RE: arver Sunfire Super Junior subwoofer. In attempting repair, I found Q12 shorted, gate to source(not to drain!), and F1 open. After replacing with exact cmpnts, operation returned to normal, however, when level cntrl was turned down after several minutes of testing, failure recurred(same cmpnts.), BUT this time R110 "smoked" beyound visible identification! Need to know it's value, and anything else I may have "overlooked" (Curious, everything seemed great for awhile after my initial attempt!)
  • 3 more comments
  • Larry Landos Nov 13, 2009
    Aforementioned resistor isn't in the line to Q12(MOSFET that shorted,type IRF640), but in the line to (lge.)output MOSFET,Q11(one of two), connecting drain of it to "common",of pwr supply(+&-163VDC). I really need an "expert" with the schematic diagram/pts. list to this(no doubt, highly"proprietary"(Carver)design)!The resistor in question appears to be a 1 watt, carbon-film type(hence the dramatic "flame-out"(why f.p. metal-film type wasn't used beats me!),and I assume with the high currents involved with a 1200watt(4 ohm woofer) it's value is less than an ohm. Additionally transistors Q13&14 in the gate circuit of failed Q12(and Q10, gates and drains of the two being tied together)check o.k.(so what is causing gate-source breakdown of(only)Q12 to be exceeded(intermittently)???
  • Larry Landos Nov 14, 2009
    Sorry, I don't think I supplied enough information; this Carver design is not the old-fashioned class-AB linear- type, but a class-D high-efficiency switching- type.
    I mistakingly mis-identified the resistor in question; it's R107,not R110! Of course, being carbon(not metal)-film type, it's burned and black, after failure measuring approx. 390 ohms. and then about 560 ohms after I cleaned all the"soot" off it and adjacent circuit board with methanol(more carbon mat'l. having obviously been removed). It must be rather low, originally, probably less than an ohm, phyisical size indicating 1-watt type. Being tied between the drain of one of the two large output- Mosfets and pwr- supply common, it obviously carries full spkr load current(spkr, by the way, must be 4 ohm, measuring around 3 ohms DC, with huge 25 pound magnet!). B-plus rails are plus and minus 163VDC.
    The smaller Mosfet that fails is paired with another(there are two pairs of these total, and they may be being used to modulate the B- voltage rails for increased efficiency), in a "switching-mode" fashion? Again, failure was not immediate, but after testing unit awhile with audio generator, 20 to 100Hz. Spec sheet of the IRF640 Mosfet(200V/18A) indicates max gate- to- source voltage to be plus and minus 20 volts(operating at 2 to 4 volts). I wonder if adding zener -protection would help? But I don't think trying to circumvent whatever the problem is in a sophisticated design as this is the proper course, though! These two pairs of Mosfets have a small smd-type NPN and a PNP transistor in their gate circuits, but disconnecting and measuring them indicates they are o.k. Interestingly, measuring gate-to- source of one pair of the IRF640 Mosfets with mm in "diode-check" mode indicated 0.7 volt (what zeners normally measure), while the pair with the one that failed was 1.07 volt (that's why I disconnected the small PNP and NPN's and measured them, but all four were o.k.)---
    I REALLY NEED A SCHEMATIC AND PARTS LIST WITH VALUES; CAN THE PRECEEDING INFORMATION BE SAVED AND FORWARDED TO ANY OTHER "EXPERTS" THAT ARE FAMILIAR WITH BOB CARVER'S UNIQUELY DESIGNED SUBWOOFERS???
  • Larry Landos Nov 15, 2009
    just see my previous postings!
  • Larry Landos Nov 17, 2009
    Guess no one out there's repaired one of these?
    Hi!-As I mentioned in an additional "pblm" post (which FIXYA apparently won't submit until first one is resolved), I mistakenly identified the location-number of the resistor in question- it's R107, not R110! (R110 is a smd-type,1/16watt, marked"202".i.e.,2k-ohm, not 22k!) Is your reference mat'l. for the correct Carver model?(SUNFIRE JUNIOR) As I mentioned before, R107 is a 1-watt carbon film type, which I believe is very low ohmage, judging by it's location in the circuit(connected between drain of large output Mosfet Q11 and power-supply"common",i.e.,junction of (plus and minus) filter caps C65 and C76). I observed the woofer- cone excurse to extreme outward- position at moment of failure(of Q12), indicating very large DC current which took out the resistor! Interestingly, outputs Q11 and Q7 are OK(not shorted), only Q12(re)shorted-any ideas what causes this? Also(perhaps a mistake) I noted fuses F1 and F2 were marked"T4A", which I thought indicated time-lag types, while markings on the board were only"4A/250V"; having replaced them with actual time-lag types, I wonder if this is why R107"smoked" when circuit re-failed(additional time for the large current to do it)? As I said before, SMD's Q13 and Q14 in the gate-
    circuit of Q12 check OK, so what could be causing gate- to- source breakdown voltage(spec:plus/minus20volts for IRF640) to be exceeded?(F1 is connected to drain of Q12). And the unit appeared to be working and sounding fine before re- failure. Where did you get the (supposed) value of SMD R110? A schematic and parts list would be greatly appreciated if you have access(I doubt going to Carver would be of any use, as these high-end "audiophile" companies generally limit servicing of their products to themselves; since the company I work for retailed this unit(which is now well out-of-warr) to my customer, I am trying to save him the time and expense of sending it to Carver!) Any more helpful ideas/suggestions would be great; otherwise, I'll have to give up on my"trial" membership with FIXYA and try to resolve this on my own-thanks!
