Question about Sega Dreamcast Console
Dreamcast won't recognize controller????
I've had the dreamcast for quite a few years now, It worked excellent when I had purchased it and some years after, but now after having an Xbox plugged into the tv I tried playing the dreamcast (unplugged everything related to the Xbox), it goes to the set date/time screen, I try and set it but it won't let me. Any help?
  • sean_spiva Nov 12, 2009
    Also a nother tip I've had the dreamcast for over 5 years.
Here:
Posted on Jan 16, 2010
Same problem mate. I read the manual and it said to charge up the battery by leaving the console on for at least 2 hours. I left it on for at least 4 but no result. Maybe the battery needs replacing but that prob requires some uncrewing of some panels. I had the same prob with my saturn (if you had one) and that just required a new lithium battery, job done. Who knows ay? I just want to go back to spending endless hours trying to level up my character on PSO, ah good old days.
Posted on Feb 24, 2010
Dreamcast cuts out after or during the startup screen, stops displaying audio and video. If a disk is inside, it doesn't shows no signs of even being on aside from the power LED and the fan. The system...
This is probably the most ridiculous thread I've ever read in regards to the most common fault of the Sega Dreamcast. The issue is not with the laser - if it was unable to read the disc, it wouldn't read the disc.
The issue is actually with the pins that connect to the motherboard. They corrode and burn out over time. This can be fixed by cleaning with a high percentage alcohol.
Make sure you have unplugged and turned off the console for a couple of hours beforehand.
And before you open it up, press the on button to check for any remaining power.
Instructions are here http://www.mmmonkey.co.uk/dreamcast-random-reset-and-common-fixes/
Sep 17, 2011 | Sega Dreamcast Console
I was playing with my Dreamcast and one day it would not recognize the controller.i turned it off and i tried it again.The same thing happend.Do i have to open the controller and clean it?
The pins on the controller connector might need to be cleaned or the cable might have short-circuited. Try using another controller to make sure it is the controller and not the system itself.
Mar 15, 2011 | Sega Dreamcast Console
My control wont work
did you tested another dreamcast control...you had the same problem...so you have to check the protection Fusistor inside your dreamcast conector controller board....it seems like a blue or green normal resistor...marked as F1 on the board..change it with a simple fuse or an smd fusistor...Good Luck!
Nov 23, 2009 | Sega Dreamcast Console
Sega Dreamcast won't recognize controllers. Have 4 controllers and have tried all combinations with and without memory cards. Was working 2 months ago when last used. Does something discharge in the system...
i have had the same problem once and i fixed it by changing the whole controllers part, if you take it apart you will see the controllers compartemnt related to the motherboard via a flex cable its so easy to replace!
See e
Jul 12, 2009 | Video Game Consoles & Games
Dreamcast wont read games more detailed problem
you need to replace the hdd[hard drive]
Jun 20, 2009 | Sega Dreamcast Console
When i am in the middle of playing a game on my Sega Dreamcast it will cut out on me sometimes and go to the Dreamcast menu,with the controller and music stuff in background and then it tries to reload the...
Your Dreamcast sounds like it's overheating.
I had the same thing, and the cooling fan was worn out and needed to be replaced. I did this, and now it works like a charm.
Apr 14, 2009 | Sega Dreamcast Console
Freezing problem with Games
The Dreamcast is no longer supported because it was to easy to copy the games, but there are still a loyal few who keep the scene alive. I have no idea how much you want to put into fixing the problem, but the only way to fix your problem is flashing the Dreamcast BIOS.
Modification 101:
http://www.youtube.com/watch?v=v7v8cEU1I50
The Dreamcast is basically a computer; with the right programming you can do anything; and having a Dreamcast Keyboard is nice.
Other links you should check out...
DreamChip and 4 in 1 Connector
Another Dreamcast Mod Chip
The Ultimate Dreamcast Survival Guide
Sega Dreamcast VGA Mod
Modified Dreamcast BIOS
www.dc-scene.net
Nov 27, 2008 | Sega Dreamcast Console
Sega Dreamcast console problem
First off, NEVER store a game console on top of a subwoofer. It is like a giant magnet, and electronic devices do not handle magnetics. I don't think i've ever heard of a VGA box, Sega brand or not, killing a console. Millions use aftermarket AV cables and adaptors on all consoles without problem. I think it likely died from being on top of the sub. Relocate it and you should be fine. Running it for a few hours isnt likely either unless you had the vents entirely blocked.
To the guest who's drive isnt spinning, I would say your drive motor has burnt out. This doesn't indicate a defect in Dreamcasts, per se, it just means bad luck or excessive dust which killed it. Either buy a different Dreamcast or see if you can find a drive replacement.
Hope this helps.
Feb 28, 2008 | Sega Dreamcast Console
Date screen
If you unplug you Dreamcast for extended periods of time the battery in your Dreamcast that saves that info will die (its suppose to last a month but over time they will wear out and not last at all). After 1 hour of gameplay (assuming the battery is still working, as Li's wear out) the battery will be fully charged and last a month.
Jan 17, 2008 | Sega Dreamcast Console
Sega Dreamcast Console Logo
762 people viewed this question
Top Sega Video Game Consoles & Games Experts
Josh Whitehead
Josh Whitehead
Reggie brown
Frank Zabroski
Frank Zabroski
Are you a Sega Video Game Console and Game Expert? Answer questions, earn points and help others
