Question about Linksys Wireless-G WRT54G Router
How do I get my WEP Key for my LINKSYS ROUTER
    Scholar:
  • 78 Answers
To access the web-based utility, launch the web browser on
your computer (INTERNET EXPLORER), and enter the Router’s default IP address, 192.168.1.1, in the Address field/bar. Then, press Enter. A password request screen will appear. Leave the User name field blank then default password admin. (You can set a new password from the Administration tab’s Management screen.) Click OK to continue.
The Internet Setup section configures the Router to your Internet connection. Most of this information can be obtained through your ISP/ your internet provider. Internet Connection Type Select the type of Internet connection your ISP provides from the drop-down menu. By default, the Router’s Internet Connection Type is set to Automatic Configuration - DHCP, which should be kept only if your ISP supports DHCP or you are connecting through a dynamic IP address. how do I get my WEP Key for my LINKSYS ROUTER - 68be046.jpg IMPORTANT: If you are using WEP encryption, always remember that each device in your wireless network MUST use the same WEP your wireless network will not function properly.
WEP Encryption Select a level of WEP encryption, 64 bits
10 hex digits or 128 bits 26 hex digits. The default is
64 bits 10 hex digits.
Passphrase Enter a Passphrase to automatically generate WEP keys. Then click Generate.
Key 1-4 If you did not enter a Passphrase, enter the WEP key(s) manually.
Click Save Settings to apply your chang
Posted on Nov 19, 2009
  • Linksys Master
  • 6,487 Answers
You need to use a computer that is working with your router now and then type this number on the internet explorer address bar 192.168.1.1 and leave the username blank and password is admin if the password admin not working try typing your commonly use password, once you're already on the router [age go to Wireless tab and then Wireless security tab and there you can get the WEP key...
Posted on Nov 13, 2009
I got a SONY PSP and it said that it scans through my Linksys WRT54G2 wireless router, it also says i need a a WEP key or a WPA key to make it work. what is the WEP or WPA key?
WEp key is your wireless security key
You can open the router page with ip address 192.168.1.1
enter user name = leave blank
Password =ADMIN
Enter the router setup page
Click the wireless tab.
Go to wireless security tab and below the wireless type there will be security key.
That is your key.
Sep 04, 2011 | Linksys WRT54G2 Wireless Router
Tip
How to set up WEP on Linksys Router
Setting-Up 152-Bit WEP Wireless Security on a Linksys Dual-Band A+G Wireless Router
Question
How do I set up 152-Bit WEP on a Linksys Dual-Band A+G Wireless Router?
Answer
Wired Equivalent Privacy (WEP) can be a 64-bit key with 10 hexadecimal digits, a 128-bit WEP key with 26 hexadecimal digits or a 152-bit WEP key with 32 hexadecimal digits. This encryption will prevent other users from connecting to a wireless network using your own WEP key. It will also protect your wireless transmissions/communications from being accessed or received by other users.
NOTE: Make sure to change the wireless settings of either Wireless-A or Wireless-G depending on the standard your network is using.
152-bit WEP key only applies to 5GHz 802.11a Wireless enabled network.
To setup WEP Wireless Security on your Linksys router follow the steps below.
Setting-Up the Linksys Router to use WEP
Step 1:
Access the router’s web-based setup page. For instructions, click here.
Step 2:
When the router’s web-based setup page appears, click Wireless then click WirelessSecurity.
Step 3:
Look for SecurityMode and select WEP.
For Wireless-A Settings:
4439-001.pngFor Wireless-G Settings:
4439-003.pngNOTE: If the screen on your router’s web-based setup page looks different, click here.
Step 4:
Look for the Encryption drop down menu and select 152 bits.
Step 5:
Look for Passphrase and type a wireless network password of your choice, then click Generate. In this example “MySecretKey” was used.
NOTE: You should come up with a password that is unique for your network and is a combination of numbers and letters up to 16 characters.
Step 6:
When you click Generate, the result will be a string of random characters.
Step 7:
Look for TXKey and select any number to determine which key you’ll be using. In this example, we selected 1.
4439-005.pngStep 8:
Copy Key1 since 1 was selected under TX Key.
NOTE: Do not give this key to anyone. This will be your wireless network’s key.
Step 9:
Click 4058-005.jpg.
© 2010 Cisco Systems, Inc. All rights reserved.
on Feb 26, 2010 | Computers & Internet
I need to know what the wep key is
Jun 10, 2011 | Linksys WRT120N Router
What is a WEP key for a Linksys WRT400N wireless router?
The WEP encryption key (network key) is in your wireless router, without this key the wireless router won't allow the computer or laptop to connect to this wireless router.
I recommend you use WPA or WPA2 encryption, it is much stronger than WEP.
The WEP, WPA, WPA2 encryption key is in your router's wireless settings. Log into your router and got to the wireless settings, you will need to get the SSID and the encryption key. Then go to your computer or laptop's wireless card and configure it with the router's SSID and encryption key, so it will then connect to the wireless router and the Internet.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Jan 01, 2011 | Linksys WRT400N Router
I want to encrypt a wireless network with wep
Question
Answer
Step 1:
Step 2:
Step 3:
Step 4:
Step 5:
Step 6:
Step 7:
4439-005.pngStep 8:
Step 9:
Click 4058-005.jpg.
Feb 26, 2010 | Linksys Wireless-G WRT54G Router
Cant find wep key
Your printer is saying that you should secure your wireless internet. Try resetting the router by holding the reset button located on the back for at least 30 seconds.
Nov 20, 2009 | Linksys WRT160N Wireless Router
Not sure of my WEP key on my BEFSR41 linksys router
The only way to see your WEP key is to remote into the router. Open a browser window, enter 192.168.1.1 in the address line and hit enter. When asked to login the default login is:
UserID: admin
Password: (nothing - as in do not enter anything)
IF this has not been changed and you get in, click on the wireless tab and you should find your wireless key there.
Good luck
Apr 10, 2009 | Linksys EtherFast Cable/DSL Router
Wep address
WEP address is your security key to get on the wireless network. New access point usually do not have one assigned. You need to get into the router and enter it in, like a password. If you haven't setup the network, then someone else did and you need to get the WEP key from that person. If you can get it, then you could reset the router to factory defaults by pressing and holding the button in the back of the router for 30 seconds. Let the router reboot and look for a wireless network called "LINKSYS" or "DLINK" or something like that. You should be able to connect without entering a WEP key. If your computer asks you for one then leave it blank or look in the manual for the default WEP key.
Mar 28, 2009 | Linksys Wireless-G WRT54G Router
Wep key for ps3
you will need to obtain your wep key no matter what...you can get it from whoever your router company is (if it is a linksys then call the linksys support number and obtain the key) in most cases thought the wep key is located on the router itself near the bar code. It will be a long number, When you get it and enter it in to the network settings then it should pick up the signal
Feb 09, 2008 | Sony Playstation 3 (PS3) Console
Linksys Wireless-G WRT54G Router Logo
863 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
