Question about Cell Phones
How can i get my phone working again.How do i download
Phone was workingproperly till ysterday.I will turn on but will display computer script in yellow quotng a mulfuntion
Hai in my nokia Lumia 520 while downloading new apps it shows error code:)80048264
Error code 80048264 occurs when it can't connect to your Microsoft account. Either your password is wrong or there is a problem with the account. Try putting your password in again on the phone under Settings (the gear)> email+Accounts> Microsoft account. If that doesn't work, try logging in on your computer (outlook.com). It should give you trouble logging in, but offer solutions to fix your log in. Once you can log in on the computer, try it on the phone again. Mine Lumia 920 did this when my account password reset without my knowledge. I don't use my Microsoft email, so I never knew it had a problem till I tried to download an app.
Aug 28, 2013 | Cell Phones
When i apply theme my phone will restart again and again till i reject my memory card some time it also restart autometically plz solve my this problem plz
i m using nokia 3110c from a long time ago and i also face this problem
but
when i use internet on is and download themes from mobile internet and apply the theme then i did not face this problem
but when i transfer some data from computer to mobile with the data cable or computer bluetooth my mobile do the same it will restart again and again
then i think that it will be a technical problem so
i will say use the mobile internet and download themes and enjoy it and yourself maybe it will help full to you
thankyou
Mar 06, 2011 | Nokia 3110 Cellular Phone
My uniden axis phone when dead ysterday. There is no information on the display just the light is on
My Uniden digital powerMax 5.8Ghz hand phone went dead and does not want to take a charge, although the base unit red charger light is on.
Mar 09, 2010 | Uniden DECT 6.0 Cordless Phone ID
My nokia 6500 i turned off and was work fine before,now
its a software problem. I think the software files are corrupt and that's why the phone cannot boot.
The phone needs to be reformatted for it to work properly again. The process is called Flashing.
That's the only way your phone could be revived.
Take care.
Jan 02, 2010 | Nokia 6500 Slide Cellular Phone
Garmap wont work. NO GPS SIGNAL
Hi there
Please do the following. On the phone go to the main menu and then to settings
Under settings please select the phone settings and scroll to the bottom
If you select GPS+ then download the update and turn off the the phone and then switch it back on.
If you select the Gps Position then select it and wait till the unit picks up signal. Then turn off the phone and turn it back on
Run the application again and it should work
Kind Regards
Garmin Team
Dec 07, 2009 | Samsung S8300 Ultra Touch platinium-red...
Only white light appears nothing else appears.
hi
first try to connect to a pc using the usb and check if u can get connected and browseif this works then there is a problem with the display else the OS of the phone is lost
beware that all your data will be lost on the phone if the following procedure is followed
hold the green button '3' button and the '*' button simultaniously and then power on the device hold the keys till 'FORMATTING' is displayed on the screen
hope this helps
Cheers
Jun 17, 2009 | Nokia 3230
A virus?
jonats,
question: have you tried charging your phone and does it indicates a display or light ups your LCD screen and indicates charging?
1) if it does charging and indicates "charging" on your LCD screen , try to do this:
note: make sure your battery does have a charge when doing this
a) remove the battery and install it again , but dont put the power on
b) press and hold this 3 buttons at the same time: "call " button / " * " button / "3" button
c) while holding and pressing the 3 buttons, switch and press the power button and wait till a display appear on the screen.
cheers.
mark
Jan 17, 2009 | Nokia 2610 Cellular Phone
Screen freezes after going in power saver mode.`
Format ur mobile phone then reinstall O/S
Aug 10, 2008 | Nokia N72 Cellular Phone
No Resource Upgrade resource agan
ok, so u formatted your player, hence the green screen. So now all you have to do is download the firmware(match your player, sl with sl firmware, etc) then extract w/ winrar, u get 2 files so put them both in root folder (displaying music, video, etc) unplug turn off, on it will update then wait few min till it turns off, then turn on and ur player will work.
May 08, 2008 | Meizu Mini Digital Media Player
Slow internet +problem displaying pages
hi, try it (1) reinstall windows & install usb cable driver again. or (2) Check ur mobile & cable on other computer i.e.on ur friend's PC. or (3) Contact ur service provider. or contact with details error msg & name of service provider. sr99mobiles@yahoo.co.in
Oct 03, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Cell Phones Logo
18 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
