Question about Vacuums
Brush roller does not turn when vacum is on - Vacuums
  • jlkowerysr May 11, 2010
    What kind of vac do you have? Brand and model please. Have you checked the belt?
  • 701 Answers
Your belt is probably broken, stretched or worn and therefore not turning the brush roll. You can get replacement belts here:
Replacement Vacuum Belts
Posted on Nov 13, 2009
When the vacum is set on the bare floor mode, the on/off light blinks and the roller brushes stop working
This is normal. The roller brushes aren't needes on bare floors. They are used to brush lint, hair, etc. from the carpet that the suction itself wouldn't get.
Jan 28, 2011 | Dyson DC28 Animal Bagless Upright Vacuum
The roller brush stop working
the fuse in the plug may have blow so replace it any ways
Jul 12, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
My vacum roller brush dosenot work
The most common failure there is the drive belt from the motor to the brushes has failed. Consult your local vacuum store for a replacement. Normally they are fairly easy to change. Check and see if the brush is free wheeling or needs a push to get it to turn. If the belt is broken or worn out the brushes will turn freely.
Mar 30, 2010 | Eureka 2961AVZ Bagless Upright Vacuum
While vacuuming a rug on high (carpet setting) the power suddenly decreased. Now it will only run with low power, not picking up items on carpet
It sounds like you burned the belt. Turn the unit over, remove the cover plate where you see the brushes. On the side of the brush roller is where the belt is located. The belt should be very tight on the roller. Also, you may see little black rubber pieces stuck to the area where the end of the roller is or in the part where the belt runs. Get your owners manual out and read how to change the belt. I'll bet when you ran over the carpet it hung on some of the nap and hung the brush roller up for a second or so. That's all it takes sometimes to fry the belt on some vacumes. Sometimes new vacumes come with a new belt. Look in the bag or box and install it.
Mar 08, 2010 | Eureka 2991AVZ Bagless Upright Cyclonic...
Carpet roller brush will not turn
You probably need a new belt. You can get kenmore belts here:
Kenmore Belts
Jan 02, 2010 | Vacuums
The vacuum wont **** up anything anymore, and a rubber belt is now visible. What can I do to fix it?
i presume the vacume is a upright type. if the belt is visible i am also presuming the belt has broken, so turn the vacume up on its end so you can see the roller, you may have to take out a few srews to tak the base plate off which is covering the roller, take this off and you should see how the system works, the belt attaches to the moter spindle and then around the brush to turn it. take the brush out you should only need to pull it clean it and then go toyour local spares shop with the model number of your vacume and get a new belt, they cost about £1.00 each, put it back together and it should work....good luck.
Aug 22, 2009 | Vacuums
Vacum not sucking the dirt and the light is not turning on
loss of vaccum brush head not spinning check belt turn over remove bottem plate check belt assmble. remove any string or hair build up sear is the best bet for the belt
Mar 31, 2009 | Kenmore 34923 / 34925 Progressive Bagged...
Brush on vacum wont make contact with rug, no pick up
if you take off the brush then reorientate the ends of the brush this will adjust height ends have a block depending on orientation they will set brush height This is common for many brush assemblies and should work for dirt devil
Jan 16, 2009 | Dirt Devil Vacuums
Self propelled wind tunnel vacum will notpropell itself
Must be a Hoover, The flat belt may look ok but I am sure it has stretched to the point where under load it won't drive the wheels or the brush roll. Could also be a bad brush roll.
Nov 06, 2007 | Vacuums
Vacuums Logo
192 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
