Question about Royal 10X Shredder
Shredder will not start when paper is inserted. switch is on auto. This happened after a long session of shredding
  • 1,959 Answers
Two possible problems;
  1. Teeth underneath lid are jammed; sometimes (especially after a long session) although the papers go through, debris builds up and can get caught in the teeth; to clear unplug and with tweezers or a tina flathead screwdriver, pull out shreds of paper still caught
  2. Motor is overheated; once cool, try it again (move switch to reverse to see if motor is still working). If motor is working, see Step 1 for a jam; some jams can be cleared by running it in reverse. Royal doesn't recommend "long" shredding sessions. My unit recommends sessions of 20 pages or less. If you try to overwork the shredder, it will overheat and in some cases, fry the motor.
I hope this helps answer your problem. Best of luck!
Greg
Posted on Nov 13, 2009
Testimonial: "This confirms my fears. The motor is fried. "
  • Greg Margossian
    Greg Margossian Nov 13, 2009
    sorry to hear that Henry, my wife has fried 2 shredders that way! Thank you for the rating and best of luck to you!
    Greg
I have a staples spl-xc200d paper shredder. It runs on auto is that normal
If I understand the question then yes it should run on auto when the paper is inserted to be shredded. I have this shredder as well and mine is always set to auto.
Apr 19, 2017 | Staples Office Equipment & Supplies
Unit runs with nothing inserted into shredder
About 598,000 results (0.73 seconds) Search Results
    [PDF]Shredder Troubleshooting FAQ
    https://images-na.ssl-images-amazon.com/images/I/81GTHxKpz9S.pdf
    Make sure that the unit is securely plugged into a working outlet / socket. 2. If you have ... The shredder runs but it does not pull paper down. 1. Be sure the ... When ready to shred, be sure to insert material directly into the center area to start.
    [PDF]Instructions Manual
    https://images-na.ssl-images-amazon.com/images/I/71EUxqIkPNS.pdf
    you leave the shredder in the "Off" position whenever the shredder is ... To beginshredding, locate the switch on the unit and select the "Auto" mode (FIGURE 2). ...Your basic vegetable or cooking oil (nothing flammable ... a) While in "Auto" mode, the motor will not start running until paper is inserted into the feed slot. Set.
    General Shredder Troubleshooting - iThinkBlue
    store.ithinkblue.com/shredder-troubleshooting/
    Make sure that the unit is securely plugged into a working outlet / socket. ... While in "Auto" mode, the shredder will not run until paper is inserted into the middle ...
    [PDF]troubleshooting paper shredders - Ativa
Jan 31, 2016 | Shredder Office Equipment & Supplies
Overload light stays on
Most likely the cutters are still stuffed with paper shreds and needs to be dismantled and cleaned
Mar 29, 2014 | Honeywell Seven Sheet Micro Cut Paper...
Runs reverse auto
From your manual!
In case of a paper jam , which may occur if the shredder is pushed beyond its specified capabilities, press the control switch to the off [O] position and empty the basket if full. Then:
1) Press and hold control switch in reverse [R] position and attempt to back paper out of shredder.
2) If shredder jams in reverse mode, press control switch to automatic [I] position and attempt to continue shredding operation.
3) If shredder jams again, alternate control switch slowly between reverse [R] and automatic [I] positions to attempt to move jammed paper completely through shredder.
If you are unable to clear the jam using this method, turn off and unplug the shredder; remove the wastebasket from cabinet and carefully remove any paper extending below the cutting cylinders; empty the waste basket; insert waste basket and repeat jam clearing procedure.
Feb 01, 2014 | Fellowes DM12C Shredder
Only goes in reverse
Lube might not be necessary. Unplug the shredder from the outlet. Lift it off the shredded paper bin and turn it over. It is very possible that you have a jam. If this is the case, remove as much paper as you can making sure that you don't use anything that could do damage to the cutter'shredder blades. Once you have removed as much paper as possible, place the shredder back on the bin making sure that it is aligned properly. One way of making sure is to check for any space between the shredder and bin. If you do have space make sure that you replaced the shredder correctly on the bin; you may have to turn it around 180 degrees. When you get the shredder properly aligned, use the switch (DO NOT USE PAPER AT THIS TIME) to switch the shredder from Forward (shredding) to Reverse. You may have to do this a couple of times so be patient. At this point the shredder should be working in both directions. If so, move the switch to Auto or the center position and try a SINGLE sheet of paper. If it shreds that piece of paper, then you have fixed it. Be sure not to insert more paper than the shredder is rated for. Also, unless it specifically states that it can handle staples, credit cards, etc. do NOT let any of these items run through your shredder.
If none of the above works, buy a new one - :)
Jan 10, 2014 | Techko SH1524CP Shredder
Why doesn't OfficeMax OM99732 shredder work on Auto?
My shredder would not sense paper being inserted and the sensor could not be cleaned. So "Auto" no longer worked but the manual reverse DID work. I opened the thing up, reversed the polarity on the red and black wires on the connector for the main drive motor and VOILA!!! I can use my shredder in manual mode by switching it to REV. Be mindful that this keeps the motor running until it is switched off. This can heat the motor and cause failure so I limit my shredding to 60 seconds then give it a rest so it will cool down. Also there is no emergency reverse so watch your fingers and neck ties.
Dec 17, 2012 | Office Equipment & Supplies
Only runs in reverse
I just had this problem with my shredder. I think the problem started with a bin that was full. Running the shredder in reverse resulted in shredded paper being pulled up into the slot used to feed paper into the shredder. Some of this shredded paper was blocking the little plastic tab that activates the switch when paper is inserted, so the shredder would no longer start when paper was inserted. I emptied the bin and removed the shredded paper from the feed slot, being careful not to break the plastic "sensor" while removing the paper from under it. The shredder works fine now.
Dec 13, 2010 | Fellowes W11C Confetti-Cut Shredder
Runs only in reverse
Nov 06, 2010 | Fellowes W11C Confetti-Cut Shredder
Runs in reverse, but no on auto.
check and see if there is a jam of paper inside the unit or around the sensors
Jul 20, 2009 | Royal 10X Shredder
The shredder will run in reverse but will not run foreward.
Inside the shredder there is a motor which is wired to run both forward and backward, the way it does this is to transfer the power from the switch to a couple of wires on the motor
The forward running motor will be linked to the auto start button which will tell it to work with the paper sensor.
When you select the Forward function the Auto Start is taken out of circuit and the Forward switch should supply the motor
After all of that I would say that the switch is open circuit on the Forward contact and needs replacing
Jun 12, 2009 | OfficeMax 0M96431 Shredder
Royal 10X Shredder Logo
1,172 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Michael Vincent Cruz
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
