Question about Drills
Charger adapter and battery get warm but charger light won't come on. Batteries don't charge any more. Are there supposed to be 2 or 3 charger contacts in the charger? Mine only has 2 but the batteries have 3.
  • 28 Answers
This could be an indication of a bad cell in the pack. As nicad batteries get older they will sometimes short internally do to oxide buildup. If one or more cells are bad the pack as a whole will pull more current from the charger which in turn could cause it to heat up. Most newer chargers have 3 contacts. The 3rd contact is normally conected to a diode inside the pack. The chargers circuitry monitors the batteries temp by measuring the voltage drop on the diode.
Hopefully this may give some insite.
Posted on Nov 13, 2009
How long do Kodak KLIC-7001 batteries usually last? I just bought a new charger (K7700) for my battery and when I put it in the green light flashes and then the red and then goes right off. Why is this...
the battery might be bad. One thing I learned with drills, is to never charge a battery directly after use (if it feels warm), and do not use when warm from the charger. I'm not sure on specialized batteries, but normal batteries like AA, AAA etc. only last about one year or so.
Mar 24, 2013 | Cameras
I purchased a brand new P113 Ryobi charger about 2 years ago. It has never worked. If I put a P104 battery in for a charge, it looks like it works correctly. I push the battery tester on the battery...
If you have your receipt, check with Ryobi to see if it is still under warranty. It comes with either a 2 or 3 year warranty, depending on when it was purchased. If it is still covered, get it replaced/repaired. If it is not, buy the P117 charger. $30 at Home Depot. It has a 90 day satisfaction guarantee. If it charges your batteries properly, you're good. If not, bring it back if you don't like/want it. My P113 won't get out of test mode now, or charge Lithium batteries anymore. So I bought the P117 yesterday. Works great, and it's a lot cheaper than new batteries! And it has a 3 year warranty.
Aug 28, 2012 | Ryobi P113 18 Volt One Charger 140501001
I have 2 batteries but some how i can not charge even i have left them 24 hrs to charge
Digital camera batteries are usually with an external battery charger.
The charger maybe faulty, the charge adapter will have a LED indicator to indicate that it is charging.
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Jun 15, 2012 | Samsung Digimax L730 Digital Camera
MotorOLA XOOM battery won't charge
Keri
Maybe a bad charger.
Mark
Motorola Support
Mar 15, 2012 | Motorola Mobility Xoom
Red and green flashing lights on 18v lxt charger
Batteries don't always look degraded but if they've been in use for a while or have a bad cell, they will show up bad on the charger and it won't charge them. The only way to test the batteries is to try to charge them on another charger. If the batteries show defective on another charger, they are bad and you'll have to replace them. Also try to charge some batteries you know to be good on your charger to see if it's the problem. If your batteries charge on another charger, your current charger is bad and they don't have any replaceable parts in them so you'd be looking at replacing it.
Feb 21, 2012 | Makita Tools & Hardware - Others
Battery is not charging.
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced. Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Apr 14, 2011 | Gateway MX6453 Notebook
Battery in charger overnight, red light flashing, insert battery in drill, it doesnot work. Please advise. Thanking You Bob Falzano
If only the red light is flashing then the battery is not charging at all. Ryobi identifies in the manual that batteries will not charge below 43 degress F. If your batteries and charger are in the garage in a cold climate, warm the batteries to room temp in the house and then try again. If the charge starts when the batteries are warm they will continue charging for the full cycle even in a cold area.
Dec 24, 2010 | Ryobi Multi-Volt Battery Charger
Battery discharge quickly, I have replaced new batteries and module control and problem still exist.
Don your charger is probably not charging the batteries. When you charge your chair overnite the charger should have a red and green light showing charge complete. When you first plug it in the lights should be red and yellow. If you are getting a red and green light when you first plug it in then there is a problem with the charger or with the charging circuit to the batteries. You should have a charger port on the battery box try plugging the charger into that port and see if you can get the batteries charged. When you do you should have a red and yellow light on the charger changing to red and green when fully charged. Hope this helps
Nov 07, 2010 | Pride Go Chair Travel Power Chair
Ryobi 18V lithium battery won't charge
Hi, Thanks for getting back to me. The yellow and blinking red indicate a defective cell. Since it has lithium cells and is that new any repair to it would be a waste of your time. Ryobi tools purchased in 2008 have a 2 year warranty. I am guessing you probably got it at a home depot and you should return it under the warranty. All new Ryobi tools have a three year warranty. Good Luck! and Thanks for using fixya!
Feb 05, 2009 | Ryobi Two 18V Lithium-Ion Batteries +...
MOTOROLA T5522 BATERIES
Hello mironas3,
A general rule of thumb when dealing with rechargeable battery packs is to take the capacity of the battery divided by the charge rating of the charger and then add an additional 10%.
Offhand I am not sure what the voltage / capacity or voltage / charge rating of the battery and charger are but you can determine that by examine the labels on both items. Let’s say (for example) that your battery is listed as 7.2 volts and 1,000 mAH and your charger is rated as 9 volts and 100 mA. (These are just theoretical examples. Substitute the numbers from your own items.) You would divide 1,000 mAH by 100 mA to equal 10 hours. Then add 10%. So you expect a full charge to take around 11 hours time.
Of course, actual charge time will vary depending on how discharged the batteries are when you start charging them. Since the charger that Motorola provided doesn't have a charge indicator determining when the batteries are done charging is a matter of making an educated guess. If you touch the batteries while they are charging and they feel warm to the touch, that's a pretty good indication that they are done or nearly done charging as once the batteries are topped off excess power will turn into heat. (Note that batteries in a charger should never be HOT. If they are ever more then just slightly warm, something is wrong with the battery or the charger or both.)
Also, just a word of warning here: remember to always use the correct manufacturer recommended charger. Substituting a charger with twice the charge rate to charge the batteries in half the time is not a good idea. Rechargeable batteries are meant to be charged slowly. Fast chargers exist but they typically have built-in circuitry that pulses the charge rate to prevent the batteries from overheating. Using the wrong charger can result in damage to your battery or radio or worse could possibly even lead to a fire.
Best Regards,
Ken
"Go Ahead. Use Us."
Jul 28, 2008 | Motorola T5522 (7 Channels) 2-Way Radio
Drills Logo
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
