works for you!
Cheers! Carlos
Apr 14, 2010 | Dell Axim X51v Pocket PC
I have a range booster g router D-link wbr-2310 and do i have to conect to the box from comcast or the conection on the wall and i put the disk an alat of archie show up and i dontknow what to put please...
I assme you have a DSL or cable modem from Comcast and this is connected to the wall. The LAN cable from this modem should now be connected to the WAN/Internet port on the DLink wireless router.
To secure your wireless network please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Mar 21, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
I dontknow how to connect my labtop to the internet useing a phone line
You will need to connect to the internet service provider (ISP) - you will need to create (aka buy) a dial up account to do it. You also need a modem installed on your computer. You may also buy external USB modems for this purpose.
Jul 07, 2009 | Dell Latitude D600 Notebook PC
MY INTERNET EXPLORER CAN NOT ACCESS INTERNET BUT FIREFOX WORKS
explorer 8 has this problem, same with me too. For me google doesn't work on IE8.
no option but to use other brozer like google chrome or firefox. and wait till microsoft makes it stable.
Rate me fixya.......... Thanks :)
S4 singapore.
Mar 26, 2009 | Microsoft Internet Explorer 8
Can't Connect to the Internet
Two things you can try before trying your browser/Internet connection:
1. Right click on the Wireless Network Connection Icon, click on Repair. Allow the computer time to repair its WiFi connection and some other settings;
2. Right click on the Wireless Network Connection Icon, click on Status. Click on properties button, select TCP/IP (Internet Protocol), click on Properties button, verify that the option "Obtain IP address automatically is ticked, OK, OK.
3. In your browsers, verify/modify settings:
In Mozilla, click on Tools, Options, Advanced tab, Network tab, Settings button, tick "Auto-detect proxy settings for this connection, OK, OK;
In IE, Tools, Internet Options, Connections tab, LAN settings button, check "Automatically detect settings" (& pls make sure there is no check mark on the Proxy server), OK, Advance tab, check Use HTTP 1.1 through proxy connections.
In Opera, Tools, Preferences, Advanced tab, Network, Proxy server buttons, check "Enable HTTP 1.1 for proxy, OK, OK.
Pls post back how things turned out or should you need additional information. Hope that this be of some help/idea.
Good luck and kind regards.
Nov 17, 2007 | D-Link Air DWL-122 802.11b Wireless...
Cell Phones Logo
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
