Question about Ryobi Garden
Hi, hope you can help. My Ryobi Scorpion wipper snipper has no electricity going to the spark plug. Is their a way to fix this either with or without a replacement part or is it not worth it? Thanks, Rob
  • 486 Answers
Rob, How have you determined that there is no spark? Have you used a type of spark tester? What is the condition of the plug. Brown or dark brown is OK. Black or silver is NOT Ok.
If you do not have a spark tester, remove the plug, and with it connected to the wire, find a portion of metal around the cylinder that you can ground it on, and then pull the rope. If the plug is black, you may see spark, but you should replace the plug.
*** PLEASE NOTE ; if there is excess fuel in the cylinder or on spark plug, it can catch fire, so be carefull to cover the hole with a heavy rag so that any fuel cannot be exposed to spark plug durning test !!!!
Worth it? If you can do the work yourself, I believe you will be OK. Depending on your parts availability, and the amount of time it takes.
Get back with me on how this issue works out.
thanks, rwvanlue
Posted on Nov 12, 2009
Manual Ryobi model RCT3160E wipper snipper
makers website. and download
Oct 21, 2014 | Garden
Ryobi Whipper Snipper starts, runs but doesn't like to rev, as if it's either flooding or sucking too much air
you've answered your question i would be inclined to be looking at adjusting the high low idle mixture settings and checking for a good spark also check the exhaust is free of obstruction may have a blockage
Jul 18, 2012 | Ryobi Garden
Replace fule line on ryobi wipper snipper I
hello sir, fuel line routing for ryobi,poulan trimmers, looking at machine from left side,front green line from tank to bottom of port on primmer bulb. rear line from tank which has filter inserted through tank with small white ring pushed up aginst tank & filter fittings, goes to port at bottom of carburetor.top line from primmer bulbgoes to top port of carburetor. that is the way thay go on.it is important to make sure you have the same fuel line I.D.3/32 and O.D.3/16 are very important! also if old line dissolved it will get in carb. and clog ports & small screen inside.clean inside of carb. with carb. cleaner & air pressure. to get your parts and numbers ,go to mtdparts.arinet.com, parts,791-683398,fuel line assembly,this is for most fuel line trimmers,any comments welcome,thank you. ``
Feb 03, 2012 | Ryobi Garden
My wipper snipper has no spark, Ihave bridged out the switch to make sure its not the switch, new spark plug ,correct gap .
The switch is a kill switch that grounds out the spark, at least that is how mine is. So assuming you have it correct, and new plug, that leaves the ignition coil. Only component left.
Sep 18, 2011 | Homelite Mighty Lite Lawn Trimmer
My stil wipper snipper starts and runs but only on low revs.it will not rev up
Most Stihl's are the same...Sounds like you need to adjust your mixture screws on the carby. you will need a small flat blade screwdriver (usually these are supplied with the wipper snipper from new and they have a little arrow on the top), H is for the High speed mixture screw, L is for the Low speed mixture screw. Turn the screws clockwise in until they seat (do NOT tighten!!) then turn them anti-clockwise the recommended amounts of turn on the cover around the holes. Careful not to lean the mixture out too much, but if it is the newer type they have a restictor on the High Speed that stops it at 3/4 of a turn. start it up and hopefully it will fix your problem, if not you will have to take it to a professional. Further info majority of STIHL high and low mixture setting are fine tuned via the respective rev settings , you'll have find out the particular setting from your STIHL dealer(sorry)
Nov 21, 2010 | Garden
Need exploded view diagram for a zama carby on a ryobi scorpion whipper snipper
www.zamacarb.com
Zama has a great website. It will show you where to find the series and model number of your carb, as well as a search engine to find the diagram and parts illustration for your carb.
Nov 04, 2010 | Ryobi Garden
My 2 stroke whipper snipper won't start
As with all 2 stroke engines,
1. Pump the fuel plug. 3 -5 times.
2. Turn the stop botton onto start.
3. Choke onto hot.
4. Pull the cord . Most important... dont touch the throttle trigger when pulling the cord. Wait until until it starts up.
If you do. (like it says in the instructions, your flooding the engine)
Works every time for me on everyone's whipper snippers.
Feb 09, 2010 | Ryobi Garden
How to fix my Ryobi Wipper Snipper - Model# RLT30CD? Hi, I having been using the bump feed and all of sudden its not bump feeding. What should i do about fixing this up? Cheers Clint Baird
You may have dirt in the spool, keeping the line from feeding. Or, the string is slightly tangled on the spool, not allowing it to feed properly.
Jim
Nov 26, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Garden Logo
69 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
