Question about Sentry Fireproof Safe
Opening instructions for a Sentrx A3817 - Sentry Fireproof Safe
    New Friend:
I have the key and combination to my safe, but haven't open it in a while, is there a battery that can be changed?
Posted on Jan 08, 2013
Have a 36" storm door. Instructions call for a 35 7/8" - 36" opening width (between vertical brick molding trim). Currently i have about 35 3/4-35 13/16". Suggestions please
You just need a 1/8" piece to add to the opening... you can screw it to the opening...measure the width that is necessary and the height (minus 6" - 3" on each end)....PREDILL the 1/8 piece with a 1/16" drill bit and use #1 size screws about 3/4" long. .This will take up the excess space..
Jul 06, 2017 | Cars & Trucks
I have ane electrolux dryer with reversible doors. I would like to keep the door opening to the left, but it hits the wall. Is it possible to adjust the door to make it stop before hitting the wall?
Hi Wendy, this is AP
I understand you want to reverse the door opening on your Electrolux dryer. I would be happy to assist you with those instructions. Are you able to provide the model number for your dryer? If this is a new dryer you may visit the manufacture website, locate your appliance, scroll down to bottom and you will see a listing of documents available, the installation instruction manual will have the reversal instructions listed. . I hope this information helps to some degree - thanks for your question, and please do not hesitate to reconnect if you have additional information regarding your question.
Thank you,
Mar 21, 2014 | Electrolux Dryers
Simplicity pattern instructions # 4636
This is a Sewing Machine Q/A
Feb 25, 2014 | Sewing Machines
Record opening message
Follow the instructions on page 42 of this manual.
Nov 22, 2012 | Panasonic KX-TG2431 Cordless Phone
How do i attach the hose to the vacuum so i can vacuum my vents?
Remove the vacuum head by tilting the front down slightly and pulling straight back. Attach the wand hose onto this opening by placing the small hooks of the hose on the bar beneath the opening and pushing the hose against the vacuum base. Lock the hose in place by turning the vacuum head lock from left to right so it catches the hose.
Read more: Kirby Ultimate G Instructions ' eHow.com http://www.ehow.com/how_7935766_kirby-ultimate-instructions.html#ixzz1VyB7yixm
Aug 24, 2011 | Kirby G6 Bagged Upright Vacuum
How to change the code
I need to get the Factory Code for a MN A3817 Sentry Safe. I have the key. I have the SN.
Feb 11, 2011 | Sentry Fireproof Safe
I desire the default code for my older model a3817, I can not locate the information.
If you have the model and the serial number you can contact customer service and they will be able to supply your code for you. You'll need to supply some paperwork but it depends on which country you are in to what you need to supply.
There should be a white label on the front of the safe which will have the model and serial number on it - if you don't have it from there, there should also be a label with the serial number on it stuck to the bottom edge of the plate that the keypad is part of.
Feb 08, 2011 | Sentry Fireproof Safe
METAL TIP CAME OFF THE GTM20 AND WONT WORK SO GARMIN SENT A FUSE AND REPLACEMENT PARTS WITH NO INSTRUCTIONS ON HOW TO FIX IT.
1. Hold the "receiver" with the open end up.
2. Insert the small spring in the opening.
3. Insert the fuse in the opening.
4. Place the metal ring atop and around the opening with the "sharp" edge of the ring down and the smooth surgace of the ring up. The fuse should now be protruding thru the metal ring.
5. Place the chrome "tip/cap" atop the fuse end.
6. Place the black plastic part over the chrome "tip/cap" with the black plastic part's threads going toward the receiver opening and push the black plastic part's threaded end through the opening in the metal ring and into the receiver opening and screw it in fairly tightly.
7. The chrome "tip/cap" should now protrude through the end of the black plastic part and everything should now be securely held in its proper place.
8. You should now be able to press your finger down on the "tip/cap" and it should depress slightly and then spring back when you release it. If that works you should be able to plug it in to the car's cigaraette lighter opening and connect your Garmin GPS.
9. Last but not least: EVERY time you remove the GTM 20 from the cigarette lighter opening you should check to make sure that the black plastic part with the threaded ends (the part that's holding everything in it's proper place) has not loosened. If you don't check this religiously you are likely to end up losing one or more of the parts I've just discussed.
DO NOT be tempted to glue that part in place as the fuse may blow someday which will require you to replace the fuse.
Aug 04, 2009 | Garmin GTM 20 Lifetime Traffic Receiver...
Sentry Fireproof Safe Logo
711 people viewed this question
Top Sentry Home Security Experts
Jim London
Jim London
Computer Repairing
Computer Repairing
Hannah Johnson
Level 1 Expert
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
