Question about Maytag Dryers
Dryer making noise and quits running
Dryer making ''chirping'' noise coming from motor or bearing even after disconnected belt for drum. (took small service panel off back) when running with load noise increases in frequency and volume and dryer evenbtually shuts off.
Thanks for your assistance.
  • Maytag Master
  • 3,361 Answers
You may need to replace the drum rollers and front drum glides. The motor definitely is bad and should be replaced.
A Maytag dryer is worth investing the repair cost.
Posted on Nov 12, 2009
Beko DRVS6W tumble dryer squeaks when the drum comes to a halt
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
GOD IS GOOD !!!!
May 22, 2015 | Beko DSV64W White Vented Tumble Dryer 6...
What is making mywhirlpool/admiral electric dryer sound loud and thumping noise
You dryer belt may be shot and a piece of rubber is missing making it jump while working. Needs replacing before it completely quits. It will eventually just break apart.
Apr 13, 2015 | Admiral Dryer. 6.5 cu. ft. Electric Dryer...
Kenmore he4t makes a whinning noise when it is not running
DRYER MAKES NOISES.
The blower:
The bearings:
May 16, 2014 | Kenmore Elite HE4 Electric Dryer
Motor making noise
DRYER MAKES NOISES.
The blower:
The bearings:
Apr 15, 2014 | Frigidaire FGQ1442ES Gas Dryer
Kenmore 86582800 drum has a high pitched squeak after been on for 5minutes. 1983 model
see this steps and fix it. God bless you
Drive Belt
If the dryer makes noise, the belt may be frayed or damaged. If the belt is damaged, it will make noise every time it travels around the pulleys. The drive belt is a long, narrow band that wraps around the entire drum, then around a tension pulley and the motor pulley.
er
Drum Roller
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers. If one is worn out replace all of them at the same time as a preventative measure.
Drum Roller Axle
Over time the drum roller axles can wear out, causing the rollers to wobble. If this happens the dryer makes noise. If the dryer is making a rumbling noise, check the rollers and axles. If any are worn out, replace them all at the same time.
Blower Wheel
Drum Bearing
Drum Support Roller & Axle
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers or axles may be worn out. After removing the drum from the dryer, inspect the rollers and axles. If one is worn out replace all of them at the same time as a preventative measure.
Drum Support Bearing
The drum support bearing is at the rear of the drum. If the dryer makes noise check this bearing. If it is worn out, replace the entire bearing.
Drum Slide, Glide, or Pad
Drive Motor
Although not very common, if the dryer makes noise the drive motor may be worn out and the motor bearings can become noisy. If this happens the drive motor must be replaced. The bearings are permanently sealed and cannot be lubricated.
Jul 13, 2013 | Dryers
Dryer is plugged in but won't turn. Only makes a humming noise like the motor is on. I took the back panel off but don't see fuses/breakers.
It sounds like the belt has come off the dryers drum that spins around. Remove the top & the front panel to see. Sears sells the belt along with a idler pulley which should be change with it too. The bearing in the pulley to make the belt break or come off when the bearing seizes up
Dec 26, 2010 | Dryers
This is an electric dryer. Over the past week when
one of 3 things could be wrong/1)dry,tight motor bearings/2)drum bearing bad/3) bad motor windings,remove belt off drum and see if anything turns hard i.e. motor,drum each one isolated then run motor w/o drum belt on drum and see if motor gets overly warm or hot especially around the bearing ends
Nov 15, 2009 | Kitchen Ranges
We have a Frigidaire FER211AS2 dryer that started making a loud humming/roaring noise. Hubs replaced the bearing and drum belt. The noise isn't quite as bad but it still makes the same noise. What could it...
Check the alignment of the belt. Humming/roaring noise usually comes from a bearing, so your husband got it right to change the bearing and belt.
Now, he just needs to make sure that the belt is aligned right and the bearing is properly seated. Also check for rubbing marks around the travel area of the drum.
Oct 09, 2009 | Dryers
Whirlpool dryer drum making noise
window.google_render_ad();There are many places & parts that could be causing your Whirlpool dryer to be noisy. To find out what is causing the noises, you need to find out where are the noises coming from.
Start the dryer and let it run for a while and listen to try to pinpoint where in the dryer the noises is coming from. Once you have an idea of the area, you will need to disconnect the dryer from the wall outlet and take the dryer apart.
Below you will find the parts that you need to check when your dryer is noisy.
The drum baffles:
The drum baffles are use to tumble the clothes inside of the drum, in other words, the baffles job is to separate the pieces of laundry as the drum turns.
When the dryer is getting older and if you use the dryer a lot, the drum baffles holding screws will become loose. Loose drum baffles will cause noises. All you need to do, is to open the top panel and tighten the drum baffles holding screws.
The drum support rollers:
These dryers uses four drum support rollers, tow on the front and two on the rear. The job of the drum support rollers is to keep the drum tumbling smooth.
When the grease on one of the rollers dry out, the roller start to make squeaking noises and the roller bearing will start to wear out until the bearing on the roller is gone. When the bearing on the roller is gone, the noise will change from squeaking to a clanking noise.
The blower wheel:
The blower wheel is use to circulate the air inside of the dryer drum. The most common Whirlpool blower noises are cause by something falling inside of the blower housing and hitting the blower when the motor runs.
The Idler pulley:
The Idler pulley is use to apply the necessary tension on the belt. There are two types of idler pulleys, the pulley with the wheel and the pulley with the teflon slide. A bad idler pulley could cause a Whirlpool dryer to be noisy.
The drive motor:
Worn out bearings on the motor will cause the motor to run kind of noisy. When the motor starts making noises, the solution to this problem is to replace the motor.
The belt:
The belt on most dryers is only about1/4 inch wide. These belts work very hard making the drum tumble. When the belt stretch just 1/2 inch more that it supposed to, the belt will start slipping and that could cause your Whirlpool dryer to be noisy.
As you could see, there are a lot of parts that could become noisy in your dryer. When your dryer starts making noises, make sure to check it out before it gets worse.
Feb 09, 2009 | Whirlpool LER4634J Electric Dryer
Kenmore 70 series dryer making loud rattling noise, drying ok
it could be a worn motor bearing, but they usually last for 20 years, i would guess that you have a worn drum roller, the thing that holds up the drum and looks like a wheel.
if your sure the motor has a worn bearing then replacing the motor is not easy as you have to unscrew the blower wheel from the motor shaft.
it also may be that you are talking about the idler pulley being worn. it is the device that holds tension against the belt and they also will wear out and be "wobbly"
Dec 28, 2008 | Kenmore 63942 Dryer
Dryers Logo
113 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
