Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Red and blue ghosts
My TV has red and blue shadows around everything on the screen. I cannot get the convergence to work. The crosses will not move to line up. Thank you, Lorrie
    Novelist:
    Champion:
  • 211 Answers
You most likely have a convergence chip bad. In our shop, when we are working on projection TVs, we find that about 80% of the repairs we make are the same problem you are having. You need to replace the convergence chip ( there are 2 of the same chips on the convergence board, and I suggest you replace both ). If you are going to attempt the repair yourself you'll need to remember to use lots of heat sink grease so you don't have the same problem again. Also, try to get original parts, as there are times that the after-market ones don't work well. As a precaution, always remember to unplug the set from the wall before you do any work on the set. Good Luck
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 08, 2008
I stumbled across a tutorial on fixing the convergence for my Sony KP-46WT510 a while ago, and now I can't find it again! Does anyone know where I can find that tutorial or one similar to it? We've been...
Here is a walk through on how to set your convergence.
A quick and easy way to try and let the TV realign the convergence try this...
1) Turn on the TV and tune to a channel and let it warm up for about a half an hour to let everything settle into its normal operating mode.
2) Press the Flash Focus button on the original TV remote. A cross pattern will show on the screen and the process is complete when the cross turns white and the TV returns to the program you were watching.
3) Do not press any other buttons until this process has completed.
If this does not adjust it enough you can adjust the convergence manually as follows:
1) Press the menu button on the original TV remote.
2) Use the arrow keys on the remote to highlight setup and press + button to select.
3) Use arrow keys to select convergence and press + button to select.
4) A pattern of white crosses appears, with a yellow [ ] around one of the
crosses. Aligned crosses (which do not need adjustment) look white and
have little or no red or blue showing. Crosses that are not aligned show
red or blue shades beyond their edges.
5) Use the arrow keys to move the [ ] to a cross that is not aligned. ***Note: start with crosses in the middle and work outward ****
*** TIP: Set the alignment while about 5 feet from TV for better results ****
6) Press the + button to select the cross and the [ ] will turn red indicating it is ready to adjust the Red convergence.
7) Use the arrow keys to move the red cross on top of the white one or at least as close as you can get it.
8) Once the Red is aligned press the + key again and the [ ] will turn blue. This indicates it is now ready to adjust the blue convergence.
9) Use the arrow keys to move the blue cross on top of the white one or at least as close as you can get it.
10) Once you have aligned the blue cross press the + button again and the [ ] should turn yellow.
11) Repeat steps 5 through 10 until all the crosses are aligned. To exit back to regular programming press the menu button on the remote.
Jan 08, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
HITACHI 57UWX20B has blue ghost shadows how do I
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Jan 05, 2010 | Hitachi 57UWX20B 57" Rear Projection...
Blue shadow
Your TV most likely has a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Using your original remote go-to the tv settings then goto the convergence section.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jun 20, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Red ghost image or shadow
It sounds like the color wheel has gone bad and needs to be replaced. This is located behind the back panel... replacing a new colour wheel will solve ur problem
rate me
Jun 11, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Covergence out of alignment on 1/4 Vertical left side of screen
You need to manually adjust the alignment:
On remote, press Menu to get to the main menu
Then arrow down to "ADVANCED FEATURES"
Then press "enter"
Then Arrow down to "CONVERGENCE" and press "enter"
"Red Convergence" should be highlighted
Press "enter"
You now have Green, Red, and Blue overlapping crosses.
If Red is out of whack, use arrows to align
To toggle to blue (and back to red), press "VIDEO"
Then align blue cross
Once the crosses look aligned, and nice and white, press "AUDIO"
This will bring up the Advanced Convergence screen
This is a grid of the same overlapping colors
You have control over the Red and Blue
If Green is very out of whack, you'll need a repairman…
While the "target" is flashing, you can move it around the screen with the arrows
Place it over an intersection to adjust, then press "enter"
Now the "target" is steady (not flashing), and you can use the arrows move your color
When it's aligned, press "enter" again
Now "target is flashing, and you can go to the next square.
You cannot adjust every intersection.
Some areas need to be adjusted via the adjacent intersection
When you're happy with color you're working on,
Press "video" while target is flashing to change to the other color
Repeat the above (blue is much harder to see and adjust for me…)
When you're happy with the entire grid, start hitting "Menu"
Each press brings you back out one menu level, until you are out of them
Once you're used to the process, it should take no more than a minute or two.
Mar 02, 2009 | Mitsubishi WT-46805 46" Rear Projection...
I have a red and blue shadow in my picture
i think you need a new convergence board they rin from about 88.00 to about 140.00
Sep 08, 2008 | Akai PT5598HD 55" Rear Projection...
Mitsubishi rear projection tv
replace vertical IC and shadows/ghosting the problem is either electrolytic capcitor or video IC or convergence adjustment
Aug 18, 2008 | Mitsubishi WS-65809 65" Rear Projection...
RED SHADOW AROUND IMAGES of SONY KP-57WS510 RPCRT
Your set uses two STK392-560 convergence ICs they are attached to a large heat sink on the D board. You can save your self about 400 for a twenty minute repair by getting new ICs at the following link as trhey provide free instalation instructions with pics so you can do the job yourself. It only requires basic soldering skills I would order about six 4.7ohm 1/2 watt resistors as well just in case you need them asusually sonys' will burn one or two of the 4.7ohm convergence resistors when the ICs fail. Heres the link
http://servicemanuals.vstore.ca/
May 18, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
Convergence
When this happens it means the convergance Ic's have failed ( STK392-110's) they will need replacing then the cross hairs will move again
Feb 07, 2008 | Panasonic PT-56HX40 56" Rear Projection...
Blue shadow
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 25, 2007 | Toshiba 53AX61 53" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
32 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
