Question about Omega Coil Spring Compressor Set
How to change coil springs on a 1986 Dodge Ram D-150 (front) and what tools are needed .
    Sergeant:
  • 399 Answers
Y need to hire a spring compressor
Posted on Nov 13, 2009
What kind of oil does a 86 dodge ram 150 take
That information is in the user manual. It also depends on what type of duty the dodge is encountering. Could be light could be very heavy, I do not know. You may stop by your friendly dealer, listen to a short sales pitch and get the answer from him if you do not have the manual. You may get it from one of the following links.
https://primralismo.files.wordpress.com/2015/04/1986-dodge-ram-150-manual.pdf
Get the Best Priced Dodge D150 Repair Manual
https://www.google.com/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=86+dodge+ram+150+manual
May 01, 2015 | Dodge Cars & Trucks
How do i change my rubber bushings on the front suspention of my 1997 dodge ram 1500
opper Control Arm Bushings
  • To access the upper control arm, remove the shock absorber and the strut bar. Also, disconnect the sway bar from the lower control arm, if your particular Ram model is equipped with it. After that, you can hold the coil spring in place with a spring compressor.
    Secure the wheel hub assembly to the chassis using a wire before you disconnect the upper ball joint. This will prevent damage to the brake hose. When ready, release the ball joint using a ball-stud loosening tool (see Resources).
    The upper control arm mounts to the chassis with a cam bolt assembly. Once removed, you can place the control arm on a vise and remove the bushings using a bushing service tool (see Resources). When installing the new bushings, do not use any lubricant but make sure the flange on the bushing end seats properly on the arm bore. Then re-install the upper control arm. When finished, take your Dodge vehicle to a good shop to align the front suspension.
Lower Control Arm Bushings
  • Remove the shock absorber and strut bar. If your particular model is equipped with a sway bar, disconnect it from the lower control arm.
    Secure the coil spring with a spring compressor and release the lower ball joint from the wheel/hub assembly using a ball stud loosening tool (see Resources).
    Now you can release the lower control arm by removing the rear mounting bolts. Remove the bushings with a bushing service tool (see Resources). When installing the new bushings, do not use lubricant and make sure they seat properly on the control arm bore. Then replace the lower control arm. When finished, take your Dodge vehicle to a good shop to align the front suspension
Oct 20, 2011 | Cars & Trucks
1986 dodge d150, 318 cu engine Truck starts sometimes, could idle for an hour or longer then just quits, not like a fuel problem quits no sputtering just dies like turning the ignition off. Coil is good...
Check your ballast resistor, they are a major failure item. The ballast resistor lowers the voltage to the coil and uses resistance to do so. Test would be to put battery voltage to positive side of the coil, during the failure condition, but my bet is resistor.
Aug 30, 2011 | 1991 Dodge Ram 150
Need torque specs on axle nuts for dana 50 rear axle
Dana 50 Front Axle
Observe the following torques;
* Left and Right drive axles-to-cross member: 120-150 ft. lbs. (163-203 Nm)
* Axle arm-to-radius arm: 180-240 ft. lbs. (244-325 Nm)
* Coil spring insulator: 30-70 ft. lbs. (41-95 Nm)
* Upper spring retainer: 13-18 ft. lbs. (18-24 Nm)
Dana 60 Front Axle
* Drive shaft-to-flange: 15-20 ft. lbs. (20-27 Nm)
* Track bar nut and bolt: 160-200 ft. lbs. (217-271 Nm)
* Stabilizer link nut: 20-30 ft. lbs. (27-41 Nm)
* Stabilizer barU-bolt: 50-65 ft. lbs. (68-88 Nm)
* Spindle connecting rod-to-knuckle: 70-100 ft. lbs. (95-136 Nm)
* Front spring U-bolt: 95-100 ft. lbs. (115-135)
Feb 19, 2011 | 1986 Ford F 250
How do I remove front coil springs from 1998 Dodge Ram 1500 2wd?
There's a clip holding the spring on the bottom a arm. Take that off then carefully jack the truck up on that side. You'll have to go pretty high and you might need a spring compressor. I can tell you from experience that you should keep your face away from the spring when using a compressor tool. They tend to slip off sometimes.
Sep 07, 2010 | 1998 Dodge Ram 1500 4WD
Have a 86 ram 50 pick-up will not start no fire from coil but fire to coil changed coil still same problem
check the ignition module and the rotor bug also check the hall effect sensor in the distributor with a OHM meter to insure that it is within range
Jan 23, 2010 | 1986 Dodge Ram 50
I need to change front shocks on a '04 Ford 150 4wd.Whats the procedure and tools i would need.Thank you
You Must Put it UP On Jack Stands And Take Out the LOWER BOLT From Shock FIRST ,Drop Lower Control arm By Removeing Lower Ball Joint AND OUTER TIE ROD.There are are 3 Nuts On top where the Coil Spring Seats Remove Them, Remove Assembly The Same as A STRUT ASSEMBLY, YOU Must USE CAUTION Use Spring Compresion tool to Remove top Shock Nut. REVERSE PROCEDURE For Instalation. Hope this Helps ;;;;;;;;AS FOR TOOLS METRIC SET & THE ONLY 'SPECIAL TOOL" IS >> A COIL SPRING COMPRESSOR. BUT NOTHING ELSE OTHER THAN METRIC WRENCHES & SOCKETS
Jan 29, 2009 | 2004 Ford F350
Put new oilpump and hadto remove timeing belt and gears. i need t
For the 1986 Dodge Ram 50 2.0L AND 2.6L 4-Cylinders:
Firing Order:
1-3-4-2
Cylinders:
(back)
...4
...3
...2
...1
(front)
Distributor:
.(back)
3.......4
1.......2
.(front)
For the Timing Marks: Click on the following Link. It has the Position of the Cranshaft and Camshaft and their respective marks.
http://www.2carpros.com/car_repair_information/year/1986/make/dodge/model/ram_50/1986_dodge_ram_50_timing_belt_diagram_marks.htm
Jan 02, 2009 | 1986 Dodge Ram 50
1986 dodge ram 150 tranny problem
Sorry this is not an easy fix the clutch packs in the transmission are slipping, usually caused by wear, but the hydraulic pump is probably getting week. As the oil warms up the oil gets thinner and the hydraulic pressure decreases. Times for a overhaul of the transmission, and if the torque converter can not be flushed a new torque converter is recommended. You may get lucky buy changing the fluid several times, but if the transmission is 22 years old it may not help.
Aug 09, 2008 | Dodge Ram 150 Cars & Trucks
Omega Coil Spring Compressor Set Logo
47 people viewed this question
Top Omega Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Omega Air Tool and Compressor Expert? Answer questions, earn points and help others
