Hitachi 42V715 Rear Projection Television Logo
Anonymous Posted on Nov 12, 2009
The people in the center are green but edges(1" top 4" sides)are fine.
Chi Chu
Level 3:
  • Hitachi Master 8,457 Answers
  • Posted on Nov 12, 2009
Chi Chu
Hitachi Master
Level 3:
Answers
8457
Questions
0
Helped
2822983
Points
26282
Convergence it dead,Know how to solders?Buy a convergence kit,used what in that kit.Tries these websites Tv repair World.com,Repair kits.
Testimonial: "thanks"
Toshiba 255 photo copier..c410 error code what can i do for that
fuser related code
Check if the connectors are disconnected.
2. Check if the center, side and edge thermistors are in contact
with the surface of the fuser roller properly?
3. Check if the center, side and edge thermistors are not
deformed or dirty.
4. Check if the harnesses of the center, side and edge
thermistors are open circuited.
2. Check the heater 1. Check if the heater is broken.
2. Check if the connector of the heater is disconnected.
3. Check if the harnesses are connected properly to the
terminals of the heater lamp.
4. Check if the thermostat is blown.
3. Check the LGC board 1. Check if the connectors CN308 are disconnected.
2. Check if the conductor pattern on the LGC board is short
circuited or open circuited.
3. Replace the LGC board.
4. Clear the status counter After repairing the matter which caused the error, perform the
following:
1. Turn ON the power while [0] and [8] are pressed
simultaneously.
2. Key in "2002", then press [START].
3. Change the current status counter value "1" or "2" to "0",
then press [OK] or [INTERRUPT] (to cancel the error).
4. Turn the power OFF and then back ON. Make sure that the
equipment enters the normal ready state.
2answers
Projection HDTV Pansonic 47" Curving blue and green colors on top and bottom of screen.
You will need to replace your two convergence I.C.s.They are two large IC mounted on a large aluminum heat sink.Replace both,look for any burned resistors near them,replace those if needed,and readjust your convergence. Good Luck
Let me know if you need any further help
How to change the belt on dryer
CHANGING THE DRIVE BELT
1. Remove the top cover and the rear panel.
2. T720/780: Remove the external fan housing.
3. Remove the special tool.
4. Remove the belt from the belt pulley and take off the belt.
5. Feed the belt over the drum onto the motor shaft and over the belt pulley.
6. Install the special tool.
7. T720/780: Replace the external fan housing.
8. Replace the rear panel and top cover.
_____________________________________________________
REMOVING THE TOP COVER
1. Remove the three T20 screws at the rear of the top cover. (Keep the two star washers.)
2. Tilt the cover and pull it backwards.
25758001-gtkp3url2ghtdqenstp5bokb-1-0.jpg REMOVING THE REAR PANEL
1. Remove the top cover.
2. Unscrew the centering nut until the face of the nut is level with the end of the thread and knock out the bearing.
3. Fit the special tool (part no. 88 011 54) by fitting the tube end into one of the stamped out keyholes in the front rail. Lift the rear edge of the drum and press the drum edge onto the roller.
4. Remove the ground connection (yellow/green wire) from the input terminal block (see pages 8 and 9).
5. Take the cable bundle out of the cable clamp and pull the header block off its terminal pins.
6. Remove the wiring:
T700/T720: R1 a, R1 b, R1 13, R1 14, R1 34 on the contactor.
T760/T780: Ra, Rb, R13, R14, R34 on the contactor and F3 and F4 on the radio interference filter.
7. T720/T780: Remove the hoses to the water tank housing.
8. Remove the centering nut and the eight screws.
NOTE: Do not remove or loosen the screws around the heater housing or drum bearing.
9. T720/T780: Remove the three plastic screws at the lower part of the rear panel.
10. Lift off the rear panel.
25758001-gtkp3url2ghtdqenstp5bokb-1-5.jpg 25758001-gtkp3url2ghtdqenstp5bokb-1-20.jpg
25758001-gtkp3url2ghtdqenstp5bokb-1-27.jpg REMOVING THE EXTERNAL REAR FAN HOUSING
