Question about Nikon Coolpix 775 Digital Camera
Memory card is incompatible suddenly - Nikon Coolpix 775 Digital Camera
    Brigadier General:
  • 11,967 Answers
Did you erase or format it on your computer instead of your camera?
Posted on Nov 12, 2009
I am using the camera for 2 monthes and now its says memory card error. i didnt changed the memory card SDHC what sould i do
Welcome to Fixya. Getting a card error means that:
* memory card is not yet formatted for camera use
* memory card requires cleaning
* using a incompatible memory card
* camera malfunction
Here are some troubleshooting steps that you can do it by yourself. However if the error message still persist, you should contact your Canon service center.
Memory Card not formatted
You have to format the memory card. Some memory card can't be formatted using a PC's, or formatted by another digital camera. I suggest that you have to format the memory card using the camera itself.
Memory Card requires cleaning
Use a dry and soft cloth in cleaning the memory card and the memory acrd slot.
Using a clean pencil eraser can also be useful in cleaning the memory card but you have to be careful, slightly rub the eraser on the memory card.
Incompatible memory card
Please use a compatible memory card
Camera malfunction
In this case you have to contact you service center. It will be a big help if you can check if your camera is still under warranty to get a free service.
Please let me know if you have any questions and if this solution was helpful.
Thank you for using FixYa.
Apr 20, 2011 | Canon PowerShot SX210 IS Digital Camera
I keep getting a card error and I have tried 9 dif cards including a new one and still the same thing.
Welcome to FixYa.
All you need to do is:
Camera malfunction
Apr 11, 2011 | Cameras
Suddenly we can't connect to our Mac. It worked fine before, but all of a sudden it's stopped. restarted the computer checked the connections, but nothing. it's just stuck.
As a Mac user I don't bother with the camera software nor do I download using the camera. Best way to work around the software and firmware incompatibilities is to purchase a memory card reader. The Mac looks at this as an external drive and you can open the memory card see the thumbnails copy and paste the files into a folder in "Documents". Don't know what OS you have but there is a viewer that you can open to see the pictures and if you were successful in loading the camera software you can use it to do your photo editing. My suggestion would be to invest in a Photoshop program. The reason I'm suggesting this is Photoshop is the "industry" standard and by having a multiple port card reader you can change cameras, even memory card types without the hassle of programming compatibilities. Now as far as this "all of a sudden it stopped" what has happened is there was an auto update which basically made the camera download non compatible.
I don't know how old your Panasonic is but there is a lot of people still using "older" digital cameras that work just fine but the computer updates and software is leaving them in the dark. The Mac will work great with the card reader (I'm using Photoshop CS3) and a Photoshop program even if you update the OS. People that are using PC and upgrade to Windows 7 are just dead in the water when it come to the camera software. Oh and another thing that's happening is memory card capacity at one time a 2gig was huge and the camera firmware was compatible with 2gig memory but, if you try putting a larger memory card in say a 4gig the camera won't accept it. I was fortunate with a couple of my Pro cameras where I was able to go onto the manufactures web site and update my cameras. Cheers have a great day ;-)
Mar 04, 2011 | Panasonic LUMIX DMC-FZ38 (DMC-FZ35K)...
2G memory card not working
If the original memory card (RAM Stick) is working, then it just means two things; either the 2GB memory card is defective or incompatible with your system. Incompatible means the type is not for your motherboard or the 2GB is more than what your computer can handle. You dont need any drivers for your memory card (RAM).
Try to install a 1GB first and check if it is working. make sure the type (ddr,ddr2,ddr3) is the same as the original and the Bus speed (3200,667,800,etc.) is the same as well to eliminate incompatibility errors.
Hope this helps.
Jul 15, 2010 | Toshiba Satellite L305D-S5874 Laptop
Memory card saying "full" when its not
Your problem is that you are using an incompatible type of memory card.
Your camera was designed to use SD cards with a maximum capacity of 2GB. It cannot use larger capacity models, and is also incompatible with the later SDHC cards.
SDHC cards are the same shape and will fit your camera, but have differences beneath the skin and so won't work properly in your camera. Without any memory card in place your camera uses internal memory; it's then only by lucky chance that your camera has sufficient SDHC compatibility to allow you to transfer the internal memory image to the SDHC card when you subsequently insert it into your camera.
Your only solutions are to either use an SD card with a maximum capacity of 2GB or to replace the camera with a later model which is fully SDHC compliant.
Apr 29, 2010 | Samsung Digimax D73 Digital Camera
4GB card incompatible?
I've come across many people who say their card isn't locked only to find that the slide switch on the side of the card is indeed in the locked position. Check yours.
Jan 15, 2010 | Canon PowerShot SD500 / IXUS 700 Digital...
Put new memory card in camera but has formatting problem. When memory card is put in it says the new memory card requires formatting. When I continue it states that formatting will delete everything in...
New batteries first!! Make sure they are "GOOD"
May have a bad or incompatible card.
Will you camera take pictures without a card in it?
If yes, you have a bad or incompatible card.
Try another card
Here is all the information you'll need to solve this:
Read it.
http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=8814&product=EKN031714
Dec 24, 2009 | Kodak EasyShare Z612 Digital Camera
RCA Pearl MP3 TH 1101A internal memory
You probably loaded an incompatible file type - this player is not as resilient when faced with such a possibility
perform a firmware upgrade to
restore it.
– Please go to http://www.rcaaudiovideo.com/faq
for more details.
-Tha Mp3 Doctor
Sep 01, 2008 | RCA TH1101 MP3 Player
N73 problem
Use only miniSD cards approved by Nokia for use with this device. Nokia utilizes the approved industry standards for memory cards but not all other brands may function correctly or be fully compatible with this device.
Use only compatible miniSD cards with this device. Other memory cards, such as Reduced Size MultiMediaCards, do not fit in the memory card slot and are not compatible with this device. Using an incompatible memory card may damage the memory card as well as the device, and data stored on the incompatible card may be corrupted.
Press menu and select Tools > Memory. You can use a compatible miniSD card as extra storage space and for backing up the information in the device memory.
To back up information from the device memory to a compatible memory card, select Options > Backup phone mem.
To restore information from the compatible memory card to the device memory, select Options > Restore from card.
To eject the memory card, press , and select Remove mem. card.
Important: Do not remove the memory card in the middle of an operation when the card is being accessed.
Removing the card in the middle of an operation may damage the memory card as well as the device, and data stored on the card may be corrupted.
"I used to be apathetic, but somehow I just lost interest..."
Apr 04, 2008 | Nokia N73 Cellular Phone
Nokia N70 wont acknowledge memory card?
Note: This device uses a Reduced Size Dual Voltage
(1.8/3V) MultiMediaCard (RS-MMC). To ensure
interoperability, use only dual voltage RS-MMCs. Check
the compatibility of an RS-MMC with its manufacturer or
provider.
Use only compatible Reduced Size MultiMediaCards
(RS-MMC) with this device. Other memory cards, such as
Secure Digital (SD) cards, do not fit in the memory card
You cannot use the memory
card if the door of the
memory card slot is open.
Format a memory card
When a memory card is reformatted, all data on the card
is permanently lost.
Some memory cards are supplied preformatted and others
require formatting. Consult your retailer to find out if you
must format the memory card before you can use it.
To format a memory card, select Options > Format mem.
card
. Select Yes to confirm. When formatting is complete,
enter a name for the memory card, and select OK.
Apr 03, 2008 | Nokia N70 Cellular Phone
Nikon Coolpix 775 Digital Camera Logo
61 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
