Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
AUGER MOTOR FROZE UP ON MODEL GSS20IEPAWW - GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Kenmore cold spot refrigerator model # 106.56662500 ice is not dispensing through the door. How do I fix it?
This is common in these units. When the dispenser lever is depressed, an auger motor rotates the auger wire. When the auger rotates, it pushes the ice toward the dispenser door and chute. When the auger is defective, it isnt able to push the ice out of the dispenser. You need to check the auger to determine if it is broken or disconnected from the auger motor. If the auger is broken, replace it.
Jan 28, 2017 | Kenmore Refrigerators
Ice maker does not dispense ice through the door
Hello. I had the same problem. I replaced the auger motor(around$95) 3 times and would only last about a little longer than a year. I bought the 4th one but this time, I wanted to diagnose the issue. So it turns out that the auger motor goes installed with the impeller upwards. What was happening was that if a piece of ice would stay in the dispenser chamber and melt, the water would go into the auger motor eventually causing the auger casing to get full of water and slow it down or short it out. I took the casing apart and noticed that there was a small space between the motor and the casing. I drilled 2 nice sized holes in the dimple of the new motor very gently as to not drill into the impeller motor and installed the auger. To this day, 3 years later, no more having to buy new auger motors. Hope this helps!
Mar 10, 2015 | Refrigerators
Whirlpool side by side ref auger froze up. will not turn.is there a reset button?
The auger motor is not very powerful, so if you have ice build up in the bin, it can hold the auger motor immobile. Suggest you take the ice bin out and completely defrost and dry before putting back in.
Feb 06, 2012 | Whirlpool ED2FHEXN Side by Side...
Icemaker is making ice but the ice dispenser is not working
Check the ice storage container. The ice dispenser will not dispense ice until the first supply ice has dropped into the ice storage container.Remove excess ice from the back of the ice container. Make sure ice cubes are not jammed between the ice maker and the back of the ice container.
The auger won't engage or turn to dispense ice.Remove the ice bucket and with a hair dryer warm up the inside where the fork is that turns the auger in the bucket and try it and if this does not help then you will have to replace the auger motor ,, chances are the motor is just froze up .--------
If there is nothing jammed then try this./Remove the ice bin out.And then clean the ice bin.
Rotate the auger with your hand.If its hard then there is problem with auger motor.If the auger is not rotating fine then its faulty auger motor or the auger motor is frozen,if you notice ice getting collected there.
Take a hair dryer and blow hot air on the auger motor for few minutes.Take care you dont blow hot air continuously.
But if that is not helping then disconnect auger motor connecting wire wait for 2 minutes clean the connector and reconnect the connector back and see.If that is not helping at all.Then,replace the auger motor.
To see how auger motor looks.Please click the link below:---
http://www.appliancepartspros.com/part_details_lgimg.aspx?part_id=3965455&image=0
You can get required parts from sears part direct online site or from repairclinic.com site.
This will help. Thanks. Helpmech.
Feb 21, 2011 | Frigidaire FRS26H5AS Side by Side...
Will not send ice cubes down the shoot just chopped ice and chilled water. The problem started when the freezer door was left open on the fridgeadair fridge.
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
Oct 14, 2009 | Refrigerators
The ice won't come out mottor that turns the ice is not working.What part shoiuld I order and how do I fixed. is a kenmore model 106.56532400
It is called an auger motor. Remove the auger motor and try to defrost it. A lot of times they will just get froze in place.
Sep 10, 2009 | Kenmore 53642 / 53644 Side by Side...
Whirlpool Door Ice Dispenser Not Working
mine froze up in the shute, had to put water down iti
Aug 26, 2009 | Whirlpool GS6SHAXLS Side by Side...
GE refrigerator model GSS22 WGMD ice maker motor
If you cant manually turn your auger motor, it may be bad. Does it dispense solid ice or no ice at all? Another thing may be your control panel. That could be bad too, it's the one sending juice to both your solenoid and auger motor.
Jul 09, 2009 | GE Profile PSW26P Stainless Steel Side by...
The auger arm doesn't turn. The ice maker still makes ice, it just can't dispense.
Take the ice container with auger inside it and defrost it. Withe the door open to the freezer push the switch that turns light on in freezer to turn it off. Have someone push the ice dispenser switch while you hold the light button in. Tell me if there is any movement in the auger motor in rear and let me know what you find. Thanks, Sea Breeze
Jun 01, 2009 | Amana ARB1905C Bottom Freezer Refrigerator
Ardis Ice Auger
I pick up a power head from the junk yard this past weekend. The unit was made by Feldmann Mfg. and engineering. I believe this is the same company that manufactures Jiffy ice augers. I paid $3 for it. It looks like it is from the 50's or 60's. It was complete except for the auger. The motor was froze from sitting, but after disasembling, cleaning, cutting new gasket, freeing the rings and numerous other problems I got it running. I found augers in the Northern hydraulics catalog in sizes from 3" to 12". They are for earth and the 8" was $139.99. You would need to contact them for the shaft size to see if it will fit in the power head you have.
Mar 30, 2009 | Tanaka TIA-350s Post Hole Digger -...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
35 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
