Question about Kenmore Dryers
KENMORE DRYER FIN LOSE. PURCHASED IN 2002. HOW CAN I FIX?
  • Kenmore Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
You will have to remove the drum to try to repair the fin
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
You can now check the drum to see how the fin is attached, but also
now is a good time to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots, if they have flat spots on them replace them.
If the drum rollers don't have flat spots on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Posted on Nov 14, 2009
How to clean fins in my dryer?
You must remove the vent shroud to clean out the fins on the blower wheel.
Jul 19, 2014 | Kenmore Dryers
Two of the three internal fins in the dryer came loose and detached from the inside of the dryer. Now the dryer is losing heat where the installation holes are located. Can I purchase new fins and install...
if you open the dryer by removing the top and front panel/door assy you can look at the bottom of the unit and find the old screws, buy the new fins, and re attach them if the holes in the dryer where the screws attach to the fins are too large for the screws use some washers
Jan 06, 2010 | Maytag Dryers
I have a Kenmore Elite electric dryer that we purchased in 2002. It suddenly stopped working - no light inside dryer, drum doesn't turn it is like all of a sudden there is no power to the appliance. My...
Sounds like you need to replace your electrical breaker in the main control box of the house that feeds the dryer. You should get 120volt on each leg coming into the dryer. Good Luck, I hope this helps Please rate me, Thanks
Dec 26, 2009 | Kenmore 63942 Dryer
Kenmore dryer- remove fan to change motor on dryer.Do I need a gear puller to remove ? 7 yr old 90 series dryer ,seal drum came lose from damage to dryer when purchased. Did not relize damage until motor...
The wheel has left handed threads. Use an impact wrench and an adjustable wrench to get it off or get a vice grips or pipe wrncha nd lock down the shaft then get a stick of wood or a hammer handle and shove it in between two fins at the 3 oclock position. Slam downwards on the wheel and it should pop loose.
Mar 22, 2009 | Kenmore 659 Electric Dryer
Accumulation of pet hair inside dryer
easiest thing to do ,, if you have a vaccum ,,just vaccum off lint and debris ,,,,
Jan 02, 2009 | Kenmore 63942 Dryer
Coins stuck inside dryer fins
raise the top and there are 2 1/4 screws running into each fin ,,,,, take screws out and dump fin and that wit do it for you / larryyb
Nov 30, 2008 | Kenmore 74602 Gas Dryer
Kenmore elite drum baffle dryer
remove the top panel and each fin has 2 5/16 screws holding them to the drum. turn the drum so the fin is on top and remove the screws then remove the coins
Oct 18, 2008 | Kenmore 88752 Top Load Stacked Washer /...
The "fin" inside came off
if i remember right ..remove washer top remove hose or pug in top of outer tub rotate basket until fin is at top i believe you can acess screw through hole..of course i have been known to remember wrong and apologize if i have this time let me know
Aug 19, 2008 | Kenmore Elite 45986 Front Load Washer
Dryers Logo
197 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
