Question about Cell Phones
Does formatting my sd card erase everything? - Cell Phones
    Problem Solver:
  • 15 Answers
Yes. Formatting a cart re-writes the file allocation table to which all data is written.
Posted on Nov 12, 2009
Testimonial: "thanks"
Cant get past 'card not initialized', even though I've used it in this Fuji finepix jx500 camera before. it erased pics when i hit format, but that's all.
Make sure that you do a format in your computer before you reinstall your card,check to see which format you require some want fat 32 others may require a different format.
Apr 19, 2014 | Fuji Film FinePix JX500 14 Megapixel...
I cant take pictures because shows the card is full, how can i erase the sd card
You can erase in the camera, or format the SD card. Or open Start Menu, Computer, Click on the SD card, open, select ALL, delete, OR, right click on the SD card, format.
Jan 16, 2013 | Sylvania G-Netbook
Formatting a disc containing data
if you format a disc or card it erases everything,permanently
Jul 15, 2012 | Computers & Internet
How to erase sd card (pny 8gb)
Put the card back into the camera and use the camera's "Format" command. This will erase EVERYTHING on the card and prepare it for further use.
If you require further assistance, please add a comment to this question and specify the model of your Sony camera.
Feb 02, 2012 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
Everytime I put the SD Memory card and I try to take a picture or video it says card protect and won't let me do anything. What should I do?
i had this same problem... take your SD memory card to a computer, and format it then it should work.
Once loaded into a computer: 1) locate drive under My computer that should say SD or removable disk 2) right-click and then click the format tab 3) one the window is open format the SD card . . . it will erase everything on the card but it should solve your issue.
Nov 28, 2010 | Vivitar DVR410BLACK Pocket Video Camcorder
I want to format my SD ?
If you want to format your SD card then open up "My Computer" - right click on the SD card, choose "Format", then check the settings that come up (name, FAT or NTFS etc) and choose ok.
Remember this erases everything on the card so be sure you are ready for this!
Oct 31, 2010 | Computers & Internet
I have a dc ST-201-VP model and cannot format the camera and have not been successful formatting the sd on the pc.c.p
If you cannot format the SD card on your computer, look at that first. I have actually had an SD card that didn't work before. As they look so simple I found it odd, yet it did happen.
Look at that first.
Remember that when you format a memory card or anything you are essentially erasing everything on it!
Jul 17, 2010 | Cameras
Virus on sd card
If your pc tells you the sd card is infected it means you have an AntiVirus running. You can use it to remove the virus by SCANNING the card.
You can also get rid of the virus by FORMATTING the card using the camera. The Format option (NOT EARASE) is usualy found in the settings menu. But beware, you will lose all the pictures as well.
Feb 08, 2009 | Panasonic Lumix DMC-FZ5 Digital Camera
Card Error
please check the following: Always choose reliable quality SD Cards. Toshiba Digital Cameras are tested for maximum performance with Toshiba SD Cards, Delkin SD Cards and Panasonic SD Cards. These are leading brands in the development of standard SD technology. Performance by other brands of SD cards may vary. Check the LOCK switch on the SD Card. The camera can not save images to an SD Card when it is in the lock protected position. If the SD Card is NEW, it may be necessary to FORMAT the card. This only applies to NEW SD Cards. If you format a card with images, all images will be erased. You can FORMAT your card periodically to maximize capacity and erase 'unseen' files, please be sure to download all images before choosing FORMAT as all images will be erased. Your Toshiba Digital Camera is designed for use with SD Cards. MultiMedia Cards are similar in size and shape to SD Cards, although with close inspection you will find that SD Cards have a different 'PIN" connection configuration, are slightly thicker in size, and have a manual slide LOCK switch on the side. Toshiba Digital Cameras are not designed or guaranteed to accept MultiMedia Cards. Please be sure to look for SD Cards from Toshiba, Panasonic and Delkin, the leaders in SD Card Technology.
Sep 11, 2005 | Toshiba Sora PDR-T20 Digital Camera
Card Error message
1. Always choose reliable quality SD Cards. Toshiba Digital Cameras are tested for maximum performance with Toshiba SD Cards, Delkin SD Cards and Panasonic SD Cards. These are leading brands in the development of standard SD technology. Performance by other brands of SD cards may vary. 2. Check the LOCK switch on the SD Card. The camera can not save images to an SD Card when it is in the lock protected position. 3. If the SD Card is NEW, it may be necessary to FORMAT the card. This only applies to NEW SD Cards. If you format a card with images, all images will be erased. You can FORMAT your card periodically to maximize capacity and erase 'unseen' files, please be sure to download all images before choosing FORMAT as all images will be erased. 4. Your Toshiba Digital Camera is designed for use with SD Cards. MultiMedia Cards are similar in size and shape to SD Cards, although with close inspection you will find that SD Cards have a different 'PIN" connection configuration, are slightly thicker in size, and have a manual slide LOCK switch on the side. Toshiba Digital Cameras are not designed or guaranteed to accept MultiMedia Cards. Please be sure to look for SD Cards from Toshiba, Panasonic and Delkin, the leaders in SD Card Technology.
Sep 11, 2005 | Toshiba PDR-3300 Digital Camera
Cell Phones Logo
268 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
