Question about Garmin GPSMAP 76CSx Handheld GPS GPS Receiver
Battery compartment connectors
When inserting the batteries into the unit, the pos connector on one of the battery terminals broke loose. If I insert the broken tab back into the unit after the battery has been installed, the unit works fine. I just want to know who can fix this in Omaha, NE. Garmin wants $75.00 just to see it. HELP!
  • 1 more comment
  • eacclev Jun 24, 2008
    Same problem here. My tab broke a while back and reinserting it worked for a while, now I have to physically hold the battery in the correct position for the unit to keep power. It no longer keeps power when the cover is replaced.
  • Anonymous Aug 21, 2008
    Same here, little tab popped off after changing batteries about 20 times. POS tabs are too thin.
  • Anonymous Apr 16, 2009
    Same problem with battery terminal... Anybody besides Garmin outthere that can fix this?
  • 3 Answers
I had this happen with my 76CS. The cost for a look at it is $125. I used a piece of aluminum foil.
Fold it over, make certain it holds tight against the wire.
It's not the best solution, but it works.
You could also search for a device with a similar battery contact, unsolder it, and pull the Garmin apart and solder it in. I'm still looking for the right device.
Posted on Sep 14, 2009
How do I hook up this unit Two wires or four
Almost all car batteries have 2 pos and 2 neg. More precisely, 1 pos post and 1 side connector, 1 neg post and 1 neg side connector. You only usually use use one set or the other depending on what connectors are on the end of your cables. You can connect something else to the side posts if you need to, but generally only pair is used.
Feb 28, 2015 | Cars & Trucks
How to activate a vtech phone
Instructions
    • 1Remove the battery cover from the back of the phone. Most models have a door that slides downward to reveal the battery compartment.
    • 2 Install the battery by inserting the connector on the battery wires over the pins in the handset battery compartment. The connector will only go on one way.
    • 3 Insert the battery pack into the compartment and replace the battery cover.
    • 4 Charge the phone by sitting it in the charger for a minimum of 16 hours on the first charge.
    • 5 Place the fully-charged phone onto the cradle of the base unit and wait for the display to show "PRESS FIND HNDST 4 SEC ON BASE." If the message does not come up, lift the phone off the base and put it back in the cradle.
    • 6 Press and hold the "FIND HANDSET" button on the base unit for approximately four seconds. The display on the phone will change to "PLEASE WAIT," then "HANDSET X REGISTERED."
    • 7 Test the phone by making a call.
Jul 14, 2014 | Vtech Lands Phones
Es lexus 300 p 1705...What is this?
DTC P1705 - NC2 (Direct Clutch Speed Sensor) Revolution Sensor Circuit malfunction or Direct Clutch Speed Sensor Output is 300 RPM or less with Vehicle at 20 MPH or more & with Park/Neutral Position Switch Off
Most probably you have an electrical fault causing the problem and attached is a diagnostic procedure. It could be 2 separate problems and after rectifying the P1705 only would you know it is single or 2. Repair manual shows right on top of transmission, black sensor with single bolt, 2 wire plug. P/N 89413-08020 list price $113.80
NOTE: DTC P1705 is set when PCM receives 2 gear position signals at the same time.
1. Turn ignition on. If any A/T gear position indicator lights remain illuminated when gear selector is moved from that gear, go to next step. If all A/T gear position indicator lights turn off when gear selector is moved from that gear, system is okay at this time.
2. Disconnect A/T gear position switch connector. If all A/T gear position switch indicators go out, replace A/T gear position switch. If all A/T gear position switch indicators do not go out, go to next step.
3. Reconnect A/T gear position switch connector. Shift through all gear positions except Reverse. Using a DVOM, measure voltage between 16-pin PCM harness connector "D", terminal No. 6 (Green/Red wire on 2.3CL or White wire on Accord and Odyssey) and 25-pin PCM harness connector "B" terminals No. 20 or 22 (Brown/Black wires).
If battery voltage is present, go to next step. If battery voltage is not present, check for a short in Green/Red or White wire between 16-pin PCM harness connector "D" and A/T gear position indicator, or A/T gear position switch. Repair as necessary. If Green/Red or White wire is okay, check for loose PCM harness connectors. Replace PCM with a known-good unit if necessary.