  • 3 Answers
R107 is 1.2K. I have similar problem, if you do find a schematic, let me know. Thanks.
Posted on Jan 05, 2010
Testimonial: "Thanks, but I already got that value from Rita(Carver repair shop in WA)Found pblm on my own!etvservice@yahoo.com"
    Brigadier General:
  • 5,158 Answers
Is that resistor in the line to q12 ? if so it should be in the spec sheet for that device. if you don't have the spec sheet then let me know what q12 part number is.
Posted on Nov 13, 2009
To etvservice:
I have the same issue with R107 - smoked - in circuit reads approx 600 ohms - F1 also open. I have not had a chance to troubleshoot the Mosfets or any other circuits yet, but was wondering what you had found within your amp that was causing R107 to blow. Maybe you can provide some feedback? Also, the resistor appears to be a wire-wound style power resistor (instead of a standard carbon comp resistor).
Thanks
Posted on Jan 29, 2010
  • 3,741 Answers
The exact value of R110 is 22K Ohm resistor which controls the amp gain for the cabinet speaker.
check out.thanks.keep updated
Posted on Nov 17, 2009
  • 301 Answers
Have you considered sending it to Carver for repair? Maybe they can provide a schematic for you.
Posted on Nov 15, 2009
No sound plugged in with low green light on and connected properly. This unit worked perfectly for 3 years never an issue, now there is only a low hum, with no response to the input.
If the fuse has gone you would get no power at all. Subwoofers are basiacally mono amps that only put out bass tones. So when you get no sound the likely cause is the semiconductor that does most of the work that amplifies the signal. It could be an IC amp or FET or a Transistor, it could have an heatsink on it. But I would look to that for the cause of your problem.
Dec 16, 2012 | Sunfire Super Junior Subwoofer
Components Q12 & Q13 (2N 3906) PNP transistors fried. Would there be anything else blown?
It is sad your having a problem with Q12 and Q13, check the regulator
that supply voltage on the transistor 's your referring to.
Q13= 2SA1478 for Mackie SWA1501 Active Subwoofer
the supply is about +15V and -15V
Aug 20, 2012 | Mackie SWA1801 Subwoofer
Does anyone know what value the R99 resistor is on the true sub junior
R99 on the Sunfire True Sub Junior is a surface mount resistor (no color bands), and measures 51k ohms. R102 near it is colored gray, red, brown, gold.
Jun 16, 2012 | Sunfire True Sub Jr Subwoofer
Does anyone know the value of r87
10 ohms on the Sunfire True Sub Junior (R87 value).
Mar 15, 2011 | Sunfire True Sub Jr Subwoofer
I have a lyn 300 I need to replace the plastic cogs inside the arms which are worn allowing the motor to slip thus the gates will not open and keep slipping, how or where can i find replacenents parts ...
Manufacture is the way to go,buy parts and changing parts.Garage doors are hard to buy a small parts.U can used Ebay.com might find people or copannies sell used garage doors and motors
Aug 09, 2010 | Sears Craftsman LiftMaster Chamberlain...
Power up problem with alesis rs300 (ra300)
you have more than likely damaged some transistors.
the resistors have burned because of excessive current.
there are 2 typesof transistors,bipolar and mosfet
a bipolar transistor has 3 pins.1) base 2)emitter 3)collector.
an NPN is tested with the + meter lead on the base , and a PNP transistor with the - lead on the base.
TESTING
base to collector should read .5 to .6 v drop in one direction and open in the other with a digital meter on the diode check function.
base to emitter about the same,but slightly higher than the collector.
if base to collector is .5v then base to emitter is .52 or so.it is always higher than the base collector number.
between emitter and collector will read open in both directions.
if there is a short on any lead combination,the transistor is blown.
npn transistors operate on the positive rail power supply,and pnp on the negative rail.
typically a 150 watt amp will run + - 65vdc.
the transistors running on the plus side are npn and on the negative pnp.
most pnp output transistors are green.,but some are black,
so we must go by the numbers on the transistors, eg.A1076 is a pnp,B755 is a pnp and all transistors that have a C or D eg. D424 are NPN transistors. all A and B numbers are PNP and all C and D numbers are NPN.
MOSFET transistors have 3 pins 1)gate 2)drain 3)source
the source goes to power like the collector does. the drain is like the emitter,and the gate switches it on like the base does.
testing a mosfet is a different procedure.
a mosfet with k then a number e.g. k135 is a positive device like npn.
a mosfet with j and a number e.g. J50 is a negative device like pnp.
a mosfet reads open source to drain both directions.
for a positive (k number device) the plus meter lead goes on the source.,the black meter lead on the drain. on the diode test function.
jump a wire from the source to the gate for 1/2 second and remove the jumper while leaving the other two meter leads connected to the source and drain.The mosfet should switch on and the meter should show a short.that means the mosfet switched on.About 5 seconds later,the resistance from drain to source should go open.
for a p channel mosfet,it checks the same,except that the black meter lead goes on the source and gate .
a mosfet will stay switched on longer than the voltage applied to the gate,if it is driving a high impedance device such as a meter.
a bipolar transistor will not stay on when voltage is removed from the base lead.
i hope this has been of some help.
Sep 09, 2009 | Alesis RA-150 Amplifier
AR3 sunfire problems
Try http://www.simplyspeakers.com. Good Luck
May 09, 2006 | Acoustic Research AR3 Speaker
909 people viewed this question
 Grubhead
Grubhead
