Pc trys to start up then just shuts down after installing more memory and blowing dust from cabinet.I have tryed removing all conponets cleaning and inspecting then reinstall.But still wont start up replaced power supply and isolated all compontes could it be the mother board going to ground? ken
  • 4,806 Answers
Hi Ken,
It is a possibility that the motherboard is on it's way yes but the fact it's still receiving power I'm not so sure.
Take a close look at the motherboard for any swollen or discoloured capacitors. If you find any then your looking at a new motherboard.
If you can see any remove the memory. Get a soft, clean, dry paintbrush and clean the memory slots with it, blow quite hard on the slots to remove any stubborn dust.
Get the original memory and put that in the machine and see if it will boot up.
If it does then chances are that the new memory you have got is either faulty or the wrong clock speed.
Good luck and please let me know how you get on.
Posted on Nov 12, 2009
  • 241 Answers
Reinstall the memory that worked OK.
If it still won't start, you did something wrong during the RAM upgrade. Look for missing connections or a wire that may have come loose during the "dust blowing". Also, be sure you didn't leave the cooling fan/fins loose on the CPU heatsink.
If the old RAM still works OK, then you may have installed the wrong new RAM. Make sure the speed and CL are identical to the working RAM. Just because it fits in the slot, that doesn't say it's the correct RAM for your computer. Wrong RAM will prevent startup in the way you mentioned. Do a Google search to be sure you're using the proper RAM upgrade and that your computer /operating system can actually address how much you put in.
Subzero Model 3211RFD continually runs
remove the top panel and check the coil and the condenser fan motor,that coil should be cleaned at least once a year.the way i clean the coil is remove the cover on the left side,usually just two phillips screws,this is the cover behind the front panel,then on the left side you'll see a quick disconnect,just unplug the wire harness and it will shut down the machine,get a towel and cover the opening,then on the right side of the coil,vac it off with a shop vac,use the brush attachment so you don't damage the fins on the coil,then put the hose on the other side of the vac so it blows and blow through the coil,the towel keeps all the dust inside the cabinet so it doesn't blow out all over your kitchen, do this a few times,lift the towel after every blow and vac up all the dust,then depending on how the top is move the towel over to cover the right side and blow through the coil where the fan blade is,it's best to blow it out from both sides,also before you move the towel over to the other side,put it on blow,stick the hose under the towel and blow into the cabinet to lossen all the dust up then move the towel and blow out the coil,vac out all the walls inside the cabinet.this is the number one killer of sub zero machines,if the coil isn't cleaned out,the oil in the fan motor dries out and the motor dies and then the compressors can overheat and need to be changed,you're talking big money.if the fan is ok up there and the temps.are normal inside the cleanout should take care of it running to long,the heat from the machine escapes through the coil so if it's clogged with dust it will run hot and longer than normal.hope this helps and good luck with your machine.
Sep 24, 2011 | Refrigerators
Pc will try to boot into windows it stops and trys again .it keeps repeating itself
This problem occurs when Operating System is corrupt ,due to some reason your OS has corrupt so you need to reinstall OS.
Aug 18, 2011 | Computers & Internet
Otiplex 760 will power up breifly and shut off as if the thing was unplugged , sometimes will stay running for a few minutes and sometimes will shut off immediatly. I cleaned the old heat element compound...
1. Try blowing the dust on the motherboard, if any hard dust is present, use soft brush to clear it.
2. Again remove the Heatsink on the processor, completely clear the compound using soft cloth, There should not be any hard particles or dust left, apply heat sink compound on both the heat sink side and on the processor, put back the heat sink and fan.
3. Check whether the power button on the cabinet is not struck and functioning if possible try to replace the button.
4. Blow the dust even from SMPS or try with another if handy.
Sep 05, 2010 | Computers & Internet
Makes a beeping sound six times when starts up. Will not excite monitor.
Open the cpu cabinet cover.Clean dust from all parts. Pull cmos cell from motherboard. Reconnect RAM memory.Try with another RAM if you have. Reconnect processor and it's fan. Make sure motherboard is not ground with cabinet cover. Remove pci card if any if you use vga card then reconnect it. Then check. Let me know if you need further assistance. Thanks for using FixYa.
Jul 19, 2010 | Dell Dimension 4600 PC Desktop
Shuts down randomly. Has been cleaned of dust,
Hello there...
I've been experiencing similar problem once.
In my case it was caused by faulty Network Interface Card, if you have a PCI Network Interface Card try temporarily remove it from the PC and then use the PC as you would normally do.... and see if it still shutdown randomly.
And if after test there is no random shutdown occurs, consider to replace your Network Interface Card.
Hope that helps... :D
Apr 13, 2010 | HP Pavilion s7600n PC Desktop
Dell OYF 432 Motherboard won't boot. Starts to boot then trys again.
Try removing each ram stick one at a time,be sure to shut down the pc while removing/replacing memory. If that yields nothing,remove the cpu heatsink,clean it & apply new thermal grease. If that doesn't work, then the motherboard is done.
Mar 15, 2010 | Dell Computers & Internet
My computer has been shutting down on its own the last two days. when i turn it back on the mb beeps a really long beep. the computer will run for only 5-10min before shutting down again. any ideas? i...
The long beed means you have refix RAM memory and processor.
For that open cpu cabinet and find motherbord.
Refix RAM memory on motherbord.
Open processor fan and processor.Then refix both.
Remove pci cards then refix it.
Make sure motherbord not ground with cabinet surface.
Then check.
Let me know if you need more assistance.Thanks.
Nov 06, 2009 | Soyo P4X400 Dragon Ultra Motherboard
No post no video Beeps once every sec. The first few times it boot I had video. Then lost video now I have it back. it will run all day when in the bios. But outside the bios trying to load Windows XP home...
Hi...
Actually the problem is the memory witch is beeping every seconds during turning the laptop on. Check your memory stick, remove the memory stick, clean from dust. Reinsert it try to use the other memory slot. If the problem is still occurs the memory stick is bad or faulty already. You need to replace the memory stick.
Thanks for using fixya
Regards
PCmania
Aug 15, 2009 | Toshiba Computers & Internet
The visible fan at the top of my tower appears not to be running. Also computer makes a lot of noise and several times when I have turned it on it shuts down. There appears to be a lot of dust on the fan...
. You could try air but if the fan does not work the computer overheats and shuts down to protect itself.
The air won't hurt, but more likely you have a bad fan which is going to require either you or someone to open the cover, go into the computer, remove the fan, buy a new one and put it back in.
Dec 02, 2008 | Computers & Internet
Trouble shooting of motherboard
Hi thayal, systems shut down because of over heating. This is normal so nothing burns up. Try opening the case & clean the CPU fan. Remove any & all dust from the fan blades. Use a clean non used paint brush to help loosen any dust build up. Than blow the entire system out with canned air. Blow out the power supply as well. When finished put the case back together & see if the system shuts down.
Luck!
Mike
Jul 12, 2008 | Asrock K7VT2 Motherboard
Computers & Internet Logo
81 people viewed this question
David Payne
David Payne