1. Remove the top cover and rear panel.
2. Unclip the external rear fan housing suction side.
3. Unscrew the 10 mm nut on the external rear fan wheel and remove it.
4. Lift the external rear fan housing motor side and pull it toward you.
Dado
Doorhandle
for passenger side:
1. unclip screw cover 'center flap' of inside door opener plastic cover, flap is 3/8"x 3/8" (center of plastic cover)
2. remove phillips screw now showing
3. push fabric panel (edge of door opener plastic cover-at hinged end of chrome handle) to allow uncliping of edge of plastic cover (top rt & lwr rt (for passenger side) of plastic cover)
4. open chrome inside door handle to allow plastic cover to be removed-slide plastic cover toward rear, free end of door to remove cover
5. remove switch panel-gently pry with wide non maring pry bar (cover wide blade screwdriver using cloth) do rear of sw panel 1st (don't pry front edge)
6. slide switch panel toward rear to allow removal
7. remove large phillips screw under sw panel
8. remove the 2 plastic covers near top, hinge edge -use plastic spoon handles to encourage caps to pop off. May also require small screwdriver approx 1/8" in to complete pop off
9. remove the 2 phillips screws w/ captive washers
10. remove 3 phillips/hex screws along the bottom inside of door panel
11. on outside/rear edge of panel push the 2 center pins of each in about 1/8"-this allows the clip to be pulled out w/ pin pushed in
12. remove plastic cover (REAR OF SIDE MIRROR)-pull window edge up and back.
13. lift rear of door panel (not hinge edge) up allow hinge edge to pivot around lower pin in door (hinge edge)
14. remove the 2 rt edge "L" brackets (gently pry center plastic pin out) (note the color and replace as removed)
15. slowly peel the clear plastc away from the non hinged end to expose the plastic panel with 3 phillips head screws
16. remove the 3 screws and panel for access to door handle.
17. using access area now available unlatch the rod attached to exterior door handle (unclip plastic to rotate clip up to allow rod to slide out-toward hinged edge)
18. using access area now available remove rod from ext door handle from inside door area
19. remove the 3 -10mm head bolts
20. remove the ext door handle (bottom edge out first)
reverse order to replace door handle
1helpful
How to connect front panel to acer power s290 motherboard
http://www.ascendtech.us/acer-aspire-sa90-mbs7109002-motherboard_i_mbacembs7109002.aspx
The front of your computer is the Front Panel.
The area of pins on the motherboard, that the main wires from the Front panel go to, is the Front Panel header.
Looking at the Front Panel header it is parallel to the outside edge on the bottom/right of the motherboard.
13 pin header.
6 across the Top row with 1 pin missing, 7 across the Bottom row.
Top row is numbered EVEN
Starting on LEFT side coming across to the Right, Top row;
Pins 2, 4, 6, 8, No Pin, 12, and 14.
Pins 2 and 4 have a Green area
Pins 6 and 8 have a Red area
No Pin 10.
Pins 12, and 14 have a Yellow area
Bottom row is numbered ODD.
Starting on LEFT side coming across to the Right, Bottom row;
Pins 1, 3, 5, 7, 9, 11, and 13.
No Pin 10.
Pins 12 and 14 have a Green area.
A) Pins 2 and 4 in the Green area (Top left) are for the Power On LED
Pin 2 is for the Positive ( + ) wire.
If the Power On LED is dim when the computer is on, switch the wires around.
B) Pins 6 and 8 in the Red area are for the Power On switch.
C) Pins 12 and 14 are N/C. Not Connected
D) Pins 1 and 3 in the Yellow area, are for the HarDDrive activity LED light.
Pin 1 is for the Positive wire.
If the HDD LED is dim when the harddrive is active, switch the wires around.
E) Pins 5 and 7 in the Purple area, are for a Reset switch, IF a Reset switch is used.
F) Pins 9, 11, and 13 are N/C.
(Pin 9 is 5 Volts DC. Used by the factory for testing)
Regards,
joecoolvette
(I thought the internal speaker was that round little 'buzzer', below the bottom white PCI slot, (PCI 2), and close to the edge of the motherboard )
1helpful
How can I make a really cheap sofa table?
Cut ListCut List: A) 4 - 1x3 @ 29 1/4" (Fronts and Backs of the Legs) B) 4 - 1x2 @ 29 1/4" (Sides of the Legs) C) 2 - 1x3 @ 10" (Side Support) D) 1 - 1x2 @ 37" (Stretcher) E) 2 - 1x3 @ 37" (Side Trim for the stretcher) F) 2 - 1x4 @ 10" (Side Apron) G) 2 - 1x4 @ 37" (Front and Back Apron) H) 1 - 1x12 @ 48" (Base for the top) I) 2 - 1x4 @ 11 1/2" J) 1 - 1x12 @ 41"
Step 1
Download Original]'>untitled-3%20(15).jpgConstruct your legs by nailing through the 1x3 legs into the edge of the 1x2 legs with 2" nails and glue. The legs will be positioned with the 1x3s to the front, 1x2s to the side, as shown in the diagram.
