Question about Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher
Bosh dishwasher 546 will not fill - Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher
  • 460 Answers
Either the fill valve is bad or the timer control is bad call a certified serviceman and have it checked out ...
Posted on Nov 12, 2009
2 Suggested Answers
bugsy33
  • 33 Answers
SOURCE: bosh dishwasher wont fill...also sink drains right intodiswasher.
sounds like your plumbing in your sink is going wrong way check pipes or your sink maybe have a clog in it
Posted on Dec 05, 2009
My bosh exxcel disher dose dot fill
Hi
Thanks for using FixYa. To start with check the water inlet valve which is located behind the lower access panel on the left or right side of the Dishwasher. If the water inlet valve is bad you have to replace it, also check the main water line for clogs/obstructions. If still the issue is not resolved then it’s a bad float switch and needs to be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 03, 2010 | Dishwashers
Bosh dishwasher wont fill...also sink drains right intodiswasher.
Nov 21, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Hi my bosh dishwaser wont fill with water
check dicharge hose needs to be 3/4 high on dishwasher about 18 in above floor
Sep 11, 2009 | Bosch Dishwashers
Bosch dishwasher sps546 will not fill. switches on ok
you have to remove the cover of your unit in able to access the valve/.pump
Jul 08, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
BOSH SHU43 dishwasher
From my experience.. usually when a motor is humming it could be something is stuck in your impeller.. if your can get to your drain pump to check it out.. and getting to your drain pump can be a pain.. good luck.. hopefully that works
Jul 17, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
DISHWASHER
Make sure you have water coming to the dishwasher. Next check your dishwasher float. Make sure it is not sticking. If not you could have a problem with your fill valve. Check for voltage at the fill valve if you have 120V then you need a valve the solenoid is defective. Replace it.
Dec 24, 2007 | Dishwashers
Bosh dish waher
Does it make the same noise when it's just filling or just when the motor starts? Usually just filling the dishwasher opens a valve and doesn't run the pump. If it makes noise during filling the valve may be getting hot and shorting, or may have a loose connection, or air may be in the water supply line causing the valve to bounce. If it takes a long time to fill the filter may be clogged.
Nov 30, 2007 | Bosch 23 in. SHU 8805 Built-in Dishwasher
Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher Logo
115 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
