Question about Samsung HLR5067WX 50" Rear Projection HDTV
My screen is a yellow green color with a grainy picture. The TV is about 4 years old and has never had the lamp replaced. Will replacing the lamp fix my TV?
  • Samsung Master
  • 8,457 Answers
Convergence it dead,Know how to solders?Buy a convergence kit,use what in that kit.Tries these websites for the kit,Tv repair World.com,Tv repair kits.
Posted on Nov 12, 2009
Hi everyone! I have a pioneer pdp-5071pu 50'' plasma. I'm having a screen/picture problem. 2/3 of the screen is good picture (top),then just below half screen there are two grainy green lines, then...
The Y Lower buffer is the most likely culprit. I would first try to firmly tap on the TV... about 3" below the center line on the right side front (not on the screen but right next to the screen). The Y Lower connector is there and it could be just loose. I have a Philips 50" plasma that the lower half went out and a gentle tap fixed it once. I took it apart and tightened the connectors by loosening the screws and pushing the Y Lower buffer toward the Y Main board while tightening the screws back. No problem with it since. But sometimes the buffers go bad on these units and need to be replaced. Some people replace the upper and lower at the same time while others say just replace the bad one.
Good luck and let me know what you find!
Oct 13, 2010 | Televison & Video
PT50LC14 Color problem with color too much yellow and green no white or blues can not correct is this the lamp again im on why does it seem that I end up replacing the lamp every year (on number 3 now)....
ok,,your problem is not on the lamp itself.,the problem is on your screen controller.the controller is connected on the plyback you can adjust the screen intensity of the red,green,blue cathode..on your screen adjustment.
May 17, 2010 | Panasonic PT-50LC14 50" Rear Projection...
I have a sony projection tv Canadian model number KF-E42A10. The screen has a green tinge to it. All images are fine, just the color is off. When I go to the the guide the green is gone, it is a pukey...
Not the lamp if u have good picture.Ur 2 convergence ICS and all the resistors is dead.Colors misaligns,have shadow or 3D colors. Must replaced 2 ICS and all it resistors in the US shop will cost U $300 parts and labors.Canadian don't know.
Feb 10, 2010 | JVC AV-65WP74 Rear Projection Television
Mitsubishi tv model wd 73727 and how to take tv apart to clean marrow
my mitsubishi 73" set is 4+ years old. all of a sudden the color is all wrong. after a couple of minutes of clear picture the colors change--blue is green and red is yellow. a little while later everything has a red tint to it and there is a line going down the center of the screen. to the left the picture is still relatively sharp, but the right hand side is terrible. I'm hoping this is just the lamp.
Rick
Woodland Hills, Cal.
Apr 12, 2009 | Televison & Video
"my kdf e50a10 has a green screen Is this is a lamp problem or an
Green picture is caused by the light engine (the projection part of tv) failing and has to be replaced. Sony has extended the warranty on some models so you might be in lick. Contact them with model and serial number they can help setup repair if you qualify. If it is not covered it can cost between $1000-2000 to fix, which is way too much.
Rustym62
http://www.the-tv-dude.typepad.com
Mar 23, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Color went to grayish green, dull picture.
It ended up being one of the connectors on the composite cable. I did not know that the different colors came through separate cables. I do now, Thanks.
Dec 05, 2008 | Samsung HLN467W 46" Rear Projection HDTV
Color Fading on Zenith E44W46LCD
you neeed to change the lamp. the access is located on the right side of the television. you can buy the lamp for about $125 from discount-merchant.com
Mar 10, 2008 | Zenith E44W46LCD 44" Rear Projection...
Samsung HLR5067WX 50" Rear Projection HDTV Logo
187 people viewed this question
Jerry Greenberg
Jerry Greenberg
