Question about Kenmore Dishwashers
Lock on light stays on even after pushing and holding the no heat dry button for 4 secs it doesn't start filling model 665-15817
  • mhulbert847 Nov 13, 2009
    I did turn the circuit breaker off and the message goes away enough to run the dishwasher once and the message returns. It's also only after the circuit breaker is off for 10 minutes or more. Would this lead you to the timer board or should I still test the other items on your recommended list? Thanks,
  • Kenmore Master
  • 19,396 Answers
Hi.
Try tripping the circuit breaker or unplugging power cord to reset the appliance.
If you cannot get rid of the message, parts inside the appliance must be tested.
Test the door lock first, that is probably the cause of the fault. The lock is tested accessing the switch and measuring Ohms on switch contacts to check if the circuit is opening and closing.
Check the water level sensor, this is often a floater sensor. Ensure that this is not stuck, and test the switch in same way as door switch.
The inlet valve is tested reading ohms on valve solenoid contacts. If there is no continuity, then the valve must be replaced.
If the parts above are not faulty, and the door is closing as it should, then the fault is the timer board.
Regards.
Posted on Nov 12, 2009
  • Ginko
    Ginko Nov 13, 2009
    Hi.
    Replacing the timer board without testing will always be at risk. The timer board must be replaced only when everything else is OK.
    the fact that the fault state comes back after replacing the circuit breaker, only means that there is a fault, and that the machine keeps detecting that something is wrong.
    Before replacing the control board, parts must be accessed and tested, starting from the door lock.
    the door lock is tested reading impedance. To test it you must disassemble part of the appliance, cut door lock wiring and read Ohms on switch contacts.
    If you have not done it before , better calling a technician.
    If you have done some repairing test door lock first.
Start button blinks
It sounds like you have the child-lock or control-lock function turned on. To turn it off, just press and hold the Heat (or Heated Dry) button for 4 or 5 seconds. That should unlock you dishwasehr and you can now use it normally.
Aug 05, 2014 | Kenmore Dishwashers
Tip
How to Unlock Any Appliance or Turn Off Child Lock
<span style="font-weight: bold;">Bosch Dishwasher:</span><br /> <ol> <li>To deactivate, press and hold the "&lt;" button until the Child Lock LED goes out.</li></ol><span style="font-weight: bold;">Bosch Microwave:</span><br /> <ol> <li>Press "Settings" followed by the number "5" to deactivate Child Lock.</li></ol><span style="font-weight: bold;">Bosch Washing Machine:</span><br /> <ol> <li>To deactivate Child Lock, press the Start/Pause button and hold down for 5 seconds.</li></ol>or<br /> <ol> <li>Press the Menu button until CHILD LOCK :ON appears in the display.</li> <li>Press the Select button until CHILD LOCK :OFF appears in the display.</li> <li>Press the Start/Pause button and the key symbol should disappear.<br /></li></ol><span style="font-weight: bold;">Danfoss Thermostat:</span><br /><br /> <ol> <li>Press the control knob or button and hold it in place.</li> <li>Turn the knob counterclockwise until you see the word "Code" appear in the display.</li> <li>Turn the knob clockwise and select the code "0033."</li> <li>Press on the control knob until you see an icon of a clock or a hand appear or disappear indicating that the child lock has been set or unset.</li></ol><span style="font-weight: bold;">Delonghi Microwave:</span><br /> <ol> <li>To deactivate Child Lock, press the STOP/CLEAR key until the beep is heard.</li></ol><span style="font-weight: bold;">Delonghi Portable Air Conditioner:</span><br /> <ol> <li>Pressing the "+" and "-" buttons on the control panel together for more than two seconds unlocks the keypad.