4. Shift through all gear positions except Neutral and Park. Measure voltage between 16-pin PCM harness connector "D", terminal No. 13 (Blue/White wire on Accord or Light Green wire on 2.3CL and Odyssey) and 25-pin PCM harness connector "B" terminals No. 20 or 22 (Brown/Black wires). If battery voltage is present, go to next step. If battery voltage is not present, check for a short in Blue/White or Light Green wire between 16-pin PCM harness connector "D" and A/T gear position indicator, or A/T gear position switch. Repair as necessary. If Blue/White or Light Green wire is okay, check for loose PCM harness connectors. Replace PCM with a known-good unit if necessary.
5. Shift through all gear positions except "D4". Measure voltage between 16-pin PCM harness connector "D", terminal No. 9 (Light Green/Black wire on 2.3CL or Yellow wire on Accord and Odyssey) and 25-pin PCM harness connector "B" terminals No. 20 or 22 (Brown/Black wires). If battery voltage is present, go to next step. If battery voltage is not present, check for a short in Light Green/Black or Yellow wire between 16-pin PCM harness connector "D" and A/T gear position switch. Repair as necessary. If Light Green/Black or Yellow wire is okay, check for loose PCM harness connectors. Replace PCM with a known-good unit if necessary.
6. Shift through all gear positions except "D3". Measure voltage between 16-pin PCM harness connector "D", terminal No. 8 (Green/Blue wire on 2.3CL or Pink wire on Accord and Odyssey) and 25-pin PCM harness connector "B" terminals No. 20 or 22 (Brown/Black wires). If battery voltage is present, go to next step. If battery voltage is not present, check for a short in Green/Blue or Pink wire between 16-pin PCM harness connector "D" and A/T gear position indicator, or A/T gear position switch. Repair as necessary. If Green/Blue or Pink wire is okay, check for loose PCM harness connectors. Replace PCM with a known-good unit if necessary.
7. Shift through all gear positions except "2". Measure voltage between 16-pin PCM harness connector "D", terminal No. 14 (Green/Yellow wire on 2.3CL or Blue wire on Accord and Odyssey) and 25-pin PCM harness connector "B" terminals No. 20 or 22 (Brown/Black wires). If battery voltage is present, go to next step. If battery voltage is not present, check for a short in Green/Yellow or Blue wire between 16-pin PCM harness connector "D" and A/T gear position indicator, or A/T gear position switch. Repair as necessary. If Green/Yellow or Blue wire is okay, check for loose PCM harness connectors. Replace PCM with a known-good unit if necessary.
8. Shift through all gear positions except "1". Measure voltage between 16-pin PCM harness connector "D", terminal No. 15 (Light Green/White wire on 2.3CL or Brown wire on Accord and Odyssey) and 25-pin PCM harness connector "B" terminals No. 20 or 22 (Brown/Black wires). If battery voltage is present, check for loose PCM harness connectors. Replace PCM with a known- good unit if necessary. If battery voltage is not present, check for a short in Light Green/White or Brown wire between 16-pin PCM harness connector "D" and A/T gear position indicator, or A/T gear position switch. Repair as necessary. If Light Green/White or Brown wire is okay, check for loose PCM harness connectors. Replace PCM with a known-good unit if necessary.
Hope helps.
May 24, 2011 | Lexus ES 300 Cars & Trucks
Where can i get Pogo Radio YourWay LX Replacement Battery ...
You are going to have to modify the battery compartment since Pogo is no longer in business. You will need a Dremel to cut the back plane of the battery compartment out. The back plain is the plastic piece that the separate the circuit and battery compartment. When you insert the battery it is inserted until it stop against the back plain. You will need to remove the back cover to cut the plain out. Once this is done just take teh old battery to a battery store for a replacement. the voltage should be 3.7 volts, and as close to the MA as possible. Also make sure that the new battery has the right connector or otherwise you will have to reuse the connector from the old battery buy cutting the wires as close to the old battery as possible and resoldering to the new battery. good luck
Jan 22, 2011 | Pogo Radio YourWay MP3 Player
How to remove the sim card?
Quick start guide
Your Nokia E75 is a business device that adapts to your
free time, as well.
Read these first pages to get started, then use the rest
of the guide to explore what new features Nokia E75
brings to you.
