Hi i have a dsl g684t router during the update of my firmware my pc tune of now i cant connect too my router pls help me ...... srry my bad english....
    President:
  • 2,351 Answers
Shut down your system.
Try unplugging the power cord from the router. Find the small reset button on the back of the router. Use a pen and press in the reset button for ten seconds or so. Reconnect the power to the router. Than startup your system. You should be able connect to the internet now.
If not than the problem is with the firmware update. Contact, D-link tech support. http://www.dlink.com/support/
Cheers!
Mike
Posted on Nov 12, 2009
Dlink Dsl -2730u
Two possible causes for this:
1. Power fluctuations has caused the AC to DC power supply to over supply the router with current. This will damage the router's electronics. Solution to this is to buy a new router.
2. Updated firmware: if you updated the firmware and the new firmware got corrupted during the download, you could experience that problem. I will suggest to revert back to a previous version if this occured.
Feb 25, 2014 | D-Link Computers & Internet
Which is the latest firmware update for the 2540U Router? http://ftp.dlink.ru/pub/ADSL/DSL-2540U/Firmware/ is the only site I can find with updates on it but I'm not sure which to choose.
Make sure you download the correct firmware for you Hardware.
Usually you can login on your browser to you router and go to the management section to check for firmware updates and select that button and it will download and install the firmware. On some models, you have to go to the D-link web site and look for firmware updates for your router. Always check what you current firmware you have installed and check the version of you router modem hardware (A, B, C etc). Then you can manually download the firmware (usually in a ZIP file), open the zip file, and then using your browser connected to the router look for Update Firmware. You will have to go to where (folder) you saved the downloaded update and select that file. It is recommended that you update using a LAN connection and not a wireless connection.
Apr 28, 2011 | D-Link ADSL2/2+ Modem/Wireless Router...
How to upgrade firmware
Click on the link below to open the Dlink Webpage to update the firmware.
Click on Support Resources
Choose your country to update the firmware.
Follow the instructions on the link to know how to update the firmware. ( Firmware update is done by connecting the Ethernet ( network cable ) from Router to PC.
Firmware Update
* Please rate this solution with Thumbs up and comment to help us improve providing support
Dec 01, 2010 | D-Link DSL-2640B Wireless 11/54Mbps ADSL2+...
No internet connectivity after upgrade firmware
1,there is a reset button
2,press this using any pin with power
3,automatically restart
4,connect your router with pc
5,type 192.168.1.1 on the browser
username:admin
password:admin12 or admin
configure router
enable dhcp
Oct 29, 2009 | D-Link DSL-G604T Wireless Router
I have just tried to connect my wii console to the inter net through my d link dsl g604t router and up came a error code having looked at the support page i have come to the condlusion that i have never...
This page has firmware for the DSL-G604T. There's a guide to updating firmware on the same page if too - usual advice is to backup current firmware configuration if possible, use a wired connection etc.
Hope this helps: good luck
Dec 30, 2008 | D-Link AirPlus G DSL-G604T (790069265662)...
My laptop can't find my wireless router
the best would be trying to upgrading your router to a new firmware like tomato or dd-wrt which has much better features and your wireless device would start working.
www.dd-wrt.com that is the one i use and its fantastic.
Dec 29, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Cant get wireless to work
Since your ISP is new, you need to do a reset on the router. Reset involves pressing a small recessed button at the rear of the unit for about 10 seconds or more.
On the Vista PC, pls verify that it is set to Auto obtain IP add and to connect to your router/WiFi network even if the network is unsecured.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa..
Apr 02, 2008 | Linksys Wireless-G WRT54G Router
Belkin wireless router
Your Belkin router is normally configured to get a dynamic IP Add from your Internet provider unless otherwise configured. Most ISP's network where clients/subscribers connect (through DSL) has a DHCP server that hands out this IP adds. If your router keeps on changing its WAN IP add, it may presumably be because:
1. Your router keeps on rebooting or powering on/off and everytime it turns on, it is given a new IP add;
2. Your ISP's DHCP server keeps on renewing its lease on the IP add given to your router.
Corrective measures would entail:
a. Do a full hard reset of your router and go through the installation setup again. Of course this would revert all settings/configuration to factory default; and/or
b. Contact your ISP and explain your concern.
In some cases, the router's MAC address has an issue that the ISP's DHCP is keeping a hard time recognizing it. this can be corrected with a firmware update.
Hope this be of help/idea. Pls post back how things tunrs up or should you need additional information.
Good luck and kin regards.
Feb 03, 2008 | Belkin (F5D7230-4) Router (587009)
Belkin Router - Network works for 5 minutes than everything loses internet capability.
hi,
           This issue usally occurs when the router is able to save the data stored or in  other words the Router id not able to AUTHENTICATE,  but as you already got a new router and you have already done the fireware upgradation of the router. we can also upgrade the firmware of your speedstream modem.
plz do these following steps ,( plz disconect the router from the computer and modem completly while doing the steps )
The Efficient 5260 modems that can be upgraded are as follows:
Look on the label on the bottom of your modem. It should read:
SpeedStream 5260 Ethernet ADSL Modem
Part Number: 060-5660-00x (where x=any number)
Revision: any (all revisions seem to work)
If your part number reads anything else, your modem is most likely not upgradable.
For those curious, 5660 models 003 and earlier do NOT support G.Lite ADSL, only DMT. If you are buying a 5260 or 5660 model secondhand, and your DSL ISP uses G.Lite DSL, it would be a good idea to check with the person selling you the DSL modem.
UPDATE: As of 5660 Firmware v2.3.0(2) and later all 5660 including 5260/5660 hybrids support G.Lite ADSL. It pays to use the latest Firmware.
PLZ REPLY IF THIS HELPS, I WILL TRY TO FIND OUT THE RESOLUTION FOR THIS ISSUE
REGARDS.
Gunjan ';';';';';';';
Oct 18, 2007 | Belkin (F5D8231-4) Wireless Router...
Random Disconnection and WLan indicator lights
Saw this on another post for this router: "in the DHCP configuration on LAN menu. the lease time was set to 72 hours (3 days) i change it to 720 hours, cos that was the most it would allow... so hopefully that would fix it. " maybe you're having the same problem. another usefull thing to do is to update the firmware from the D-link site. some stability issues such as this should be fixed by a firmware update. post what happened goo luck ;]
May 10, 2006 | D-Link DSL 604+ (DSL-604+) Wireless Router
Computers & Internet Logo
280 people viewed this question
David Payne
David Payne