</li></ol><span style="font-weight: bold;">Fisher & Paykel Dish Drawer:</span><br /> <ol> <li>Disable the child lock by pressing and holding the key with a key and lock symbol printed on it until the padlock symbol disappears from the screen.</li></ol><span style="font-weight: bold;">Frigidaire Dishwasher:</span><br /> <ol> <li>Press and hold the No Head Dry button (or the Rinse Only, Delay Start or Air Dry button depending on model) for 3 seconds.</li></ol><span style="font-weight: bold;">Frigidaire Dryer:</span><br /> <ol> <li>Press and hold the "Control Lock" button for five seconds to release the lock.</li></ol>or<br /> <ol> <li>Press and hold the "Options" and "Select" buttons simultaneously and hold for 10 seconds to release the door lock.</li></ol><span style="font-weight: bold;">GE Dishwasher:</span><br /> <ol> <li>Press and hold the Heated Dry button for 3 secs.</li></ol><span style="font-weight: bold;">GE Electric Stove:</span><br /> <ol> <li>Press and hold "Lock" for three seconds to release the child lock function.</li></ol><span style="font-weight: bold;">Kenmore Dishwashers:</span><br /> <ol> <li>Press the "Heated Dry" button, and hold for four seconds until the "Lock On" icon light turns off.</li></ol>or<br /> <ol> <li>Hold the "Sensor Dry" or "Lock" symbol down for three seconds until the lock indicator light goes off.</li></ol><span style="font-weight: bold;">Kenmore Dryer:</span><br /> <ol> <li>Press and hold the AUTO DRY LEVEL button for 3 seconds.</li></ol><span style="font-weight: bold;">Kenmore Microwave:</span><br /> <ol> <li>Touch and hold Cancel for 5 seconds to deactivate the lock.</li></ol><span style="font-weight: bold;">Kenmore Range:</span><br /> <ol> <li>Push and hold the Lock button for 10 seconds.</li></ol><span style="font-weight: bold;">Kenmore Washing Machine:</span><br /> <ol> <li>Press and hold "Drain & Spin" for 3 seconds to release the child lock.</li></ol>or<br /> <ol> <li>Press and hold Cancel for 10 seconds.</li></ol>or<br /> <ol> <li>Hold the "End of Cycle" button down for 5 to 6 seconds.</li></ol>or<br /> <ol> <li>Hold the Child Lock button for 5 seconds.</li></ol><span style="font-weight: bold;">Kitchenaid Dishwasher:</span><br /> <ol> <li>Press and hold Energy Saver/Dry button for 5 seconds.</li></ol>or<br /> <ol> <li>Press and hold Lock button for 5 seconds.</li></ol><span style="font-weight: bold;">Kitchenaid Microwave:</span><br /> <ol> <li>Press and hold the "Cancel" or "Start" button for five seconds.</li></ol><span style="font-weight: bold;">Kitchenaid Oven:</span><br /> <ol> <li>Touch and hold START for 5 seconds.</li></ol><span style="font-weight: bold;">LG Dishwasher:</span><br /> <ol> <li>Press and hold the Spray and Rinse button simultaneously for 3 seconds.</li></ol><span style="font-weight: bold;">LG Dryer:</span><br /> <ol> <li>In models that include a rack dry, usually holding the [rack dry] button for three seconds will disable the function.</li></ol><span style="font-weight: bold;">LG Refrigerator:</span><br /> <ol> <li>Press and hold the Lock button for 3 seconds.</li></ol><span style="font-weight: bold;">LG TV:</span><br /> <ol> <li>Open the menu, select lock (padlock symbol) then select lock system, then select off.</li> <li>Press exit to exit the menu.<br /></li></ol><span style="font-weight: bold;">LG Washing Machine:</span><br /> <ol> <li>Press and hold "Dry" & "Spin" buttons together for a few seconds. </li></ol>or<br /> <ol> <li>Press and hold "options & select" until the light goes off.</li></ol>or<br /> <ol> <li>Press and hold "end of cycle" for over 5 seconds.</li></ol>or<br /> <ol> <li>Press and hold the PRE-WASH/Child Lock buttons for 3 seconds. </li></ol><span style="font-weight: bold;">Maytag Dishwasher:</span><br /> <ol> <li>Press the Heated Dry button for three seconds.</li></ol><span style="font-weight: bold;">Maytag Microwave:</span><br /> <ol> <li>Press and hold the "Enter/Start" button for 3 seconds</li></ol><span style="font-weight: bold;">Panasonic Microwave:</span><br /> <ol> <li>Press "Stop/Cancel" 3 times to deactivate Child Lock.