Question about Texas Instruments Office Equipment & Supplies
How do I graph on the T1 83 plus when an invalid
How do I graph on the T1 83 plus when an the error message :invalid dim appears?
  • Texas Instru... Master
  • 8,073 Answers
You must have done some statistical calculations. This type of calculations activates the statistical plots. The resulting configuration conflicts with the normal graph configuration.
Before drawing function graphs, you must turn off the statplots:
Press [2nd][Y=] to access (STATPLOT)
Press [4:PlotsOff][ENTER][ENTER] Calculator displays Done.
Then you press [2nd][0] to access the (CATALOG) of commands. Then [PGRM] to enter the letter [C]. Cursor jumps to the first command that starts with the letter c (omitting the Greek symbols). From there, scroll a bit to highlight [ClrAllLists] and press [ENTER][ENTER]. After clearing the lists the calculator displays Done.
You should be able to draw your graphs.
If that does not work, just reset the Ram as described below.
Press [2nd][+] to access (MEM)
Press [7:Reset][1:All Ram][2:Reset].
Press [CLEAR] to erase the Ram Cleared message.
Press [Y=] and enter your functions. Press [ENTER] at the end of each function. Make sure each [=] after Y1, Y2, remains highlighted after the cursor moves to some other location.
Hope it helps.
Posted on Nov 13, 2009
Fix the ERR:INVALID DIM message on my TI-84 plus, please.
INVALID DIM error message may occur if you are trying to graph a function that does not involve the stat plot features. The error can be corrected by turning off the stat plots. To turn the stat plots off, press 2nd, STAT PLOT , and
then select 4:PlotsOff.
Mar 26, 2012 | Texas Instruments TI-84 Plus Calculator
So on my graphing calculator i put my equation x^3-x^2-10x-8. then i hit graph and it says err:invalid DIM.
INVALID DIM error message may occur if you are trying to graph a function that does not involve the stat plot features. The error can be corrected by turning off the stat plots. To turn the stat plots off, press 2nd then stat plot, and then select 4:PlotsOff. By the way it is easy to graphing function y=x^3-x^2-10x-8.
See captured images: full graph and detail of the left side max
As you can see this function have zero values in the points -2, -1 and 4
Mar 04, 2012 | Texas Instruments TI-84 Plus Silver...
Error message invalid dimensions
y , and then select 4:PlotsOff.
Jan 19, 2012 | Texas Instruments TI-84 Plus Silver...
What does "invalid dim" mean?
The ERR:INVALID DIM error message may occur if you are trying to graph a function that does not involve the stat plot features. The error can be corrected by turning off the stat
plots. To turn the stat plots off, press {2nd}[stat plot], and then select 4:PlotsOff.
Jan 19, 2011 | Texas Instruments TI-84 Plus Silver...
Getting ERR: INVALID DIM when pressing the Graph button
If the message appears when you try to graph functions deactivate the statistical plots. To do so:
Press [2nd][Y=] to access (STAT PLOTs)
Select [4:PlotsOff] then [ENTER]
That should solve your problem. Post a comment to this thread if you still have trouble graphing.If the message appears in another context, it sure would help knowing the context of the error.
May 12, 2010 | Texas Instruments TI-84 Plus Calculator
TI-83 Plus Calculator: I am trying to graph an equation and I get the "ER...
May 07, 2010 | Texas Instruments TI-83 Plus Calculator
Im getting an err: invalid dim on my TI-84 Plus calculator...what do I do?
Apr 18, 2010 | Texas Instruments TI-84 Plus Calculator
When trying to graph anything, ERR: INVALID DIM appears..
The easiest and quickest way to start graphing is to reset the RAM. Press [2nd][MEM][7:Reset][1:All Ram][2:Reset], then [CLEAR] to clear the RAM Cleared Message and go to the main screen.
Hope it helps.
Oct 07, 2009 | Texas Instruments TI-84 Plus Silver...
I get the error message ERR: INVALID DIM with
If you are in the stat mode and entering points in list 1 and list 2, it could be that one list is longer than the other.
If you are just trying to graph from the y= screen, one of your plots is probably turned on. The easiest way to fix this is to press the 2nd button the the plus button, then 7 and then 1 and then 2. This will reset to factory settings.
Jul 24, 2009 | Texas Instruments TI-83 Plus Calculator
132 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
