Question about Bissell 1697-7 Powersteamer Pro Deluxe Vacuum
Model 1697.m Bissell carpet cleaner.
This machine is only a few yrs old . And only used a few times. There was no water or solution coming out. So I cleaned all the filters and blew air from my compressor trough everything .I put it back together and after a few minutes it worked. I finished what I was doing and tried it the next day but nothing again. I took out the pump and submersed it in water until it was full . Plugged the ends where the lines went on . And reinstalled pump . I turned it on but nothing happened . I noticed some air bubbles in the line by the belt. I also noticed an air pocket in the line . I also took the line off the side by the belt while it was on but no water came out. is there air in the system .? Or is the pump bad . Is water supposed to come out that line while it is on.? The solution spinner doesn"t work either
Thanks Keith
    Problem Solver:
  • 7 Answers
You are going to want to replace the water pump on the machine. Also you might want to look into replacing the belt that runs it. If that still des not working, you probably have a clog in the hose coming form the heater element. This is VERY common with the Bissells. Good Luck!
Posted on Jan 09, 2008
2 Suggested Answers
EwingElect
  • 276 Answers
SOURCE: How do you change the 2 belts on the Bissell 1697-...
Check the manual at http://www.bissell.com/searchresults.aspx?searchtext=1697&mode=userguides
Information should come with the replacement belts, but there is also information on page 16 of the above listed userguide.
Posted on May 23, 2010
The cleaning solution will not come out of the wand or thecarpet cleaner.
Hi James. Sorry you're having difficulty with your machine. I understand how frustrating this must be.
Here's a quick link to troubleshooting steps to assist you with the spray:
http://www.bissell.com/FAQDetail.aspx?id=1065&cid=ccsocial
Apr 18, 2013 | Bissell 1697-7 Powersteamer Pro Deluxe...
My power steamer model 1697, 8804 series doesn't **** up the water
I filled up my Bissel power steamer with hot water. I also filled up the formula mix. It turns on and sprays. The "dirty" water was seen the first time I used it. Now there the clean water is on the carpet and no dirty water is in the tank what"s up???
Jan 01, 2011 | Bissell 1697-7 Powersteamer Pro Deluxe...
Water doesn't come out of my Bissel Deep Cleaner
Did you use TAP water...not a good idea.Use de-mineralized water you can get at most pharmacies,there is probably mineral buildup in the lines.
Mar 23, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
My Bissell carpet cleaner model #1697-W will not dispense the cleaning solution and will not **** the water back up--also need to know how you get to the belt on the machine?
The drive belt for the pump is located under a cover on the front right side as you look for the front of the machine. Just lift it up and the belt will be obvious. If it is not sucking then make sure that the dirty water tank is empty and that all the filters are clean and the front of the machine is not clogged with fibres, dirt or hair. Also check pre and post motor filters and clean them if required. Then check the mix control is working OK to allow fluid to flow out of the machine and not switched off. Bissell's are simple machines.
Oct 06, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
Carpet cleaner not working properly will not send out the water
his is a very common problem with Bissell Carpet Shampooers...
Fortunately it has a very simple solution.
The problem is caused by blocked water jets ! and if your machine is still under the two year guarantee,Bissell will collect and repair very quickly free of charge !
Good Luck !
Call them on
0844 888 66 44 - Option 1 (UK Only) (Monday - Friday, 9am - 4pm)
Sep 03, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
Not working
The bissell shampooers use belts t run the pump and the beater bar. if the master beltbroke which is the one that controls the pump and beater bar then yes the machine will not dispense water or turn the beater bar. it will have to be replaced *the belt that is*
Nov 13, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
Not putting out water
I had the same problem with mine and it was an easy fix. If you remove the soap holder without putting the selector dial to "water only" you will lose the prime in the hose that goes to the water chamber. It takes a few minutes of pulling the water trigger to regain that prime, but it will come back eventually. Easiest fix, of course, is to always remember to dial to water only when you need to add cleaning solution..
beth
Jun 02, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell 1697W power steamer
I JUST PURCHASED A NEW BISSELL CARPET CLEANER AND THERES NO INSTRUCTIONS IN MY BOOK AS TO HOW MUCH CLEANER TO USE, IT SAYS ON THE BOTTLE OF CLEANER THAT CAME WITH IT,IT SAYS TO ADD 5OZ.OF CLEANER TO EACH GALLON OF HOT TAP WATER
Apr 13, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell 1697-7 Powersteamer Pro Deluxe Vacuum Logo
578 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
