Question about Dell Latitude D800 Notebook
Dell Latitude D800 Wont Power Up
I have a Dell Latitude D800. When I plug it in, the battery light comes on and stays on. There is no response when i press the power button. I have let it charge for a couple hours.
  • egglestc149 Nov 12, 2009
    I have tried most of these solutions- i pretty much figured it is something internally... I have tried different ram and power cord(I have several donor computers) I have also tried without a battery - nothing happens: not even a battery light then. Could be a power switch
  • 241 Answers
Most likely cause...motherboard has burned out. But try reseating your RAM , and removing your battery with the power cord removed. Press the power button to drain and "reset" things. Reinstall the cord and battery.
If it still doesn't start, try another charger. They can partially fail so they appear to charge but don't have enough power to run the machine.
Finally, try replacing your power switch. This sometimes fixes a starting problem.
Motherboard replacement will cost as much as getting another D800.
Posted on Nov 12, 2009
  • 70 Answers
Check the status of the battery directly from the battery. Turn the laptop over and on the batter is an battery indicator button and lights to tell you if it's charged. If it is charged then you have an problem internally. Wiggle the tip of the power cord at the laptop connection to see if it is loose, if it is then you have an loose connection on the motherboard which can be fixed by an experienced tech that can solder or the motherboard will need to be replaced.
IF THIS HELPS PLEASE VOTE.....GOOD LUCK AND THANKS..
  • Dell Master
  • 4,806 Answers
Take out the battery and try booting the machine on AC power only. If the machine boots up then let the operating system load up, the shut it down. Remove the AC jack and put the battery back in again, then power it up.
If it boots all is well if it doesn't then there could be a problem with the battery.
Please let me know how you get on and good luck.
  • Lee Hodgson
    Lee Hodgson Nov 13, 2009
    I have to agree with mrogers59.
    It is most likely the motherboard which is at fault here. If the laptop has a power board (a separate board that comes away from the main board with power switch on it), you can always swap one out from one of your donor computers.
    If its part of the motherboard then chances are the motherboard has developed hairline cracks on solder on the parts that get the hottest. The usual places are the power point on the motherboard, GPU (graphics processing unit) and so on.
    you can always try removing the BIOS battery from the motherboard for 20 minutes to see if clearing the CMOS works.
    Other than that you could try swapping motherboards from the donor computers that you have.
    Regards.
Dell motherboard not coming on
For latitude there's not much to do. check the power adaptor/connecting pin --- if any problem. If not than u need to replace the board.
May 02, 2014 | Dell Latitude D800 Notebook
I need to unlock a bois pass word for dell latitude D800
The best way to unloc a BIOS password is to reset by removing the CMOS battery and while the mains is removed press the power button a few times and leave for about 30 seconds. Refit the battery and power up. Password should be removed.
Apr 12, 2013 | Dell Latitude D800 Notebook
I Have a Dell Latitude D800 and it's plugged into power. when i hit the start button it lights up a couple of lights on the keyboard, they go out after a couple of seconds and then nothing happens?
Is the battery charging? and is the power adaptor properly plugged in? If yes then it's probably a faulty PSU and you will need to phone DELL for a replacement/repair.
Sep 06, 2010 | Dell Latitude D800 Notebook
My Dell Latitude will not turn on. When I press the power button it will come on for 5 seconds then go off. Can anyone help ?
Plug in the AC power cord, remove the battery, and try powering up. Anything? Any lights?
Remove power cord, hold in the power button for 30 seconds, then try plugging it in again and powering up without the battery. Any change?
Mar 13, 2010 | Dell Latitude D800 Notebook
I have a dell D800 it won't power on at all the battery show full
Try removing the battery and plugging it into the wall. then turn it on, if it turns on your battery is bad or connected improperly.
Dec 11, 2008 | Dell Latitude D800 Notebook
D800 will not even boot
Okay, I had that problem with my HP less than a minute ago.
Maybe it is the same problem. See if the battery light comes on. Press the power button again and again if it doesn't start, for some time. It may show the boot screen and hang. Now, the battery must be charged. Shut it down directly and switch the AC off.
Now, switch it on and see if the battery light comes on. If it does, it is the same problem as mine. Now, turn the PC over and remove the battery carefully. There may be switches for that.
Now, plug in the AC and start it without the battery in. If it does, you're done. Now, plug in the battery again.
Nov 28, 2008 | Dell Latitude D600 Notebook
Dell D800 Problems!!
Could be a short in the battery, Dell batteries are notorious for this. Try running it without the battery for a while. If the problem goes away, then it'e tome for a new battery.
Jul 05, 2008 | Dell Latitude D800 Notebook
remove the battery from the system and try to power on the System with the AC adapter connected. its only to check whether the system is receiving the power .
Also press the Fn key holding it down press the power button and release both the buttons , look for the LED codes and do let me know abt it
Apr 21, 2008 | Dell Latitude D600 Notebook
Latitude D800 wont boot
ok now it sounds to me the power pack on the back has shat its self so ufourtanetly u need a new one if u still have a valid warrenty ring dell or go to their web site at www.dell.com and they will happiley help u there number is also their but if u dont have warrenty go to their website and see how much it costs for a new battery but see a friend who has a dell laptop and plug in the power cord it might be your power cord not your com or battery so give it a wirl and if u have any problems email me at mid.nightclub@hotmail.com
Dec 31, 2007 | Dell Latitude D800 Notebook
Dell Latitude D800 Notebook Logo
638 people viewed this question
Alun Cox
