Question about Campbell Hausfeld 28 - Gallon Air Compressor
My air compressor can pump air in but when it get
Hi I have a campbell hausfeld 26gallon 125psi.
my air compressor can pump air in but when it get full at 120 psi it shuts off.
when I use the air and when in use it works fine. when the psi goes down to 80psi it kicks and it try's to pump air in the compressor but its struggles and seems to over heat or somethings and dies, it seems to be a breaker built in, it clicks and when it cools down for a couple of min it clicks back and it try's to pump again in it but still struggles. if I want to get it pump to 120 psi again I would have to use up all the air to about 15psi for it to pump again. what should I do or what is the problem? please help
  • 41 Answers
I had this problem when i ran a extension cord of to small wire gauge.ran larger feed wire and problem stopped.
Posted on Feb 01, 2010
  • hammernhand Mar 30, 2010
    do you hear air leaking from the switch area?if you dont i doubt the check valve would be the problem.
    Problem Solver:
  • 14 Answers
When it reaches 120 psi it will cut out usually will cut back in at around 70- 80 psi if it struggles to restart at cut in pressure it may not be bleeding the head pressure om your compressor . this is done by the pressure switch which when shuts off releases a small squirt of air under it . to solve this problem you may need new switch . there is also the non return valve to check
Posted on Nov 13, 2009
Pressure switch shut-off set too high.
It is adjustable. Remove the square cover nut and adjust the spring tension. . It would be best to lower to 110-115 psi. The compression rings will thank you for it..
Aug 24, 2014 | Campbell Hausfeld CW210500SJ Pressure...
I have a 6HP 26gallon CH Model VT627102 compressor. The pump shaft seems to be bent. Is there anyway to replace the shaft or am I better off replacing the entire pump? Also, can I put a larger pump...
Hi gary sr...
You already know the answer sir...
You will be better of replacing the compressor its self...don't buy a total new machine, you could save yourself a few bucks by just replacing the compressor unit.
Go to http://www.harborfreight.com/ and take a look at a replacement compressor unit, and then compare the price to a new compressor assembly...
I am sure you will buy the just compressor.
Please take time to rate me
Sep 03, 2011 | Campbell Hausfeld 26 - Gallon Air...
Compressor shuts off at 60 psi will not come back on until opsi
If the pressure switch has been changed you will need to reset it if not ,then is the compressor trying to come back on but will not start untill it reaches 0 psi?
Apr 25, 2010 | Campbell Hausfeld 26 Gallon Low Rider...
Need new pressure regulator for Campbell Hausfeld
their web site is chpower.com can order on line if not to old can check warranties also they can direct u to service location in ur area
Feb 01, 2010 | Campbell Hausfeld Air Tools & Compressors
Compressor runs but will not air up pass 10 psi
sounds like something has compromised the piston or rings. would advise you remove the cylinder head and inspect cylinder and bore, think you will no doubt find something broken.
Jan 25, 2010 | Campbell Hausfeld Air Tools & Compressors
Campbell Hausfeld Air Compressor auto shut off switch not working
i have the same one and mine was broken by my kids , i had to replace the entire component, DONT RUN COMPRESSOR with out the regulator working IT CAN EXPLODE IF OVERFILLED,a must fix situation i believe i got mine from sears , a great unit ive used it painting and with many air tools over many years now , well worth fixing mine is a little loud but dependable good luck.
Mar 15, 2009 | Air Tools & Compressors
Gas air compressor shuts down
IS IT BUILDING TO THE UNLOAD PRESSURE AND THEN STALLING OR JUST SHUTTING DOWN ANYTIME. IS THE UNIT SITTING AT AN ANGLE?
DOES IT WORK FINE WITH THE LOW OIL SWITCH UNPLUGGED? UNPLUG SWITCH AND LEAVE IT UNPLUGGED FOREVER.THEY'RE ALL P.O.S.
Feb 14, 2009 | Hitachi EC2510E 5.5hp Gas Air Compressor
No air pressure past 60PSI on a 125PSI Campbell Hausfield WL61110
Your comperssor is oilless type and suffers from short cylinder / piston life. When the compressor no longer reaches cycle pressure the cylinder / piston should be replaced. These parts are available at www.chpower.com I believe that the part number is wl210300aj. Not expensive, enjoy.
Dec 13, 2008 | Campbell Hausfeld 26 - Gallon Air...
Campbell Hausfeld 28 - Gallon  Air Compressor Logo
280 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