SIM card, battery,
charging, memory
card
Put the pieces together, and get started with your
Nokia E75.
Insert the SIM card and
battery
1. To open the back cover of the device, with the back
facing you, unlock the back cover release button,
and lift the back cover.
2. If the battery is inserted, lift the battery in the
direction of the arrow to remove it.
3. Insert the SIM card. Ensure the contact area on the
card is facing the connectors on the device and that
the bevelled corner is facing the top of the device.
4. Align the contacts of the battery with the
corresponding connectors on the battery
compartment, and insert the battery in the
direction of the arrow.
Jan 22, 2011 | Nokia E75 Cell Phone
How do you open battery slot
(1)Remove the USB connector cover.
(2)Press and Move the battery cover in the direction of the arrow.
(3)Remove the battery cover and insert one AAA-size battery into the
(4)Replace the battery cover.
Jan 23, 2010 | Nextar MA933A MP3 Player
Nikon F601 Wont Turn On...
The most common cause of no electrical function is some sort of corrosion on the battery terminal connectors.  Assuming the battery is the correct type (6V DL223A, CR-P2) and holding a good charge, it could be that one or both of the prongs at the bottom of the battery compartment has something on it. The F601 (or the N6006 version, which I have) is 16-17 years old now, and has likely picked up some battery corrosion over its lifetime. Try rubbing the top of the terminals with a rough pencil eraser (being careful not to bend the prongs over).
You might also check to see whether the battery is latching under the tiny tabs inside the edge of the battery compartment when it is inserted. It should be- this holds the battery down tight against the terminal prongs.
If the battery is good, inserted correctly (open terminal end in first), and the F601 still doesn't power up, then...ummm...
Jul 10, 2009 | Nikon F601 35mm SLR Camera
Positive terminal keeps getting corroded even after 3 weeks.
Try keeping the terminal far away from any moisture and dirt. In fact isolating it may not be a bad idea. Try getting a battery box for it or sealing off the existing one, just make sure to use a drain tube and vent. Some stores have battery terminal isolators, these are less effective but can help. There is also a battery terminal sealant spray that may be helpful if you cannot get/use a battery box. Clean the terminals thoroughly, spray the terminal sealant, and use the battery box for a three way attack. This is especially use full in harsh climates. These methods can also be used on remote battery terminals that are on some cars.
-Dynami
May 04, 2009 | 1995 Chevrolet Lumina
Van dies while in operation
That points to the battery.
Does it click or chatter when you turn the key to restart?
You have an apparent GROUND and POSITIVE 12v off the battery when the car IS running, but noyjhing when it dies. I love a mystery ;-)
If there is a loose connection at either terminal of the battery or the cables where they connect to the car frame, the connector lugs at the battery will arc and vaporize the metal at the weakest point of contact and all you will get is a click. Take off the battery connectors and clean the posts and insides of the connectors with sandpaper, then starting with the POS (Red +) side, push them on firmly, loosen the clamp bolts tap them several times around in a circle with a small hammer, block of wood or screwdriver handle so they seat all the way down, then tighten the bolts. If it wont go, remove the bolt, insert a flat-blade screwdriver in the **** and twist the screwdriver to expand a bit then tap some more. NOT HARD... just alot of little taps) Put the bolt back in and do the NEG (Black, -) the same way.
NOW it will start!
Mar 27, 2009 | 1996 Oldsmobile Silhouette
WILL NOT TURN ON
There are generally 2 causes for this symptom.
1. The input connector is usually a 3 terminal device. When the plug is inserted into the device, a spring loaded contact is pushed away from another terminal which effectively disconnects the battery section from the device. This stops any electricity from the plug from being connected to your batteries and causing overload conditions. If this spring loaded terminal has been damaged, when the plug is removed from the device it will not "spring" itself back to its terminal and the battery power will not reach the PC board.
2. The battery case (compartment) has 2 wires going from it (internal to the device) one black and one red. If either of these wires has broken off the battery holder or broken off the PC board within the device, it will not power up.
You can also make sure that all the batteries are inserted in the correct direction. Since the unit works when plugged in, you can cross out anything else having to do with the unit.
Mar 06, 2008 | Radio Shack Pro-97 Handheld Scanner
Garmin GPSMAP 76CSx Handheld GPS GPS Receiver Logo
292 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
