Question about Toshiba 65H83 65" Rear Projection HDTV-Ready Television
How to separate base and top to move upstrairs
How to separate base and top to move upstairs
    President:
  • 1,284 Answers
There was a guide that came along with your owners manual that has instructions on how to take the upper half off of the lower half. Unfortunately that's the only help I can offer.
Posted on Nov 12, 2009
  • mustangalley Oct 25, 2010
    a link to the manual on how to disassemble the split cabinet would be helpful
  • Don
    Don Oct 25, 2010
    Here is a link for the owners manual.
    http://www.tacp.toshiba.com/televisions/...
Ive taken all the screws (that I can find) out, but cannot separate the blue base from the black top. Does anyone know what might be keeping them together?
if the base has rubber feet ( blocks to protect furniture or to prevent it moving around
try removing the fixing screw in that block
Sep 17, 2016 | Memorex MP3851SP Radio/CD Boombox
How do we move our Simmons Nuflex base?
Nice information. Thanks for sharing this.
packers and movers chandigarh
All Services
Apr 26, 2014 | Simmons NuFlex Adjustable Bed Foundation
Just moved in yesterday and the Honeywell thermostat is not working properly. the down stairs has diffent kinds but the up stairs rooms have the Honeywell thermostat. we set the temp. to 60 degrees but it...
Sounds like the programming on your thermostat needs to be reconfigured, but I need more information like the Honeywell Model number which can be found behind the front cove, but becareful to unsnap the t-stat properly not to damage the pins that connect t-stat to its base.
Jul 25, 2011 | Honeywell Programmable Thermostat Heater
I moved into a place that has a MasterCool Evaporative Cooler on the roof. The ownstairs is quite comfortable so I really only need to cool the 2nd story.... it seems as if all the cold air settles...
jbrown - Hot air rises, Cold air falls. If you have ceiling fans upstairs, turn them on to run counterclockwise at highest speed you can stand. Make sure all the windows are closed upstairs. The ceiling fans will help to keep the cool air upstairs and pull some from downstairs.
If you don't have ceiling fans, invest in a box type fan that you can place at the head of the stairs (that's the top of the stairs) run it on HIGH and it will act like an exhaust fan, by pulling cool air upstairs. It may take a while, but it will help cool the upstairs to some degree.
Hope this helped you. Please let me know. Thanks.
Jun 24, 2011 | Mastercool 67471 Evaporative Cooler Air...
Not enough heat
Take an Amp draw on all heaters and compare. If within 5%, they are working fine but you may have more open area downstairs than up.
Mar 03, 2010 | Heating & Cooling
Washer Tub appears top be off center after move upstairs. How do I remove cover to check? kenmore washer model # 100.24812200
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
IF THIS IS A BRAND NEW INSTALLATION - be sure you hav removed the basket shipping pins (4) that secure the tub during shipping.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 08, 2009 | Kenmore Washing Machines
Agitator not moving--seems loose
This washer has what we call a bionic agitator and this agitator has a 2 parts:
it has a base and a top section.
IF the BASE IS NOT WORKING AT ALL, please have the transimssion checked and also check the coupling.
IF the BASE is working and the top is NOT
THEN replace the 4 plastic AGITATOR DOGS that are in the agitator.
Remove the CAP from the agitator...remove any plastic cap.
Get a socket wrench and get the socket that removes the bolt.
remove bolt...
PULL the agitator from the base and separate the top from the bottom.
Take the top and turn it upside down to remove the platic interior part that holds these 4 dogs. REMOVE the old dos and replace with new and do a reverse engineeriong putting agitator back.
Nov 20, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Toshiba 65H83 65" Rear Projection HDTV-Ready Television Logo
192 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
