Question about Hitachi 55FX48B 55" Rear Projection Television
Tv shut off while playing wii game now it does not want to come back on at all please help i unplugged tv and plugged back into wall receptical and the red light comes on for a brief second like the tv is coming on then just goes back out and does not come on at all.
    Problem Solver:
  • 10 Answers
U shorted the tv
Posted on Nov 29, 2009
My wii stopped working
Is there power at the wall outlet? Is power reaching the Wii?
Jun 19, 2017 | Video Game Consoles & Games
WII IS ABOUT 2YEAR OLD.IT WILL NOT TURN ON....NOTHING
Wii - Power Problems
Please use the information below for all power-related issues with your Wii console. Some power problems are caused by unlicensed or damaged accessories (such as frayed wires on controllers, A/V cable, etc.). Avoid the use of these products.
Please select a topic:
No Power
    Most power issues with the Wii can be fixed by resetting the AC adapter. You can easily reset the AC adapter by following these steps:
      1. Unplug the Wii AC adapter at both ends (from the back of the Wii system and from the wall outlet or power strip). acunplug.png
      2. The AC adapter must remain unplugged at both ends for a full 2 minutes.
      3. We also recommend you unplug anything connected to the USB ports and the Nintendo GameCube Controller ports (such as LAN Adapters, keyboards, Nintendo GameCube controllers, etc.).
      4. While you're waiting, check the AC Adapter for the following:
        • Make sure that the word "Wii" and the model number "RVL-002 (USA)" molded into the AC adapter. Unlicensed products are not fully compatible and may not work correctly.
        • Check the AC Adapter for physical damage. Physical damage, such as frayed wiring or a cracked housing can cause the system to shut down. If your AC Adapter shows signs of physical damage and needs to be replaced, you can purchase one from Nintendo's online store.
      5. After you've waited 2 minutes, plug the AC adapter into the Wii system and directly into a wall outlet, not a surge protector or power strip. If the power light comes on and stays on, then it appears resetting the AC Adapter worked. If resetting the AC Adapter did not fix your power issues, please continue reading:
        • Avoid the use of unlicensed products such as memory cards, controllers, and cheat devices. Some of these products are poorly manufactured and may result in damage to your system. If one of these products is attached to your system, remove it and try resetting the AC Adapter (see above).
        • Check any accessories that connect to the Nintendo GameCube Controller ports or the USB ports of the Wii -- whether licensed or not -- for physical damage. Physical damage, such as frayed wiring or a cracked housing can cause the system to shut down. Remove any damaged products and try resetting the AC Adapter again (see above).
        • Make sure the Wii has good ventilation. Avoid operating the Wii while it's on carpeting or inside an enclosed space. If you have the Wii placed in a vertical position, make sure the vent on the bottom is lined up properly with the hole in the plastic stand and no foreign material is obstructing that hole.
        • Check the vents on the back and side of the Wii for dust build up. The system will shut down if it cannot vent properly to prevent overheating. If there is a build-up, remove it using a vacuum cleaner with a soft brush attachment.
        • Make sure that your wall outlet works. To check it, try plugging a lamp into the same outlet where your system was plugged in. Turn the lamp on the verify the outlet works. Also, make sure you are not using an outlet that is operated from a wall switch. If you do, make sure the wall switch is in the ON position.
        • Make sure the AC adapter is attached properly. Firmly plug your AC adapter into the back of the Wii (the port is labeled 12V IN) and into a working wall outlet (not a power strip or surge protector). Click here for detailed instructions.
        • Once plugged in, check the power light on the Power button to see if the system is receiving power.
      If the power is still continually shutting off regularly, please click here for repair options. For this particular symptom, it is best to include your Wii console's AC Adapter with your system. This will help our technicians ensure they are able to resolve your issue.
Aug 22, 2011 | Nintendo Wii Console
Was playing and someone came in and turned off the lights in the room, the power supply was hooked up to that switch and shut everything down. i tried to turn it back on and didnt work. tried changing the...
if you were either downloading a update or a game update or playing a game while it was loading you have a bricked wii
fixable but req some stuff
some way req hardware and software
others are only software
Oct 18, 2009 | Nintendo Wii Console
Wii console went dead... is there a fuse to reset the thing?
Try unplugging all the cords from the wii unit, wait about a minute or so, then reconnect the cords and power up. This should "reset" the system. A similar situation occurred with our system, and this was the solution we were told to try, and it worked. Good luck! :)
Sep 23, 2009 | Nintendo Wii Console
Wii system not powering up
There was a power surge which caused my WII to not power on anymore.
Unplugging the power adaptor fromt he wall for 5 minutes and then plugging it back in
fixed the problem.
Nov 08, 2008 | Nintendo Wii Console
Nintendo wii power problem
Unplug the power cable from the wall and the wii for 5 minutes so it can reset. It must be removed from the wii and the wall.
Jul 06, 2008 | Nintendo Wii Console
WII audio and TV audio simultaneously
do you have surround sound, if you do you will need to plug the wii hookups into the surround sound, or plug it into the tv and shut the surround sound off.
May 31, 2008 | Nintendo Wii Console
Televison & Video Logo
127 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
