Question about Canon PIXMA MX310 All-In-One Printer
Getting a 5B00 error on a MX310. We just replaced the ink absorber
  • 6 more comments
  • mmarlow Nov 13, 2009
    Replaced the ink absorber now get a 5B00 error. Tried menu,scan,copy,scan - no luck. tried power and reset, going thru eeprom settings, no luck
    did that. even un-did the power supply for about 30 minutes
    it won't allow you to do that. power on, runs thru startup sequence, then printer error, 5B00, menu button beeps, sso scan copy and fax
    several beeps when you press once
    three
    None of the previous suggestions have worked.
    Ink pads were full. Replaced them. now get the 5B00 error. Have gone thru a litany of routines to no avail.
    Here is the correct solution:
    How to reset Canon MX310 5B00 error
    1. Power off the printer.
    2. Holding the stop/reset button, press and hold power button also.
    VERY IMPORTANT!!
    Hold both buttons together for 5 secs.
    3. Still holding the power button, release the stop/reset buton, then press the stop/reset button twice.
    4. Release power button (the screen should now say 'Service Mode'). - This may take a minute or two.
    5. Wait until the power button lights steady green, then press the stop/reset button four times with a 3 sec space between each press. On the 4th press the indicator should turn steady green.
    8. Press the power button, and wait until printer has shut down.
    9. Press power button to power up. The printer will feed one piece of paper.
  • 8,197 Answers
Error 5b00
reset waste absorber counter. here is how to reset.
1) With the printerGetting a 5B00 error on - 2.gif powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button 4 times.
If this does not work you need to call canon.
Good Luck
Posted on Nov 13, 2009
  • 4,806 Answers
Your error means the waste ink pads are full, its recommended you get them replaced but they should hold out for a bit. to get the printer going again you can follow these steps and reset the counter.
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button.
(DO NOT release the buttons. The Power LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and
Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light
alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4) When the Power LED lights in green, press the Resume/Cancel button the specified number of time(s)according to the function listed in the table below. (Each time the Resume/Cancel button is pressed, the Alarm and
Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4 times----Green (Power)------Waste ink counter resetting
Good luck.
    Brigadier General:
  • 5,158 Answers
Basically you need to reset the printer. this is done by unplugging the power cord for about 30 minutes then applying power again. if this does NOT reset it let me know.
  • 3 more comments
  • Roberta Smith
    Roberta Smith Nov 13, 2009
    (1) Press MENU
    (2) Press SCAN COPY SCAN to enter service mode
    (3) USE > to got to NVRAM ACCESS
    (4) set ABS-M LEVEL to 0
    (5) set ABS-P LEVEL to 0
    (6) Press STOP to EXIT
  • Roberta Smith
    how many beeps ?
  • Roberta Smith
    several isn't a number.... please count them and let me know thanks
  • Roberta Smith
  • Roberta Smith
    there are actually three methods to try. do each once and it should reset with one of the methods. canon is abit vague on the correct methods.
    Waste Error Reset:
    1: Power off printer
    2: Hold Resume button then press and hold POWER, the beeper will sound once.
    3: Hold POWER and release RESUME
    4: Press RESUME twice
    5. Release Power button
    6: When the indicator lights steady, press RESUME three(3) times. The indicator should be orange.
    7: Press Power to set data
    or
    1. Press and hold the POWER button
    2. Turn off the printer by disconnecting the printer power cable,
    3. turn on the printer, still holding the POWER button
    The indicator (L.E.D.) should be green.
    4. Press and release the RESUME button , the indicator (L.E.D.) should be orange.
    5. Press and release the RESUME button again, the indicator (L.E.D.) should be green.
    6. Release both buttons.
    7. Reconnect the printer cable.
    8. And it should be reset.
    President:
  • 3,278 Answers
Hello.
From the Canon site, to reset your printer, try:
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
    Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
Hope this helps.
Posted on Nov 12, 2009
Mx 347 canon error 5b00
1) Ink absorber condition
2) Part replacement:
- Ink absorber kit
3) Ink absorber counter value in the
EEPROM;
reset the ink absorber counter
Sep 24, 2012 | Canon PIXMA MX340 Wireless Office...
5B00 ink fault primter mx310
Ink absorber foam is full.. need to replaced it...then ready to use again...
Jul 22, 2011 | Canon MX310 Office All-In-One Printer
Canon MX340 5B00 error
Error 5B00 refers to the ink absorbers being full. This is a massive job to replace them as they are in the bottom of the machine so the whole engine needs to be removed to fit new ones. Also special software is needed to remove the warning. Its a job for a canon agent. Its a big big and very messy job.
Srri.
By the way the kit you require has a canon part number of QY5-0192.
Jul 20, 2011 | Canon PIXMA MX310 All-In-One Printer
Error code 5B00 Canon MX 310
you need to reset the waste ink absorber,your absorber is full
Feb 24, 2011 | Canon PIXMA MX310 All-In-One Printer
How to reset canon pixma MX338 printer error code 5B00...need solution URGENT....PLEASEE HELP
The waste ink absorber is full and is triggering error 5B00. To reset the error you need to replace the ink absorber. You may find a cheaper ink absorber kit on Ebay or Amazon.
Feb 03, 2011 | Canon PIXMA MX300 All-in-One Printer
, printer error 5B00
Hello
Error code 5B00 indicates absorber full error. To fix this problem you need to reset waste absorber counter and replace waste ink absorber.
Hope this helps
Jan 18, 2011 | Canon PIXMA MX310 All-In-One Printer
Canon pixma MX310 error 5B00
Jul 27, 2009 | Computers & Internet
Won't print error message 5b00 on screen. How can
5B00 is the waste ink absorber full message, only a Canon repair shop can reset the error code.
Jul 27, 2009 | Canon PIXMA MP170 All-In-One InkJet...
I keep getting mssg : check printer error 5B00. i found the answer to this, its about ink or something. after i clean the pad, and i connect the printer again, but i still get the same problems..... some...
Hi guys, Error code 5B00 indicates absorber full error. To fix this problem you need to reset waste absorber counter and replace waste ink absorber. Unfortunately you don't write the printer model so I cannot write reset procedure here.
Jun 05, 2009 | Canon PIXMA MX310 All-In-One Printer
Check printer 5B00
Hi guys,
Dec 25, 2008 | Office Equipment & Supplies
Canon PIXMA MX310 All-In-One Printer Logo
4,046 people viewed this question
old marine
old marine
