Question about Rowenta DZ1700 Iron
Iron only stays hot enough to iron for about 2 minutes. The red light blinks except for that time.
  • 5,568 Answers
I suggest contacting Rowenta; if you check here at FixYa, you'll find a spectrum of problems with what should be a simple, reliable device. Several instances of the iron not turning off at all until the plug is pulled from the wall, several others that fail to turn on at all. This once was a good company and it wouldn't surprise me to find that they are now made in . . . China.
Posted on Nov 12, 2009
I plug iron red light stays lit but sole plate dont get hot
The connection to the resistance might be burned out. disassemble carully, might need soldering.
If you disassemble and don't have experience repairing an iron, take photos for each step. See some videos about iron repairing
Iron Disassembly Process
Iron Repair No Power or Short in cord wire Rowenta Master
How to repair broken iron
Iron Repairing sajid salman flv
Oct 26, 2015 | Irons
My rowenta iron which is about 4-5 years old starts blinking the red on-off button after only 2-3 minutes of use. Also the orange button will not stay lit. What is the problem? The red on-off button does...
your iron has a thermostat fault its this thermostat thats cutting in and out that puts the red light on it could be fixed but that wont be a cheap fix best bet is to buy a new iron as that would work out cheaper
Sep 11, 2010 | Rowenta DX6700 Iron
Need the circuit board for a DE-871A Iron / Iron does not turn on
The electronic shutoff light blinks but won't stay on, so the iron won't get hot. Can this be repaired? Can I disable it?
Dec 14, 2009 | Rowenta Professional DE871 Iron
Red light keeps blinking and iron shuts off
Sounds as if the cable may be damaged or a loose connection. May be cheaper to buy a new one from wallmart or similar store.
Jul 31, 2009 | Rowenta Effective DX1900 Iron with Auto...
It shuts itself off
The SHARK ELECTRONIC Iron is equipped with an electronic auto-off. The electronic auto-off switches the iron off if it has been left standing unmoved in any position (sideways, flat or upright) for approximately 7-9 minutes. A red light on the LED display panel will flash when the iron switches itself off. (Fig. 7) To switch the iron back on, just shake the iron side-to-side several times.
Jul 31, 2009 | Euro-Pro Shark GI490 Iron
Red light on
Per the owner manual, you shake the iron to "wake it back up".
The safety cycle initiates after it sits over 8 minutes on it's heel, or on it's sole plate or it's side side for more than 30 seconds. The light shoul dbe blinking when it is in the safety mode.
If you can't wake it up, then return it if it is still under new warranty.
Jan 30, 2009 | Tefal UltraGlide Easycord FV4256 Iron
Autoshut off red light keeps flashing
I had the same problem and eventually removed the tilt sensor. This is the molded board that you see when you open the back of the iron. By removing it, you will also loose the timer off function. The thermostat will still be operational.
Oct 14, 2008 | Braun SI6285 Iron
I'm having a problem with the auto shut off of my sunbeam 421A series iron. The iron works great until the auto shut off comes on and the red light starts blinking. I understand that the iron should...
Unless you have a 5 or 6 hundred dollar iron, or unless it is brand new, and still under warranty, there is an excellent rule of thumb when an iron quits working: Buy a new one! These days, irons can be purchased cheaply enough that it is WELL worth the money. Not just for the convenience, but for the safety issues. This is an appliance that could burn your house down even if it's in PROPER working order. Hope this helps!!
Chad
Sep 21, 2008 | Sunbeam 4214 Iron
Red light flashing
Blinking red light is a standby phase, its not going to get hot like this. Shake it or just start ironing, the red light will go solid and the plate will heat up. The red light will go off when the plate is hot enough. It will go on again (solid) after a few minutes to keep the plate at the right temperature. If you leave it standing around for a while it will begin blinking again (standby).
These irons are known for malfunctioning though, mine stays in standby and the plate never heats up! Hopefully yours is fine.
Feb 07, 2008 | Braun SI6225 Iron
Rowenta DZ1700 Iron Logo
283 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