</li></ol><span style="font-weight: bold;">Philips TV:</span><br /> <ol> <li>Using your TV Remote, press the 'MENU' button, select FEATURES and press cursor right.</li> <li>Press cursor up/down to select CHILD LOCK and press cursor right.</li> <li>The screen will prompt you for PASSWORD, key in you password if known. If the password is unknown, then key in the code 0711 twice.</li> <li>Press cursor up/down to select CHILD LOCK, press cursor right to change the status to OFF.<br /></li></ol><span style="font-weight: bold;">Samsung Dishwasher:</span><br /> <ol> <li>Hold down the Delicate and Rinse buttons simultaneously for three 3 seconds.<br /></li></ol><span style="font-weight: bold;">Samsung Refrigerator:</span><br /> <ol> <li>Press and hold the Ice Off/Lock button for 3 seconds.</li></ol>or<br /> <ol> <li>Press and hold the Ice Off button for 3 seconds.</li></ol>or<br /> <ol> <li>Press and hold the Lighting button for 3 seconds.</li></ol>or<br /> <ol> <li>Press and hold the Child Lock button for 3 seconds.</li></ol><span style="font-weight: bold;">Whirlpool Dishwasher:</span><br /> <ol> <li>Press and hold Heated Dry button for 4 secs.</li></ol><span style="font-weight: bold;">Whirlpool Dryer:</span><br /> <ol> <li>Press and hold the END OF CYCLE SIGNAL button for 3 seconds.</li></ol><span style="font-weight: bold;">Whirlpool Washing Machine:</span><br /> <ol> <li>Press and hold the END OF CYCLE SIGNAL button for 3 seconds.</li></ol>
on Jun 17, 2011 | Washing Machines
Locked light is stuck on
Are you pushing the button repeatedly or pushing it once and and holding it on for 4-5 seconds? Just push and hold it on for a few seconds till the lock light goes off.
May 25, 2014 | Kenmore 16602 / 16604 / 16609 Built-in...
What if my dishwasher will not start
push and hold the heated dry for 5 secs,,,, then try again
Nov 14, 2011 | Maytag MDB7100AWB Dishwasher
Kenmore dishwasher ultra was quiet guard 3 model 56516012403 control panel will not activate red lights blinking on normal wash and cancel drain. did the hold the heat dry button then the normal wash...
that would be model # 66516012403 correct??
you may have inadvertently set the lock on function..
check this out from your manual...
Lock On
Use the Lock On to prevent unintended use of the dishwasher
between cycles. You can also use the lock feature to prevent
unintended cycle or option changes during a cycle.
When LOCK ON is lit, all buttons are disabled.
NOTE: The dishwasher door can be opened while the controls
are locked. However, the lock must be turned off and the Start/
Resume button pressed to resume the cycle.
To turn on the Lock
Press and hold HEATED DRY for 4 seconds. LOCK ON glows.
If you press any pad while your dishwasher is locked, the light
flashes 3 times.
NOTE: If the Heated Dry option is selected, the light will
temporarily turn off until Lock On glows.
To turn off the Lock
Press and hold HEATED DRY for 4 seconds. The light turns off.
hope this helps,
best of luck,
ttfn
Oct 25, 2009 | Kenmore 15912 Built-in Dishwasher
Whirlpl Dshwshr Control Lock light went on/Reg Cycle won't work
Hold the air dry button for 4 seconds. My son just fixed mine with the same problem.
Apr 07, 2009 | Whirlpool 24 in. DU1100XTPS Built-in...
Lock Light Blinking
silly question but did you try holding the control lock button(perhaps its the heated dry button) in for 3 secs???? sonds as if the CONTROL LOCK has benn activated( child lockout)
Jan 14, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Lock on button
hold the heated dry button for 4 seconds
May 06, 2008 | Dishwashers
Kenmore Ultra Dishwasher. Model 665.15772990
There should be a button on the machine with a padlock symbol. Hold it down for 4 seconds to unlock it. If you want to lock it again, hold it down for 4 seconds to turn it on.
Jun 01, 2007 | Kenmore 24 in. 16032 Built-in Dishwasher
Dishwashers Logo
37 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
