Question about Bose Lifestyle 38 System
No sound from Direct TV box
We had a power hiccup and the system now has no sound. We can play DVD's ok - but no sound with the service from the cable box. Can't get it to give us audio signal
  • 14 Answers
Unplug the Bose Media Center from the wall. Leave unplugged for approximately 30 minutes. Then plug the unit back in. Allow a few minutes for the Media center to initialize. Your sound should return as normal.
Posted on Feb 03, 2008
Cannott get a picture on my tv from my DVD/VHS COMBO
Your DVD player should be connected to either the Yellow White Red connections on your TV set (same color to same color -- dvd OUT to tv IN )
OR it should be connected using the RF cables and connected inline AFTER the Direct TV Box....the box would block the DVD; and possibly the Direct TV Master box would apply 19 Volts to the DVD modulator....destroying the modulator.
Always OUTput to INput on the connections...
Also try with a new set of connections. make sure all the ports are ok.
Hope It's resolve all Problem,
Or
Still having Problem Then follow Us For
Tech support
Feb 07, 2014 | Televison & Video
Get RCA DVD Player to work.
ok on dvd player u wann use hdmi cable direct to tv ok then select input hdmi on tv remote to see picture
Feb 02, 2008 | Thomson Lyra PDP2860 Digital Media Player
Can't change to channel 3 to use the dvd player
Your Vizio TV should have provisions on the rear panel for direct connection of your DVD player. Use those connections and select your DVD player as a video input.
Mar 08, 2018 | Vizio 42 in. LCD TV
I have a Coby DVD938 hooked up through a cable box. The sound is fine when a DVD is playing, but when the TV plays, the sound is very quiet. I tried hooking the audio wires direct to the TV and had the...
You're Going to have continuous problems like that with your current configuration. You should plug your video and audio cables directly to a separate input into the back of you set. That's provided of course that you have another input on the set. If your set and dvd player are HDMI cable capable then you also would have typically another hdmi input. In that cast you don't need separate audio cables. The audio is carried as a digital signal in the HDMI cable.
Oct 28, 2013 | Coby DVD938 Theater System
My tv sound is schreeching
OK sounds like you have problem on your cable box connection or signal..Try to play a dvd to test. If the sounds fine on DVD you definitely have cable box prob.
Dec 10, 2012 | Dell U2711 27 in LCD TV
My power went of a for about 8 hours last night and when the power was restored everything works except I cannot hear sound on my BT730 sound system while listening to TV through the cable box. I can hear...
Trace the TV audio back to its source - TV or Cable Box most likely. We have no way of knowing which. Substitute in another source to test the input.
If DVD audio works so does the basic HTS.
Sep 07, 2011 | Panasonic Home Theater System System
Direct tv hdbox & Plasma TV & DVD SSound system & DVD recorder
Need to make sure you have the red,white,and yellow rca connection cables ran from the samsung dvd player to the red,white,yellow input on the back of the dvd recorder. Once you do that make sure you put your dvd recorder on line 1 input. If you look closely on the back of your recorder it should say line 1 input. If your recorder isn't on that input you can put the recorder on line 1 input by using dvd recorder remote and pushing the input button. Make sure you don't push the tv input button the dvd recorder remote there should be a seperate input button or a way to toggle the inputs on the recorder. Once you verify all that turn on your tv and go to the input on your tv that you watch the dvd recorder on and you should see what your recording on the tv.
Nov 20, 2008 | RCA RTD155 System
DVD Player won't show recordings on my TV screen
put the dvd player on the same channel as you set your Tv when wathing direct tv. and try recording
if you are using rca push on cable yellow,red ,white set to your A,V audio,video channel
when recordining you will be changing channels on the direct tv box
do you have a manual for dvd player read that really good that might help.
Sep 28, 2008 | Sanyo DRW-1000 DVD Recorder/VCR
How do I get my tv to play through the surround sound
If you have direct cable into the television, you will need to use an audio output if available on the back of your set into your HT system.
If you are using cable w/ a cable box you have two options. You can still connect everything directly into the TV then reroute the audio to the HT system... or, you could hook only video to the TV and audio from the cable box to the HT system. Really up to you.
Mar 04, 2008 | Panasonic SC-HT680 System
New home theater setup- no signal at tv using onkyo tx=sr605
Could well be the quality of your cables. if you have high end cables the consult a service agent. if you have the cables that came with the products, go and get some better ones.
Nov 04, 2007 | Onkyo TX-SR605 Receiver
Bose Lifestyle 38 System Logo
2,793 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
