Question about Honeywell Power Humidifier: Furnace Humidifier/ Humidifier
Chronotherm III...Replace Battery notification blinking...replaced twice with the appropriate batteries, turned the correct way. Cleaned off the battery terminals and still have replace battery notification?
Thermostat problem; Honeywell chronotherm lll ' Low Batt. indicator Keeps blinking after Batteries replace. I chk'd batt. with elect. volt ntr. Was told to pull batt. and change ends with them , letthem stay reversed for 5-10 sec. then put them back in right order,and replace thermostat. No success!
Anyone have any answers
Posted on Jan 13, 2010
  • 2 more comments
  • Aehdk111 Feb 20, 2011
    I have the same problem... I replaced all 3 batteries with brand new ones, but still... the "Repl. Bat." light stays on... Any suggestions???
  • packrat190 Mar 03, 2011
    I have the same problem, looking for solution
    I found that light sandpapering on both terminals where the batteries make contact cleared up the replace battery light indicagtor problem.
  • Ann marie Dec 16, 2011
    Sandpapering worked for me! Thanks so much. We now have heat again,!
Cleaned both my battery terminals with a small metal file untill the contact shined bright again and problem fixed.
Posted on Aug 30, 2012
  • Justin Prime
    Justin Prime Aug 28, 2014
    For me, it was not the contacts, although the contact wipers do need to be bent in carefully to maintain proper pressure. I found that if you leave the batteries out 2-3 minutes, the "replace battery" indicator will go out. You will need to reset the time but all other settings will be retained.
I HAVE A "honeywell chronotherm
Open the front panel, opens from the top, hinge at the bottom. You will see 2 Philips screws at the bottom at the "hinge" part. Unscrew them. Pull the thermostat from the wall by pulling off the top part. You need 3 AA batteries. You have 20-30 sec to change the battery without re-setting the program, so be prepared and have batteries handy. Make sure your + and - are in correct order- have a flashlight handy to see well. If you done it in time- you all set, if you are a bit late prepare to re-program according to your liking. You can re-program it while it is away from the wall, sitting in your chair! Instructions are on the inside panel, which you open All the best!
Nov 23, 2010 | Honeywell Power Humidifier: Furnace...
A/C won't come on, replaced batteries, display reads -AC Honeywell chronotherm III Thanks for any advice !!!
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Aug 07, 2010 | Honeywell Power Humidifier: Furnace...
I have a Honeywell Chronotherm III Thermostat and in instead of showing the temparature in the display it shows -AC. I've replaced the batteries, and tryied adjusting Temp up and down for cooling and...
It would appear to me that you have lost the 24 volt power supply to the thermostat. In referencing the manuals for this thermostat, available @ www.honeywell.com, I've found that when the thermostat is not connected to the wall plate (plate mounted on the wall, that the thermostat either snaps or screws into), it will display the -AC. This being said, either the thermostat is loose on the wall currently, or your 24 volt transformer has died. Hope this helps.
Dec 23, 2009 | Honeywell Power Humidifier: Furnace...
Thermostat does not read current settings or respond to commands.
HONEYWELL WEBSITE:
Go to honeywell.com
Oct 08, 2009 | Honeywell Power Humidifier: Furnace...
Honeywell Chronotherm III is stuck on Repl Batt
when i have seen this in the past, i have been able to clean the contacts that the batteries touch.they may not look dirty, but if they get a little corrosion or get tarnished, they will not let the full battery power get to the stat and it will think the battery is low. try cleaning it with some emery cloth and see if that helps.
Jan 12, 2009 | Honeywell Power Humidifier: Furnace...
Fan shuts off too soon after oil burner stops
That is an old style t-stat i would replace it with a more up to date model. Your problem may be in the limit switch. But yes to answer your question most fans can be adjusted just depends on if it has a manual limit that looks like a silver box on the interior of your furnace or if it has a mother board control system.
Jan 04, 2009 | Honeywell Power Humidifier: Furnace...
Honeywell chronotherm III air conditoner
I had that last night. I turned off the unit for a couple of hours and it came back on and ran and cooled. I have no friggin' idea if it will work but it got us through last night.
Jun 05, 2008 | Honeywell Power Humidifier: Furnace...
Replacing thermostat for central heat and air/ not humidifier
rh and rc should have a jumper between them.connect red to either.y=yellow g=green w=white and do not use the blue.your new stat will run on batteries.
May 26, 2008 | Honeywell Power Humidifier: Furnace...
Try this link:
http://yourhome.honeywell.com/yourhome/Applications/TechLit/TechLitSearchResults.aspx
It looks like there are a variety of model numbers for the Chronotherm III. Hopefully you can locate your model number.
Dec 17, 2007 | Honeywell Power Humidifier: Furnace...
Humidifiers Logo
3,843 people viewed this question
Top Honeywell Humidifiers Experts
Dennis
jdthefixer
Bill Long
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