Step 2
Download Original]'>untitled-4%20(14).jpgStart by marking each of the legs 5" from the bottom of the board. This will be the bottom of the side support, C. Nail C to the legs, using 1 1/4" nails and glue, from the inside.
Step 3
Download Original]'>untitled-5%20(13).jpgNow add the stretcher, D, centering D on the support, C, but keeping the top edges flush. D will lay flat, with the wide side up. This is demonstrated above. Use glue and 2" nails, nailing through the support, C, into the end of D.
Step 4
Download Original]'>untitled-6%20(9).jpgAdd the side trim pieces, E. First, nail through the supports C into E, using 2" nails. Then nail down the length of the stretcher, taking care to keep the top edge of the stretcher (D) perfectly flush with the top edge of the stretcher support (E). Use glue and 2" nails.
Step 5
Download Original]'>untitled-7%20(8).jpgNow use the 1 1/4" nails to nail through the back of the side apron pieces, F, into the legs. Use glue. Keep top edges perfectly flush.
Step 6
Download Original]'>untitled-8%20(7).jpgDo the same for the front and back apron pieces, G, as shown above. Nail through G into the legs using 1 1/4" nails and glue. Keep top edges flush. Take a minute to check for square
Step 7
Download Original]'>untitled-9%20(7).jpgNow add the base top, piece H. Keep the front and back edges flush with the legs, but let the sides overhang 4" on either side. Nail into the legs and the apron using 2" nails and glue.
Step 8
Download Original]'>untitled-10%20(6).jpgUse glue and 1 1/4" nails to attach the breadboard ends to the base top. Keep all outside edges flush.
Step 9
Download Original]'>untitled-11%20(5).jpg I recommend not cutting the final piece, J, unitl you have taken an exact measurement. Add the final piece, using glue and 1 1/4" nails.
Finishing Instructions
May 29, 2012 • Furniture
57wv600 blinks 7 times, no picture, or blue for few seconds
1. Remove the 5 screws from behind each speaker
2. Grasp bottom center of plastic panel and "pop" forward. Swing upward to remove.
3. Remove 4 screws from the wooden panel in center.
4. There is a "black box" in the very front of electronics. It will have torque paint on the 2 rows of 3 screws. top row is labeled "focus"
MY TV would go green before going black. Volume still worked.
5. I turned the center bottom screw (marked "green") appx. 1/8 to 1/4 turn COUNTER clockwise.
Plugged TV in and it works fine.
18helpful
2answers
How do you remove Tailgate interior PANEL on Ford Freestar 2004 tailgate door
Remove the 2 bolts from handle, #2 from picture. Remove 2 screws from either side of door pane(#4) now just the clips hold it on, pull panel off at one corner and work your way around until its completely removed.
Thank you and good luck,
Lee
13helpful
How do I remove the radio from a 1998 Honda CR-V?
UNSNAP PUSH-PIN FASTENERS FROM BOTTOM OF CENTER CONSOLE
AND REMOVE BOTTOM PANEL.
2. EXTRACT 4 SCREWS FROM BOTTOM EDGE OF BEZEL. EXTRACT 4
SCREWS FORM INSIDE DASH BELOW POCKET. PULL CUP HOLDER/
POCKET ASSEMBLY OUT OF DASH AND REMOVE.
3. OPEN GLOVE BOX AND REMOVE STOPPERS. EXTRACT 2 SCREWS
FROM RIGHT SIDE OF CENTER DASH BEZEL..
4. FROM BELOW STEERING WHEEL EXTRACT 2 SCREWS FROM BOTTOM
EDGE OR PANEL, UNSNAP UPPER EDGE OF PANEL, UNPLUG, AND
REMOVE.
5. UNSNAP TOP EDGE OR CENTER LOWER BEZEL, UNPLUG, AND REMOVE.
6. EXTRACT 2 SCREWS FROM SIDES OF POCKET.
7. UNSNAP RADIO/AC CONTROL DASH BEZEL, UNPLUG, AND REMOVE.
8. EXTRACT 2 SCREWS FROM EACH SIDE OF THE RADIO BRACKET
ASSEMBLY TO REMOVE RADIO FROM DASH/AC BEZEL.
Kenmore Dryer Drum Felt
i know have to ck myself on those sometimes the stitch closest to the edge of the seal goes toward center of drum..you will also have to stretch the seal around edge of drum 4 hands make it easier
Aug 01, 2008 • Dryers
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
