Question about Matsonic MS8177C Motherboard
Power supply I have a Matsonic MS8177C Motherboard and at this present moment the power supply is a 350w power supply. Can I substitude the power supply for something higher watts. Please can you reccommend. Than You
  • Anonymous Aug 21, 2008
    I confuse, how to choose power sw, reset sw, hdd led, etc in motherboard, please give me solution or give me information / manual book
    Genius:
  • 1,226 Answers
Yes you can make it 450watts power supply.
Posted on Jan 08, 2008
6ya staff
SOURCE:
I have presently a atx 350w power supply would yours solve my supply problem
If your ATX switch mode power supply is faulty then I suggest you replace it with a new one that is 350 watt or higher wattage.
Fixing faulty ATX power supplies is not a DIY project, there are dangerous voltages in these power supplies and can cause death or serious injuries.
Jan 30, 2011 | AMD Codegen 350W ATX P4 Recommended...
My Matsonic MS8177C will not work with 2 DDR 400 PC3200 1 GB memory. However, it works with one in either slot. It will also work with one 1gb & 1 512. Why will it not work with two 1gb?
Please refer to the motherboard manual to know the memory capacity that can be inserted in your motherboard. If you already know about it and still doesn't solve the problem then follow this steps:
1. Remove all the 1 GB memory and then clean the pins of each by using an eraser of a pencil in your motherboard.
2. Find the motherboard bios jumper settings and reset it and turn it back to normal again.(Please refer to the motherboard on how to do this.)
3. Insert again the two 1 GB memory.
4. Power on the computer.
Take note: Be sure that both 1 GB memory have the same frequencies because some memory will not work if they don't the same speed and frequency.
Hope this could help you. Don't forget to rate me please..Thanks..
Oct 26, 2009 | Matsonic MS8177C Motherboard
Power supply packed i n
Yes, you can safely put in equal or higher. Just make sure it is an ATX and that it is P4 compatible. Most new ones all meet to those specs. Higher is actually better. I would go with a 400w or higher.
Apr 07, 2009 | Intel Allied 450W Dual Fan Pentium 4 ATX...
Upgrade for Bestec ATX-1956D (HP p/n: 0950-4106)
How about the LC Power LC350M Micro ATX - 380 Watt
or the
Logisys 350W Micro ATX
They should fit your form factor and output as much as 350W being relatively cheap, but neither gets 18 amps on 12V rail...
I think no power supply of that size has an output like that...think about a cheap but substancial chassis upgrade if you need that power...Have a look at directron for the PSUs.
Feb 13, 2009 | HP Bestec ATX-1956D 200w HP Part No...
We want a hp compac motherboard driver downloader
Without more information it is hard to supply a exact driver download. Hope fully this link will help:
http://www.hp.com/#Support
After that you will need to select the download driver selection the go to the lower part and enter in your HP model number and any other information that is needed to get the right driver!
I hope this helps!
Dec 12, 2008 | Computers & Internet
No sound matsonic mspm800 motherboard problem
http://www.matsonic.com/drivers/view.php?modelID=MS8308E
The above site address is the only one I could come up with nearest your motherboard number copy and paste the first line into address bar go there it lists most of the drivers for motherboard including sound hope this helps
Jul 25, 2008 | Matsonic MS8177C Motherboard
Ms8318e
what kind of display problem? most problem are drivers.
Dec 14, 2007 | Matsonic MS8177C Motherboard
Matsonic MS8177C Motherboard Logo
99 people viewed this question
Top Matsonic Computers & Internet Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Ekse
Are you a Matsonic Computer and Internet Expert? Answer questions, earn points and help others
